Need advice on Good machine within budget
Post Date: 2011-10-26
Hookset View Drop Down
  Quote Hookset Quote  Post ReplyReply bullet Topic: Need advice on Good machine within budget
    Posted: 26 Oct 2011 at 7:01pm
Hey everyone, total noob here at having a machine built so please go easy on me.
Im looking to build a great gaming machine that has to stay at or under $2650.
I want to be able to play all the newest games like BF3 and the like. I also would like some of the "Wow" factor of having a machine that looks great. I love the look of the lights and liquid cool etc. I know I can't afford a monster machine so I want to be able to upgrade it as time goes on. I will need a new monitor, mouse, and keyboard but I am willing to go cheap on those to start as they are an easy upgrade and I would also like to hook it to my HDTV at times. I have another computer for our everyday use and storage so this will be a PC for gaming and online gaming almost all of the time.
I was playing around with the build and would like your thoughts.
I e-mailed an engineer about it and he only suggested changing out the led fans for 4 200mm led fans. Like I said I'm not at all good at designing one and I was sure I would have made some if not many mistakes. Here is my creation and thanks for any advice.
Ticket Number: 609647
Motherboard: ASUS Sabertooth P67 (Intel P67 Chipset) (New & Improved B3 Revision Without SATA 3G Issue)
System Memory: 8GB DDR3 2000MHz GTX-8 Digital Storm Certified Performance Series (Highly Recommended)
Expansion Bay: Internal Digital Media Card Reader (Black)
Hard Drive Set 1: Operating System: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition)
Video Card: 1x NVIDIA GeForce GTX 580 1.5GB (Includes PhysX) (Overclocked EVGA Edition)
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Red) (Up to 6 Fans)
Enhancements: Touch V12XT Aerocool Temperature Display & Fan Controller (Requires Chassis Airflow Upgrade)
Boost Processor: FREE: Overclock the processor between 3.3GHz to 3.9GHz
Install/Test Game: FREE: Battlefield 3 (Available only with Intel K Series and Extreme Edition CPUs)
Display: !PROMO BUNDLE: Acer 22 inch LCD + Logitech (Keyboard + Mouse) + Logitech Speakers
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Oct 2011 at 7:33pm
What is the native resolution of the monitor you gonna be gaming at?
Ghostsight View Drop Down
  Quote Ghostsight Quote  Post ReplyReply bullet Posted: 26 Oct 2011 at 7:35pm
Well im a noob too when it comes to this but from what they have told me so far you might want to upgrade your power supply to the 1050hx.  Also im not sure about the performace difference in upgrading to the 2000mhz ram vs the 1600 or 1800. DST4ME will know for sure.  The bigger power supply would be needed for sli if you choose to later on. Not sure if your motherboard will support sli either, but as I said others will know for sure.
  Quote Hookset Quote  Post ReplyReply bullet Posted: 26 Oct 2011 at 7:39pm
Not exactly sure as of yet. I will get the cheaper monitor for now and upgrade that in the near future. I just wanted to get one for now to use it and then use it on my other PC as soon as I get a better one.
Edited by Hookset - 26 Oct 2011 at 8:31pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Oct 2011 at 7:47pm
I can't tell you what to get, if I don't know what its gonna need to run.
you need to match gpu power with monitor otherwise you gonna endup wasting money or not having enough power.
I can tell you right now that I would not recommend that config, and that 800w is not gonna do sli 580.
don't pay twice for monitor, wait and get what you want in the meantime use the tv or something.
Edited by DST4ME - 26 Oct 2011 at 7:47pm
  Quote Hookset Quote  Post ReplyReply bullet Posted: 26 Oct 2011 at 9:14pm
Sorry. Like I said I don't know enough to design my own but I did try.
Maybe I should start all over.
Forget the rest of my post.
I obviously dont know what I'm doing.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Oct 2011 at 11:54pm
We do have to make you a new config, but first we need to know what the res of the monitor you gonna want to run is gonna be, so first decide on the monitor that you would want to upgrade to.
lets do this, how much were you expecting to spend on the monitor you would really like?
  Quote Hookset Quote  Post ReplyReply bullet Posted: 27 Oct 2011 at 12:01am
After some looking I'm thinking I want to go with a native of 1920x1080
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Oct 2011 at 12:02am
Ok great that is a start, now what was the budget for it going to be? keep in mind we are talking about the monitor you said you would eventually upgrade to.
Edited by DST4ME - 27 Oct 2011 at 12:03am
  Quote Hookset Quote  Post ReplyReply bullet Posted: 27 Oct 2011 at 12:06am
I figure somewhere around 200-250
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Oct 2011 at 12:13am
Dell UltraSharp U2311H 23
1. response time is a bs number, its there to fool you and does not represent the true response time of the monitor, there is no real way of truly finding what response time is, the closest to it is white to white but you don't see that, you see grey to grey or black to black cause they give small numbers to fool users but they don't mean anything, there are different methods to get these numbers also, and each will give a different number as results, therefore you can even compare one to the other, cause we don't know what method was used for which, and even if we did, still GTG or BTB don't mean anything.
2. contrast ratio is also bs number.
that dell monitor is an ips panel.
  Quote Hookset Quote  Post ReplyReply bullet Posted: 27 Oct 2011 at 1:03am
I like the looks of the Dell
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Oct 2011 at 1:31am
Its a great ips monitor.
now to run that monitor at max settings, for custom config its gonna be around $2800 that has ssd, sli 570 etc, or you get ode 3, which can't do what the custom config can as far as future upgrades go but as far as game performance they would be equal.
or we can build you a system for around $2100 with single 570, you add the second 570 in a few months.
let me know which you like to see/do.
Edited by DST4ME - 27 Oct 2011 at 1:32am
  Quote Hookset Quote  Post ReplyReply bullet Posted: 27 Oct 2011 at 1:53am
I think the single 570 is the way I'd like to go.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Oct 2011 at 1:59am
Without ssd $2,123, with ssd $2,399
which you want to see?
  Quote Hookset Quote  Post ReplyReply bullet Posted: 27 Oct 2011 at 2:01am
With ssd please
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Oct 2011 at 2:05am
Here you go Ticket# 609800 --- $2,399 (To see this build click here)
Video Card: 1x NVIDIA GeForce GTX 570 1.2GB (Includes PhysX Technology) (EVGA Edition)
haf 200mm non led fan
other then adding another 570 to that config, there is nothing you can do to make it better at that res, and all it needs really to be complete is a 570.
in 2 to 3 years upgrade sli 570 and it will feel like a new pc in gaming.
Edited by DST4ME - 27 Oct 2011 at 2:06am
  Quote Hookset Quote  Post ReplyReply bullet Posted: 27 Oct 2011 at 2:12am
Thank you so much DST4ME!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Oct 2011 at 2:17am
My pleasure and good luck boss
