My rig and cooling question
Post Date: 2010-09-05
goodman247 View Drop Down
  Quote goodman247 Quote  Post ReplyReply bullet Topic: My rig and cooling question
    Posted: 05 Sep 2010 at 1:21am
Hi guys, I just placed my order for a new rig and I have one question, is the Noctua 120mm fans enough for my rig? Even if the processor is OC'ed?? I'm new to this so thanks for the help.
Config:
Processor: Intel Core i7 950 3.06GHz (Quad Core)
Motherboard: EVGA X58 SLI 3 Edition (Intel X58 Chipset) (Features USB 3.0 and SATA 6Gb/s) (Model: 131-GT-E767)
Hard Drive Set 1: Operating System: 1x (40GB Solid State (By: Intel) (Model: X-25V Edition) (Extreme Performance)
Hard Drive Set 2: Multimedia\Data: 1x (1TB Hitachi/Seagate (7200 RPM) (32MB Cache)
Video Card(s): 1x NVIDIA GeForce GTX 480 1.5GB (Includes PhysX Technology)
CPU Boost: FREE: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Cooling Upgrade Recommended)
Pre-Install Game: FREE: Hot-selling game with a NVIDIA GeForce GTS 250 or above graphics card
Warranty: FREE PROMO: Life-time Expert Customer Care with 4 Year Limited Warranty
dranza View Drop Down
  Quote dranza Quote  Post ReplyReply bullet Posted: 05 Sep 2010 at 1:26am
Yes the noctua is good enough for that level of OC
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 05 Sep 2010 at 1:37am
  Quote goodman247 Quote  Post ReplyReply bullet Posted: 05 Sep 2010 at 1:46am
Thank you guys for the fast reply, because I was reading through some of the guides and I was just wondering if the 120mm fans can help my processor last, because I hope to use this computer for a long while heheStrong
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 05 Sep 2010 at 6:26pm
yes, even overclocked your processor should be healthy for at least 4 years under a noctua, and you can always tune down the overclock to increase that time, or just ask DSO to not go over 3.5 (or whatever) which is still a good range
over 3.7 it becomes more about bragging than productivity, unless you are doing lots of processor specific things, like rendering movies or compiling data.. not gaming or office type work
  Quote goodman247 Quote  Post ReplyReply bullet Posted: 05 Sep 2010 at 7:35pm
I mainly use it for gaming and watch movie and other normal activities. I want to ask even when the processor is OC'ed it is still on automatic?? Meaning it will only go up when I turn on things that require higher power? Also, does the computer come with the program that I can use to tune down the OC if I choose to? Another thing I heard is in order to maintain a stable processor, keep the voltage of the cores at or under 1.2V is optimal, is there anyway that I can set the voltage of the comp so that is doesn't go over? Sorry I'm very new to this and thanks a lot for all the help
Edited by goodman247 - 05 Sep 2010 at 7:42pm
  Quote dranza Quote  Post ReplyReply bullet Posted: 05 Sep 2010 at 8:14pm
The clock speed stays at the OCed clock speed and will not go up or down. For your motherboard it will come with EVGA E-LEET program that allows you to do that.
Yes you can set the voltage the bios. I don't know about the optimal voltage since each cpu is slightly different some may require higher or lower voltage to be stable. Although if you are going to overclock the processor, depending on how much you are going to overclock it and the processor the voltage needed to be stable may be higher than 1.2V. For example my i7 930 overclocked to 3.9 need a voltage of 1.365 for it to be stable.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 05 Sep 2010 at 10:25pm
goodman dso can handle all of this for you, but you dont need your overclock tuned down when you arent using it, the idle power draw of overclocked vs not overclocked is not something to be concerned about, and you want the best power out of your build
turning up and down your overclock isnt something i'd advise, just ask that DSO overclock conservatively for you if this is a concern of yours
  Quote goodman247 Quote  Post ReplyReply bullet Posted: 06 Sep 2010 at 12:39am
Ah I see, you guys are so helpful and some times when I try to look for the answers through search engine and within the forum I don't always get the exact answers. I have full trust for DSO and I'll be super happy if my desktop can last for 4-5 years and I will definitely be buying more things from DSO for years to come hehe. I just want to say everyone here is the BEST!!!!
  Quote FrankW Quote  Post ReplyReply bullet Posted: 06 Sep 2010 at 3:44pm
I told DS I would be happy with 3.6 if it extended the life of the processor. The system came in at 3.591 and very stable. That is good enough for me.
