My first order.
Post Date: 2008-09-22
Pantalones View Drop Down
  Quote Pantalones Quote  Post ReplyReply bullet Topic: My first order.
    Posted: 22 Sep 2008 at 12:11pm
First time post FTW!
Just ordered this demon spawn.  I call it a spawn because I'm on a budget of $3,000.
Let me know what you guys think.
Chassis: Digital Storm 850Si
Motherboard: NVIDIA 780i Core 2 Quad (Chipset: nForce 780i SLI)
System Memory: 4GB DDR2 1066MHz Corsair Dominator DHX (Extreme-Performance)
Card Reader: - No Thanks
Hard Drive 1: 320GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Raid Option: - No Thanks
Hard Drive 3: - No Thanks
Video Card(s): 2x SLI Dual (NVIDIA GeForce GTX 260 896MB (Includes PhysX Technology)
TV Tuner: - No Thanks
Sound Card: Creative Sound Blaster X-Fi XtremeGamer (CLEARANCE PRICED)
Extreme Cooling: Air Cooled Stage 3 WindTunnel (Copper Heatpipe Heatsink & Additional Case Fans)
Modifications: - No Thanks
Protection: - No Thanks
Pre-Install Game: Crysis (Pre-Install, apply updates, and test gameplay with my system)
LCD Display: - No Thanks
Forgot to add Ticket Number and Price.
TN: 185484
P:  $2,905.00
Edited by Pantalones - 22 Sep 2008 at 12:23pm
Tyler Lowe View Drop Down
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 22 Sep 2008 at 12:27pm
The X-FI has issues with Vista. I would go to a Razer sound card, or just drop the sound card altogether.
  Quote Pantalones Quote  Post ReplyReply bullet Posted: 22 Sep 2008 at 12:39pm
Didn't know that.  I'll call them and see if I can make those changes.  Thanks for the heads up.
So besides the sound card issue... everything else seems good?
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 22 Sep 2008 at 12:46pm
Yep. The rest is fine. I probably would have done something like this with the same budget
http://www.digitalstormonline.com/comploadsaved.asp?id=185524
Edited by Tyler Lowe - 22 Sep 2008 at 12:47pm
Nomak View Drop Down
  Quote Nomak Quote  Post ReplyReply bullet Posted: 22 Sep 2008 at 12:47pm
You might have to call them again..
1. Match your CPUs FSB w/ ram - 1333 MHZ + switch to OCZ ram (more reliable than Corsair)
2. Downgrade - but its really an (big) upgrade - to CM HAF case + change to red lights
3. For hard drive 1 go w/ a fast 300 gig Vraptor if money allows, you want a fast HD for your OS/apps/etc
4. Go w/ one CD/DVD drive - lightscribe edition
5. If you want to OC your CPU, invest in Liquid Cooling ( a must for good/stable OC ), but WindTunnel will suffice Star
6. Drop Crysis, buy it cheaper somewhere else
7. Invest in 4 year warranty (a must w/ OC'd systems)
8. Stay away from Creatives sound cards - Razer/Asus Xonar are more reliable
9. Downgrade to Vista Home Premium 64 bits
... any of the above would net you better performance/stability in the long run + peace of mind w/ 4 year warranty Smile.
Edited by Nomak - 22 Sep 2008 at 1:11pm
rai-zero View Drop Down
  Quote rai-zero Quote  Post ReplyReply bullet Posted: 22 Sep 2008 at 1:23pm
that's my same system except I got the 300GB Velociraptor and Razor sound card and 4-year warranty but put me just over $3300
Maybe I will get my system tomorrow, seems to take a long time to ship (from the 17th to the 23rd estimate delivery that's 7 days if you count pick-up and delivery days).
Tyler Lowe has a great build as usual, he went with the liquid cool while I opted for stage 3 with Velicoraptor.
It may be late to change your order but if not may consider TL's build you can add a sound card later if you want.
Edited by rai-zero - 22 Sep 2008 at 1:28pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Sep 2008 at 3:48pm
Well I was gonna make a setup for but first I looked at the one TL has made, and I have no changes to add to his.
I think the setup TL has for you is great.
The only thing I would change in TL's setup is to change your am from corsair to ocz, corsair has been crapping out. so here is TL's setup with the ram change:
here you go Ticket# 185797 --- Price: $2934 (To see this build click here)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 260 896MB (Includes PhysX Technology)
Internal Lighting: Blizzard Internal Lighting (Red Edition) (Cold Cathode Tubes)
I like to recommend to you to go with a 4 year warranty.
  Quote Pantalones Quote  Post ReplyReply bullet Posted: 22 Sep 2008 at 8:39pm
Alrighty, I cancelled my order (to avoid mass confusion to the guys at DSO.)
I shouldve posted here before i ordered. :/
Here is what I'm looking at now.
TN:  185971
  Quote Pantalones Quote  Post ReplyReply bullet Posted: 22 Sep 2008 at 8:43pm
I didnt do a 1:1 with the CPU and RAM.
780i doesnt support DDR3, so the highest im getting is 1066.
a 790i and 1333 RAM will push me over $3,000.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Sep 2008 at 10:12pm
sounds good man but the one TL/I build for you will oc better, higher, and more stable, also TL/my build has liquid cooling for cpu and air for the cards.
you got air trying to cool all.
its upto you ofcouse, I just want to make sure you know the difference
  Quote Pantalones Quote  Post ReplyReply bullet Posted: 22 Sep 2008 at 10:47pm
Well guys, imma cut some corners and spring for the extra bucks...  this is what I think will give me the best stability and longevity.  Thanks much DST4ME and TL.
Edited by Pantalones - 22 Sep 2008 at 10:48pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Sep 2008 at 11:22pm
ok looks good man, you gonna love that for a long while.
once thing, ask them to oc your ram, that will get you the ram fan which is great, and it will help your cpu oc better, however first go with ocz ram instead of corsair, that will save you ten
so this:
here you go Ticket# 186008 --- Price: $3201 (To see this build click here)
now this takes you to 3201, if you don't want to do that, that is ok, but then do this, when ordering ask them for the fan for the ram, which should be like $20
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 22 Sep 2008 at 11:22pm
Smokin build. I agree with DST. Get the OCZ RAM instead of the Corsair. Corasir may have a better name (arguably), but OCZ really has been the more relieable of the two recently.
