Naveen's System Review: System Owned 6 Weeks
Post Date: 2009-12-07
Naveen View Drop Down
  Quote Naveen Quote  Post ReplyReply bullet Topic: Naveen's System Review: System Owned 6 Weeks
    Posted: 07 Dec 2009 at 2:09am
I'm not one of these people who jumps up and reviews the second I get something out of the box.  I wanted to test it and put it through it's paces.  I've never had a system built for me (not counting my C64 or various Apple IIs back in the day). I've built them all myself.  This time though I wanted liquid cooling and for my first one I wanted the pro's to do it.
I picked up one of the pre-built "can't change anything at all" deals.  Not everything is exactly what I would have picked but the price was obscenely low (relatively speaking).  Here are the specs:
Trim Accents: - No Thanks
Processor: Intel Core i7 920 2.66GHz (Quad Core) Factory Overclocked to 4.0GHz
Motherboard: EVGA X58 3X SLI (Chipset: Intel X58)
System Memory: 6GB DDR3 1600MHz Corsair/Mushkin (Digital Storm Certified) (Hand Tested)
Power Supply: 1250W Enermax Galaxy EVO (Dual/Triple/Quad SLI Compatible) (Recommended)
Card Reader: - No Thanks
Hard Drive Set 1: Operating System: 1x (1TB Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Video Card(s): 2x SLI Dual (NVIDIA GeForce GTX 295 1.792GB (Includes PhysX Technology)
Sound Card: 7.1 24-bit / 192kHz Decoding High Definition Integrated Audio
Liquid Color: Blue: Non-conductive High-Performance Fluid (Requires H20: Stage 3 Cooling Package)
CPU Boost: Yes, Factory Overclocked i7 920 from 2.66GHz to 4.0GHz with 100% Stability & Reliability
Memory Boost: - No Thanks
Windows Boost: Yes, Disable and tweak all of the non-crucial services on the operating system
Pre-Install Game: - No Thanks
LCD Display: - No Thanks
Priority Build: Ship Within 72-Hours After Order Is Successfully Processed
I order on 10/13/09 and receive the unit on 10/23/09.
Cat decided she wanted to be used for size reference.
THANKS UPS!
The smell of fresh computer.
Boxes moved.
In all it's glory.
Look ma, (almost) no cables!
The setup with my 40" Samsung LCD-LED (holy god is this screen sweet).
Okay review part:
I initially had some issues with audio (specifically the mic) locking up my system.  After a ton of poking I found some settings deep inside of the Control Panel that fixed it.  About 1/2 the programs that list what the CPU speed is say it's running at 3.8 Mhz the other 1/2 say 4.01 Mhz.  Not sure which ones are 100% correct (I've not had a ton of time to research it)
The system is an amazingly clean build and I could not even come close to how clean they built it (cables hate me with a passion).
I've had some temp issues when the room gets over 78-80F so in Summer I might need to lower the OC or run the AC.  Other than that temps have been good.  My GPU1 and GPU2 max out around 61c and GPU3 and GPU4 never go above 48c (3/4 are right next to 1/2 and block airflow).  Yes I run Quad-SLI.  The water cooling seems to be very well done and keeps things nice and cool (unless as previously stated room temps get too high).  No drips, drops or leaks.
Frame rates in most games are nuts.  In WoW I can get almost to 200 FPS in some areas.  Dalaran drops me to around 70 FPS.  Mass Effect 1 seems to be the only game so far that gets a bit choppy.  I just started playing it and need to research a bit on why this may be the case.
The only hardware glitch I can find (and I posted about it somewhere) is on the access door 2 of my 4 fans run at much lower speeds than the other 2.  I really did not pursue looking into it because the PITA factor of swapping them out would be far too high.
Packaging and documentation were top notch and I could not have asked for better.
During the ordering and after I received the system Eric helped me extensively.  Thanks again Eric!
From a raw numbers standpoint here is what I get on 3DMark06:
I was hoping for a number closer to 30k and when I have the time might try to tweak the system up a bit.
