My First Build
Post Date: 2011-10-15
invadercow View Drop Down
  Quote invadercow Quote  Post ReplyReply bullet Topic: My First Build
    Posted: 15 Oct 2011 at 4:04pm
Right now I have a computer I built myself, but recently the sound card has died, the video card is going, and it's just time to upgrade. It's been 5 years now. I should also mention I have three monitors I'd like to keep working with the new system.
My budget is 2,500 - 3,000. I could maybe go a little over (3500) if it means a big jump in performance. When I customized my PC on digital storm, It came to 3,900, which is far over budget. I'm not sure what I could remove to shave off some of the price without sacrificing performance.
I want a triple monitor setup (already have the monitors), capable of some serious multitasking. Now, my HUGE main priority is making sure these monitors work. I dont know much about if the graphic card needs SLI capabilities or not, so I'll let you guys help me with that.
I do a ton of multitasking, right now I have probably 20 windows open and they're all doing something important. I do a little bit of gaming, but when I actually decide to play a game, I want it to perform at its best on the maximum settings while I still have a lot going on in the background. I also do a lot of programming and graphics design work, so it isn't unusual for all 3 monitors to be filled with various memory-intensive applications.
Right now here are my usage statistics (this is low compared to the norm, since I just started my PC):
Processes: 110
Memory usage: 3.12gb / 4.093 gb
Physical memory: 78%
CPU Usage: 25%
Not sure if that will help, but I need as much memory as I can get.
I want this thing to be as silent as possible, and I want priority given to a good sound card and a good video card that will work with all three of these monitors. I cant say much about overclocking, I want this thing to last for a LONG time, but I also want to squeeze out as much performance as I can. Oh. Blue lighting is really cool too.
Below is what I've built so far, I couldnt decide a good ammount of RAM, but I figured for the way I use this computer, the more the merrier.
Saved Ticket #: 605946
Processor: Intel Core i7 960 3.2GHz (Quad Core)
Motherboard: ASUS Sabertooth X58 (Intel X58 Chipset) (Features USB 3.0 and SATA 6Gb/s)
System Memory: 24GB DDR3 1600MHz Digital Storm Certified (Highly Recommended) (6x4GB Sticks)
Hard Drive Set 2: Multimedia\Data: 2x (1TB Western Digital Caviar (7200 RPM) (64MB Cache) (Model: Black Edition)
Optical Drive 2: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x)
Internet Access: !PROMOTION: Killer 2100 (Optimized for Online Gaming) Lag and Latency Reduction
Video Card: 1x NVIDIA GeForce GTX 580 1.5GB (Includes PhysX) (Overclocked EVGA Edition)
Sound Card: Auzen X-Fi Hometheater HD 7.1 (Model: AZTHTHD02817) (PCI-Express Slot Based)
Extreme Cooling: H20: Stage 2: Asetek Liquid CPU Cooler (120mm Radiator) (Great Value)
Noise Reduction: Noise Suppression Package Stage 2 (Optimized Airflow & Fan Speeds with Noise Dampening Material)
Surge Shield: APC 1500VA Uninterruptible Backup Surge Conditioner (Recommended)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Oct 2011 at 4:08pm
You got it all wrong, that is the old platform.
let me ask you a few questions.
what are your monitor's res?
are you planing on gaming across all 3 monitors?
110 processes are too many, you got bs running in the background that does not need to run.
Edited by DST4ME - 15 Oct 2011 at 4:09pm
  Quote invadercow Quote  Post ReplyReply bullet Posted: 15 Oct 2011 at 4:16pm
What do you mean its the old platform?
My monitor resolutions are 1680x1050
I've never played a game accross all 3 monitors since I could never get it to work, so no, I'll probably never bother with that.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Oct 2011 at 4:24pm
LOL ok so all you need basically is to run the 1680x1050 res at max settings in most games.
thats easy.
old platform means there is a newer more powerful platform that has come out already. the p67 and 2600k will beat the 960 up and down the street all day with their eyes closed and hands tied behind their backs, lol.
so now I'm gonna give you some info, and based on your answer I'm gonna give you a build that will out due your config for less, unless your needs change after I tell you this:
to run your res at max, a 570 gtx is more then enough.
now this is the tricky part, you can game across all there monitors but you gonna want a system that can do dual sli and possibly give you tri sli option.
the dual sli we can do easy on the p67, but to have the option for tri sli properly, we need to wait for the highend platform due out nov called teh x79.
now the dual sli on p67 is gonna run your around $3000, the highend x79 is gonna be possibly little more expense ( they are not out yet so we don't know prices).
so I want you to decide if you are sure you want to game on one monitor or all three later on, cause the build for 1680x1050 is gonna be totally different then build for 3 of those.
also let me ask you something, you got 4GB of ram now based on what you said, is that giving you problem now?
what kind of apps do you have running? (you said you had like 20)
Edited by DST4ME - 15 Oct 2011 at 4:25pm
  Quote invadercow Quote  Post ReplyReply bullet Posted: 15 Oct 2011 at 4:38pm
Right now my monitors are dual SLI'd, but I dont plan on gaming across all 3 in the future. I just play any game on my center monitor. I definitely need all 3 to function though, I just dont need games to span accross them all. I'm not sure if an SLI is even necessary for the way I use these, I'm pretty sure it isnt.
The 4gb of RAM is definitely not enough, I originally had 6 but whenever i put in the last stick I would bluescreen, so I just gave up on that. I want this to last a long time in the future, so I'm thinking I'll just go ahead and get 12gb-24gb.
