My System
Post Date: 2007-10-23
Steve A View Drop Down
Guest
Guest
  Quote Steve A Quote  Post ReplyReply bullet Topic: My System
    Posted: 23 Oct 2007 at 1:18pm
Hey guys, the goal was to stay under $2000, yet have a comp that will be able to play games well for up to 2 years... Came in at 1990 after lame California sales tax...8.23%... Thoughts?
Case: Digital Storm Twister PRO (Black Anodized Aluminum Finish)
Power Supply: 600W Thermaltake (SLI Compatible) (Silent PurePower Edition)
Processor: Intel Core 2 Quad Q6600 2.4GHz (1066MHz FSB) (8MB Cache)
Motherboard: nVidia 650i Core 2 Quad (By: eVGA) (nForce 650i Ultra)
Memory: 2GB DDR2 Corsair at 800MHz XMS2 (Dual Channel) (Extreme-Performance)
Floppy / Media: - No Thanks
Hard Drive 1: 250GB (Western Digital / Seagate) (16MB Cache) (7200 RPM) (SATA)
Hard Drive 2: - No Thanks
Raid Option: - No Thanks
Optical Drive 1: - No Thanks
Modem: - No Thanks
Video Card: nVidia GeForce 8800GTX 768MB (By: eVGA / Asus) (PCI-Express)
TV Tuner: - No Thanks
Sound Card: Motherboard Multi-Channel High Definition Audio (7.1 Channel)
Physics Card: - No Thanks
Cooling: Air Cooled Stage 3 (Silent Artic Cooling (TwisterBoost Overclocked)
Round Cables: - No Thanks
Windows OS: Microsoft Windows Vista Home Basic
Protection: - No Thanks
LCD Display: - No Thanks
thecomplex View Drop Down
  Quote thecomplex Quote  Post ReplyReply bullet Posted: 23 Oct 2007 at 1:43pm
Looks good. That should work for two years and be able to max most current games out. I see you've selected Stage 3 cooling - you'll get more out of the overclock if you go with the A1 revision motherboard. Will put you just over 2000 probably but won't break the bank. You can also upgrade to 1066 RAM to maximize the overclock, but that will be more expensive.
Otherwise, looks good!
Chris
(2) 150GB WD Raptor (10K RPM)
(1) 120GB Maxtor (7200RPM)
Vista Home Premium 64
bfrank2me View Drop Down
  Quote bfrank2me Quote  Post ReplyReply bullet Posted: 23 Oct 2007 at 4:35pm
Move to Oregon & save the tax?
...the first hundred years are the hardest
Kelly View Drop Down
  Quote Kelly Quote  Post ReplyReply bullet Posted: 23 Oct 2007 at 5:59pm
I concur with both replies.
Minion View Drop Down
  Quote Minion Quote  Post ReplyReply bullet Posted: 23 Oct 2007 at 6:01pm
I would pass on the case lighting and upgrade to Vista premium.
Guest
Guest
  Quote Steve A Quote  Post ReplyReply bullet Posted: 23 Oct 2007 at 7:36pm
Ahah, The Oregon thing could be a seriouse option soon enough...
Now I use a laptop with premium on it for everything but gaming, is premium worth the extra couple bucks from a purely gaming standpoint? I didnt skip it from a budget perspective... more of a keep it simple idea... less graphical gui crap to run in the background....
Am I mistaken?
commast View Drop Down
  Quote commast Quote  Post ReplyReply bullet Posted: 23 Oct 2007 at 8:09pm
Vista Premium has more features but it won't slow down your PC at all. I would go with the Premium version since it doesn't cost much more than the basic version and you'll have Media center along with other things. Your video card won't break out a sweat even when running the Aero interface. Vista premium has almost the same services running in the background as Basic and you can safely disable quite a few of these services too.
