My liquid cooling purchase
Post Date: 2010-04-27
Ambidex View Drop Down
  Quote Ambidex Quote  Post ReplyReply bullet Topic: My liquid cooling purchase
    Posted: 27 Apr 2010 at 12:23pm
Ok guys I have ordered the parts. Hope they are ok!
cpu wb Swiftech Apogee GTZ Ultra extreme
gpu wb Swiftech komodo 5800
Rad Black Ice GT Stealth 360 xflow
Pump Koolance PMP-450
Fitt: compression - 6x bitpower premium compression (1/2" ID // 3/4" OD)
Fitt: barb - 4x bitspower premium black (1/2" ID)
Tube: Feser White 1/2" ID // 3/4" OD (9 feet)
liquid: Feser One F1 clear, 1 liter.
Fans: 3x NZXT FN-120 Premium 120x25 (White&Black)
reservoir: XSPC Bay 5.25" (black/silver)
clamps: 6x reusable clamps (1/2"ID, 3/4" OD) black
Cable: extension NZXT 8pin mobo cable
hope its ok :S
comments please
EVGA X58 3x SLI Classified
Sapphire HD 5870
Corsair Dominator 1600MHz 6Gb
Corsair HX 1000W
Corsair Obsidian 800D
LG LED w2486L 24" 2ms,1mill:1
Swiftech custom liquid cooling
Corsair GT 120GB
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 27 Apr 2010 at 12:36pm
i am sure it will work fine
the CPU WB is old, and performs 3-4C poorer than the new blocks
GPU water block is fine, hope you have a reference 5870, otherwise it won't fit
radiator, worst of all radiators that I know of, except for some Koolance aluminum crap, especially with the speed of fans you purchased
pump. lol is a standard D-5 but Koolance overcharges like $50.00 for it
rest is fine, although paying so much money for bottled water seems silly.
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 27 Apr 2010 at 2:52pm
Oh, I heard from people that it is a good radiator :S
Sapphire HD 5870
Corsair HX 1000W
Corsair GT 120GB
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 27 Apr 2010 at 3:21pm
Apogee XT's the newer WB, shows much better performance
Black Ice, eh, it's value stuff, I'd go with it
Liquid, eh, distilled water seems to work best for heat transfer and evaporates cleanly, premix can gum up and do some serious damage to components if it leaks...
extension what?
fan = 47 CFM @ 25 dba, horrible static pressure....man...justin, this fan has 0.95 static pressure. is this seriously gonna work at ALL with a radiator? Smile
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 27 Apr 2010 at 3:30pm
Are the fans bad as well...?
Sapphire HD 5870
Corsair HX 1000W
Corsair GT 120GB
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 27 Apr 2010 at 5:15pm
fans are normally designed to just shove air out, which is basically measured in CFM
fans that are "good" for radiators are fans that have been designed to produce a lot of suction, measured in static pressure, because the fan has to suck air from behind the radiator and pass it through it
your fans have a low static pressure rating...0.95 or so, other fans, like the Cooler Master R4-L2R series have around 3.0 or so static pressure, with lower noise o_o
in short, I dunno if those fans will work too well...gonna have to wait for justin's verdict though
Edited by ablahblah - 27 Apr 2010 at 5:15pm
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 27 Apr 2010 at 6:12pm
Well, if it is possible.
I could change the fans- they said it was ok. I paid like 50 $ more. Im getting some 200CFM fans. Now.
Is that good?
Sapphire HD 5870
Corsair HX 1000W
Corsair GT 120GB
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 27 Apr 2010 at 6:19pm
sigh...when it comes to Radiators and Heatsinks, you don't focus on CFM ratings, you focus on static pressure ratings. Higher Static Pressure or H20 or pressure ratings is better for radiators. 200 CFM fans aren't really worth it for a radiator though, it's sorta wasted money. When I was trying to do a layout of a possible LC rig for me, I used these fans :
http://www.frozencpu.com/products/9303/fan-575/Cooler_Master_R4_Series_120x25mm_Super_Silent_Fan_-_Blue_LED_-_R4-L2R-20AC-GP.html
19dba, 69 CFM, 2.93 H20 Pressure
Edited by ablahblah - 27 Apr 2010 at 6:20pm
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
