My pc won’t detect my external hard drive
Post Date: 2022-04-03
Martinguy View Drop Down
  Quote Martinguy Quote  Post ReplyReply bullet Topic: My pc won’t detect my external hard drive
    Posted: 03 Apr 2022 at 6:47pm
I just recently purchased a digital storm PC and connected my Seagate 16TB external hard drive and nothing will show up on my PC on previous PCs that I’ve used it was able to identify it right away I don’t know how to get this guy recognized
If it helps paint a more understood picture, here’s my digital storm specs
Processor: Intel Core i9-10980XE Extreme Edition (18-Core) (Boost Up to 4.6 GHz)
Motherboard: ASUS Prime X299-A II (Intel X299 Chipset) (Up to 3x PCI-E Devices) (ThunderboltEX Optional) (No SLI)
System Memory: 128GB DDR4 3200MHz HyperX Fury RGB
Power Supply: 1200W Silverstone / EVGA / Thermaltake (Modular) (80 Plus Gold)
Expansion Bay: ASUS ThunderboltEX 3 Adapter (Requires Thunderbolt Compatible Motherboard)
Optical Drive: External USB - Blu-Ray & DVD Multi-Drive (Burn + Play Blu-Ray & DVDs) (6x BD-R)
Storage Set 1: 1x SSD M.2 (1TB Digital Storm M.2 Performance Series) (NVM Express)
Storage Set 2: - No Thanks
Thanks you in advance
Edited by Martinguy - 03 Apr 2022 at 6:51pm
  Quote Snaike Quote  Post ReplyReply bullet Posted: 03 Apr 2022 at 7:44pm
Have you checked your device manager yet?
All drives should be there. If yours is there and has an orange warning sign it should lead you to the problem.
If it's not there, make sure all power leads and cables are plugged in.
Edited by Snaike - 03 Apr 2022 at 7:45pm
  Quote Martinguy Quote  Post ReplyReply bullet Posted: 03 Apr 2022 at 8:42pm
Hey Snaike, yeah I’ve checked there, uninstalled the driver that was already there, reset my comp, unplugged the external drive and replugged it in to force the drivers install.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 04 Apr 2022 at 12:30am
If the drive isn’t showing in device manager them it’s either a bad usb cable or the USB port. Try a different USB port, like a 2.0 instead of a 3.2 for example.   Lots of devices dislike 3.2 USB ports. Use a USB port on the back, directly to the motherboard and not a case front port.
Good luck.
  Quote Martinguy Quote  Post ReplyReply bullet Posted: 04 Apr 2022 at 4:19pm
Hey bprat22, yeah I just gave that a shot right now I tried USB 2 and I tried moving around to different ports to see if that would do the trick and maybe my system would recognize the hard drive and nothing I even used a different external hard drive to see if it would recognize it may be there’s something wrong with the drive or something and no dice, but I am able to connect my iPhone to the computer and it can detect it right away so there something
Edited by Martinguy - 04 Apr 2022 at 4:22pm
  Quote Cretae Quote  Post ReplyReply bullet Posted: 05 Apr 2022 at 4:01am
I think maybe this article could help you. It seems to cover all the bases, so perhaps it will have something to offer.
https://www.pcmag.com/how-to/what-to-do-when-an-external-hard-drive-wont-show-up
I've not heard of a drive so large it needs extra power, but yours is 16TB, so... maybe? Or perhaps it will show up in disk management giving you some other options.
Hope it helps.
MrCheetah View Drop Down
  Quote MrCheetah Quote  Post ReplyReply bullet Posted: 05 Apr 2022 at 5:05am
Good troubleshooting steps thus far.
My addition is:
Originally posted by urdesign
Fix 2. Assign a Drive Letter for the Drive
If the external hard drive letter is missing or is conflicted with another drive, then it will not show on your PC. You can check if the drive is assigned a drive letter in Windows Disk Management and assign or change a drive letter for it.
Press Windows + X and select Disk Management.
In Disk Management, you can see all detected disks are listed. If you see your external hard drive is listed but has no drive letter, you can right-click the drive and select Change Drive Letter and Paths.
Next, click Add button and select a drive letter for it, or click Change button to change a drive letter for the drive.
8 FIXES FOR EXTERNAL HARD DRIVE NOT SHOWING UP IN WINDOWS 10 | urdesignmag
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 05 Apr 2022 at 11:30am
My other thought is to go into Bios/UEFI and go to advanced, peripheral and make sure USB is enabled for drive detection.   Every bios is different so not sure the exact path.
