Need a gaming system
Post Date: 2011-02-23
JuanOrez View Drop Down
  Quote JuanOrez Quote  Post ReplyReply bullet Topic: Need a gaming system
    Posted: 23 Feb 2011 at 5:16pm
$2500ish
I have the monitor, mouse, keyboard etc. Only need the PC.
Play MMO Rift at max settings @ 1920x1080
-Maybe Crysis etc.
100% gaming
I would like the corsair 700D chasis and stick with one video card. With the D14 cooler, can this be overclocked to stage 2 safely? I also like Corsair as a brand as I've had them in other systems with great success. However, if there are better options I'm open to suggestion.
Saved Ticket #:
489124
Any comments would be appreciated.
Edited by JuanOrez - 23 Feb 2011 at 5:41pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 23 Feb 2011 at 5:51pm
why the 700D? it does not have the best airflow.
Here you go Ticket# 489133 --- $2766 (To see this build click here)
Chassis Model: Special Deal Hot Seller - Corsair 700D
Motherboard: ASUS P8P67 (Intel P67 Chipset) (Features USB 3.0 and SATA 6Gb/s)
Hard Drive Set 1: Operating System: 1x (160GB Solid State (By: Intel) (Model: X25-M MLC Edition) (Extreme Performance)
Video Card: 1x NVIDIA GeForce GTX 570 1.2GB (Includes PhysX) (EVGA SuperClocked 012-P3-1572-AR)
Boost Processor: Stage 1: Overclock the processor between 4.0GHz to 4.7GHz (Cooling Upgrade Recommended)
Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Xtra Large)
I recommend:
Here you go Ticket# 489134 --- $2355 (To see this build click here)
based on your config, these system can't do sli, mmo does not need sli, some fps might.
Edited by DST4ME - 23 Feb 2011 at 5:52pm
solja1982 View Drop Down
  Quote solja1982 Quote  Post ReplyReply bullet Posted: 23 Feb 2011 at 7:48pm
This is essentially a mirror of the build recommendation that I got from DST, with the minor exception of the GPU, which he recommended I went with the 560 Ti instead of the 570, which I originally thought was best.
Otherwise, the build recommended looks strong from here.
  Quote JuanOrez Quote  Post ReplyReply bullet Posted: 23 Feb 2011 at 9:03pm
Thanks!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 24 Feb 2011 at 4:30am
Our pleasure and good luck