Over all I'm extremely happy with my purchase and am enjoying the system.  Hmmm did I leave anything out?
I posted this picture elsewhere but it's just too cool to not share again....  My DS system with 5 amBX systems running:
If you have any questions feel free to ask.
Intel Core i7 920 2.66GHz (OC 4.01 Ghz)
EVGA X58 3X SLI
2x EVGA GTX 295
FrostBite CPU cooling.
G19
G9x
G13
Win7 64Bit
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Dec 2009 at 10:50am
Congrats looks great
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 07 Dec 2009 at 11:52am
you are running at 4.0 Ghz.. some programs take your B-clock and use a set multi for the chip model.. you have a 920. at 190 Bclock, so they use 20 for the multi reporting 3.8Ghz.. You actually are using a 21 multi giving you an overclock of 4.0Ghz
Your 3dmark does look low.. you have quad sli enabled in the nvidia control panel?  My 2 little 4890's broke 30,000 on 3dmark06.
  Quote Naveen Quote  Post ReplyReply bullet Posted: 07 Dec 2009 at 12:21pm
yeah quad is setup.  When I OC the cards using the provided tool the number actually goes down a bit.
I work insane hours so have not had a ton of time to go through everything.
I'll take a snap shot of all the relevant programs that show setups and post them in the next few days and maybe someone can see something obvious that is causing issues.
Thanks
EVGA X58 3X SLI
2x EVGA GTX 295
G19
G9x
G13
Win7 64Bit
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 07 Dec 2009 at 12:32pm
overclocking on air is tough, they scale well  with cold, so if possible, get the room cold as you can, have the fans locked at 100%. overclock little by little, once you see the score drop, you have gone to far.. make sure you unlock the core speed from the shader clock, so  you can up them separately.
Edited by justin.kerr - 07 Dec 2009 at 12:32pm
  Quote Naveen Quote  Post ReplyReply bullet Posted: 07 Dec 2009 at 11:44pm
So.. got home from work and for fun I turn off EVGA Precision and do a 3DMark run... now this is funny:
Keep in mind, EVGA Precision was on but with all stock settings.
EVGA X58 3X SLI
2x EVGA GTX 295
G19
G9x
G13
Win7 64Bit
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 08 Dec 2009 at 9:08am
try it like i mentioned, with the GPU fans at 100%, unlink the clocks, raise core first, bring up the shader as needed, then lastly do the mem once you find the other two's max.
are your cards standard cards, or overclocked from the factory?
one GTX 295 can break 30,000 so I know you should be able to get close, 3dmark 06 scores way more than it should for fast CPU's, so that might be what will keep you just under that 30k mark.
Also make sure you have no other programs running.
bears5150 View Drop Down
  Quote bears5150 Quote  Post ReplyReply bullet Posted: 14 Dec 2009 at 1:46am
wow awesome comp I am jelos!
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 14 Dec 2009 at 10:36pm
Looks Great!!!
Congrats!!
Ermm
Sodius View Drop Down
  Quote Sodius Quote  Post ReplyReply bullet Posted: 26 Jan 2010 at 9:23am
Very sweet looking setup.
OsandmanO View Drop Down
  Quote OsandmanO Quote  Post ReplyReply bullet Posted: 28 Jan 2010 at 1:07am
Nice set up. Wish I had the $ for that monitor.
What does "EVGA Precision" do anyway? Just curious. thanks !
There will ALWAYS be room for upgrades.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 28 Jan 2010 at 12:19pm
EVGA Precision is an app that allows you to adjust gpu fans and oc gpu. MSI Afterburner tho seems to be a better app as it gives more options and works with both ati and nvidia, Precision only works with nvidia cards.
  Quote OsandmanO Quote  Post ReplyReply bullet Posted: 28 Jan 2010 at 5:36pm
Ah... cool thanks
  Quote Sodius Quote  Post ReplyReply bullet Posted: 29 Jan 2010 at 7:40pm
That monitor is cool