Sometimes an external drive does need a power supply seperate from USB if the USB can’t supply enough juice. Probably not the case here.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 05 Apr 2022 at 2:22pm
I have an 8TB WD My Book external drive and it has its own power adapter. Make sure your is on if it has one. It will not operate otherwise.
Edited by hoserator - 05 Apr 2022 at 2:24pm
  Quote Martinguy Quote  Post ReplyReply bullet Posted: 05 Apr 2022 at 3:47pm
Thanks bprat22, MrCheeta, And Cretae for your guys tips, horserator, I had read somewhere in the forum that WD external hard drives worked just fine with digital storm PC’s and I don’t know if maybe the whole dilemma of getting the drive to work would ridiculously be up to the brand or type of drive, I don’t know, gonna try and see if anything will get these drives recognized.
And I don’t know if this is normal whenever I turn on my PC after a while it gives office burning kind of a smell. I don’t know if that’s normal I don’t know if that has anything to do with my dilemma.
Edited by Martinguy - 05 Apr 2022 at 3:50pm
  Quote Snaike Quote  Post ReplyReply bullet Posted: 05 Apr 2022 at 4:34pm
Burning smells are NEVER good. Is it a dusty smell or the magic electrical smoke? If it's dusty, when was the last time your machine got a thorough cleaning, inside and out? If it's the magic electric smoke you need to figure out where that's coming from immediately. Like my electrician friends love to say, "Once you've let the magic smoke out, nothing is going to work right."
Edited by Snaike - 05 Apr 2022 at 4:34pm
  Quote Martinguy Quote  Post ReplyReply bullet Posted: 05 Apr 2022 at 5:16pm
Oh man Snaike, i’ll check it out and see where exactly that smell is coming from but I smell it through the glass at the entrance and it just has that burning smell, I just bought/got this PC a week ago 😭
  Quote Snaike Quote  Post ReplyReply bullet Posted: 05 Apr 2022 at 5:21pm
If the machine is brand new there would be some burn in smells. However one would think that the stress testing DS does would get those mostly out. Perhaps it is just residual. Pop the covers and give everything a quick clean just to be on the safe side.   (Remember to GROUND yourself before touching sensitive parts. I keep one hand on the case and try a light touch with the other.)
With the case opened up you can get in there with your nose as well to find out where the smell is coming from.
  Quote Martinguy Quote  Post ReplyReply bullet Posted: 05 Apr 2022 at 5:26pm
Ok for sure, I have the case off as I’m typing this message and checking everything out to see where the smell is coming from.
Before when I said that the computer could recognize my iPhone now whenever I try to get the information from my iPhone off of the computer it says that there’s no files within the folder, i’m sure it has to be some kind of stupid detail that I’m missing has me going bananas trying to figure out what’s going on
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 06 Apr 2022 at 12:30am
I’m assuming iTunes is installed on your pc?   That’s the transfer medium.
For the smell, make sure your pc isn’t sitting on a rug.   A lot of pc have a fan on the bottom pushing air into the power supply.   Poor ventilation can overheat the psu.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 06 Apr 2022 at 12:57am
I don't use "smart" phones so can't even relate to phone connectivity problem.
As to the burn odor, on my system, one of the screws holding the window was rubbing the LED ribbon and finally shorted the wires inside. Sparks and smoke! I was sure it was over but no fire.There are a lot of parts in there with a lot of electrons going around so ....good luck.
BTW, the ribbon still works, It just has a brown spot in it. No leds died!
Edited by hoserator - 06 Apr 2022 at 12:59am
  Quote Martinguy Quote  Post ReplyReply bullet Posted: 08 Apr 2022 at 12:33pm
Oh whoa! Horserator, That would’ve scared the beJesus out of me!
I tried every recommendation and for some reason I don’t know why these ports are not working and if they do it’s only a temporary thing so I’m gonna call support and see what they say
  Quote hoserator Quote  Post ReplyReply bullet Posted: 08 Apr 2022 at 1:34pm
Did you try the Ext. HDD in another system to make sure it is still working?
  Quote Martinguy Quote  Post ReplyReply bullet Posted: 10 Apr 2022 at 1:15pm
Oh yeah, I had put document and files I wanted to put on the DS comp from another computer. So I know it can definitely be detected by other pcs
This page was generated in 0.140625 seconds.