Right now here is everything running
/Java Applet 606,000K of memory
/Java Applet 500,000K of memory
Usually I two more open which basically uses all my memory. This is Minecraft and a Minecraft server, the other two are important apps I'll run on any computer I own 24/7. (they use 500,000k each)
/Two Iron Browser windows, 5 tabs each.
/MSN
/AIM
/SVChost is using 100,000k of memory, but that's necessary.
/A few document windows
/Teamviewer
That's it right now, except for the random things running in the background like NOD32, Tuneup Utilities, Utorrent, Peerguardian.
I've been through this comptuer 100x and I've eliminated most things I really dont need, so a lot of this would run on any computer I own.
Edited by invadercow - 15 Oct 2011 at 4:41pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Oct 2011 at 5:01pm
What os are you on? xp? must be cause pg won't work on vista or win7.
is your os 64bit?
if you have a pc that has 6 or 12GB of ram, something like Tuneup Utilities are pointless.
just giving info.
look at this tell me what you think, the stuff that is not in there from your config, is because it was gonna make no difference in performance.
Here you go Ticket# 605967 --- $2,743 (To see this build click here)
Motherboard: ASUS P8Z68-V PRO (Intel Z68 Chipset) (Features Intel Quick Sync Technology)
Video Card: 1x NVIDIA GeForce GTX 570 1.2GB (Includes PhysX Technology) (EVGA Edition)
95% of your noise comes from gpu's fan when underload.
the noise package make no real difference 10% at best, but it you trap noise you trap heat, and when you lower fan speeds you lower airlfow.
that case you chose does not have great airflow, its for systems with lc.
  Quote invadercow Quote  Post ReplyReply bullet Posted: 15 Oct 2011 at 5:08pm
I'm on Vista and it's 64bit. I figure I'll go ahead and upgrade to windows 7 Ultimate 64bit. I'll probably need to eventually, anyway.
This looks put together pretty well, surprisingly cheap too. I added a surge protector, and I think I'll just have two 1TB Harddrives instead of a solid state drive. It comes out to 3000. Pretty good. 1000 cheaper than what I came up with.
Do you think I should overclock anything?
Edited by invadercow - 15 Oct 2011 at 5:09pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Oct 2011 at 5:11pm
the ssd has speeds no hdd can can do, don't replace it with a hdd.
as for oc, whatever needs to be oced and to what level is already oded to that level on my config. just make sure your vcore is below 1.4 since you gonna run it 24/7.
  Quote invadercow Quote  Post ReplyReply bullet Posted: 15 Oct 2011 at 5:13pm
Alright then, looks like this is done. Thanks for all the help! You've saved me 1,000 dollars and probably a ton of trouble. I'd +rep you if this forum had rep. I'll be orderng this in a few weeks.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Oct 2011 at 5:31pm
Thats nice of you to say, but as long as you are happy and you got your money's worth and saved, that makes my day cause that is all I'm here for the rest DS has you covered
coolmasta View Drop Down
  Quote coolmasta Quote  Post ReplyReply bullet Posted: 15 Oct 2011 at 5:40pm
Can a single 570 hook up to three monitors? I know he's not gaming across 3 but he wants all 3 hooked up at once.
I7 2600k @ 4.5 Ghz, Noctua D14
8 Gigs Corsair 1600
HAF 922
Evga Gtx 580
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Oct 2011 at 6:17pm
I must have misunderstood him then, @invadercow did you want all 3 on at the same time?
IF yes then you need to change your gpu to 6970 or 6950, they can do 3 monitors at the same time but nvidia can't do 3 monitors with one card, you would need sli but there is no sense in blowing money on a second gpu for sli, instead one ati 6970/6950 will do great.
Edited by DST4ME - 15 Oct 2011 at 6:35pm
  Quote invadercow Quote  Post ReplyReply bullet Posted: 15 Oct 2011 at 7:48pm
Oh, well, yeah I want them all on at the same time. Like right now I have DS on the center monitor, MSN on the right monitor, and A bunch of crap on the left. I can move windows between each monitor. That's how I'm looking to have it setup.
So I should change the Nvidia card to a ATI Radeon HD 6950?
Should I get the 2x CrossFire Dual 6950 2GB's, or a single? I wouldnt mind spending a little extra if it would make this easier. Apparently to connect a single 6950 to 3 monitors you need some kind of a DVI adaptor or something.
http://accellcables.com/products/DisplayPort/DP/mdp_dvi_sl_active.htm
Edited by invadercow - 15 Oct 2011 at 8:00pm
  Quote coolmasta Quote  Post ReplyReply bullet Posted: 15 Oct 2011 at 8:00pm
Nah with that resolution a single 6970 will be great.
8 Gigs Corsair 1600
HAF 922
Evga Gtx 580
  Quote invadercow Quote  Post ReplyReply bullet Posted: 15 Oct 2011 at 8:01pm
Alright, hopefully it works. Id either get dual 6950s or a single 6970.
I'll order the adapter tonight.
EDIT: I would need to get eyefinity to make these work, right? Right now I have two Geforce cards SLI'd, so I'm not used to AMD. I currently use a program called Ultramon to control the monitors and span the taskbar accross all of them. Is this different with AMD? Does eyefinity do all that?
Also, since i wasnt clear earlier, just to restate. Each monitor is 1680x1050. Just making that clear aswell.
Edited by invadercow - 15 Oct 2011 at 8:09pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Oct 2011 at 9:46pm
single 6970 would be fine, yes eyefinity is what you would use.
get to know eyefinity here, at the bottom right there are links for how to stuff and things like that.
