My First DS Build. Opinions?
Post Date: 2011-05-19
coop70 View Drop Down
  Quote coop70 Quote  Post ReplyReply bullet Topic: My First DS Build. Opinions?
    Posted: 19 May 2011 at 10:39pm
Was 1500 but ended up going about 1800
Stable, fast computer to run for 2 to 4 years and then work for my son for a few years.
Mostly WOW and some Photoshop
Saved Ticket #: [541292]But order changed a few times.
Chassis Model: Special Deal Hot Seller - Cooler Master CM 690 II Advanced Got this case because I don't like lighting and this one allows lighting to be shut off
Motherboard: ASUS P8P67-M (Intel P67 Chipset) (New B3 Revision) (Does Not Support SLI)
System Memory: 8GB DDR3 2000MHz GTX-8 Digital Storm Certified Performance Series (Highly Recommended)
Expansion Bay: External USB Digital Media Card Reader
Hard Drive Set 1: Operating System: 1x (1TB Western Digital Caviar (7200 RPM) (64MB Cache) (Model: Black Edition)
Internet Access: Wireless-PCI N 300Mbps (Supports 802.11n/g/b)
Video Card: 1x NVIDIA GeForce GTX 550 Ti 1GB (Includes PhysX Technology)
Extreme Cooling: AIR: Stage 1: Coolermaster V6 GT Dual 120mm Fans (Compatible With AMD, i5, i7)
Boost Processor: FREE: Overclock the processor between 3.3GHz to 3.9GHz
Thanks for any input....
Stage 5 and can't wait!
coolmasta View Drop Down
  Quote coolmasta Quote  Post ReplyReply bullet Posted: 19 May 2011 at 10:46pm
What reolustion will you be using? Wow does not require that much, but I would hesitate to use anything less than a 560.
I7 2600k @ 4.5 Ghz, Noctua D14
8 Gigs Corsair 1600
HAF 922
Evga Gtx 580
  Quote coop70 Quote  Post ReplyReply bullet Posted: 19 May 2011 at 10:50pm
Actually I did call and upgrade to the 1x NVIDIA GeForce GTX 560 Ti 1GB (Includes PhysX) (EVGA SuperClocked 01G-P3-1563-KR). Called and changed after reading horrible reviews on the 550. Sorry I left that out. I'm hoping to be able to max out WOW.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 19 May 2011 at 11:56pm
If I were you I would go exactly with this instead, if you want the most power and reliablity:
Here you go Ticket# 545788 --- $1760 (To see this build click here)
Motherboard: ASUS P8P67 (Intel P67 Chipset) (New B3 Revision) (Does Not Support SLI)
Video Card: 1x NVIDIA GeForce GTX 560 Ti 1GB (Includes PhysX Technology)
Extreme Cooling: AIR: Stage 1: Corsair A70 Dual 120mm Fans High Performance Cooler
