Need advice on my first build - Velox
Post Date: 2021-10-27
AlphaFX View Drop Down
  Quote AlphaFX Quote  Post ReplyReply bullet Topic: Need advice on my first build - Velox
    Posted: 27 Oct 2021 at 4:54pm
Subtotal was 4,063, I was shooting for around 4k
I read that overclocking the cpu isn’t really necessary these days, not sure.
Processor: Intel Core i9-11900K (5.3 GHz Turbo) (16-Thread) (8-Core) 3.5 GHz (Rocket Lake)
Motherboard: ASUS Prime Z590-P / MSI Z590-A Pro (Intel Z590 Chipset) (Up to 2x PCI-E Devices) (No SLI Support)
System Memory: 32GB DDR4 3600MHz HyperX Fury RGB
Optical Drive: - No Thanks
Storage Set 1: 1x SSD M.2 (1TB Samsung 970 EVO PLUS) (NVM Express)
Storage Set 2: - No Thanks
Graphics Card(s): 1x GeForce RTX 3080 10GB (VR Ready)
Add On Card: - No Thanks
Extreme Cooling: H20: HydroLux PRO: Exotic Custom Cooling System (CPU Only)
HydroLux Fluid Color: Clear Fluid + Clear Tubing (Requires HydroLux Liquid Cooling System)
Internal Lighting: Digital Storm LED Lighting System
Software Control: - No Thanks
Recovery Tools: USB Drive - Windows 11 Installation (Format and Clean Install)
Virus Protection: Windows Defender Antivirus (Built-in to Windows 11)
Mouse Pad: - No Thanks
Branded Gear: - No Thanks
Priority Build: - No Thanks, Ship Within 14-21 Business Days After Order Is Successfully Processed
  Quote AlphaFX Quote  Post ReplyReply bullet Posted: 27 Oct 2021 at 8:11pm
Think I’m going to remove the OS boost and Overclock. The liquid cooling I definitely want for visuals.
Nomad1970 View Drop Down
  Quote Nomad1970 Quote  Post ReplyReply bullet Posted: 27 Oct 2021 at 9:09pm
Note that the processor you have is now obsolete. The I9-12900 Alder Lake is now available.
Also the RAM and motherboard need upgrades to the newer ones.
Edited by Nomad1970 - 27 Oct 2021 at 9:10pm
My Precious 2
I7-9700 oc 4.7GHz
SSD M.2 1TB Samsung 970 EVO
240GB Samsung 860 Pro SSD
1TB W.D. HD
EVGA GTX 1080Ti
MrCheetah View Drop Down
  Quote MrCheetah Quote  Post ReplyReply bullet Posted: 27 Oct 2021 at 9:13pm
Good call!
Correct -- unless you crave petty bragging rights.
CPU and motherboard manufacturers do extremely well nowadays pushing components to the (safe and reliable) limits.
To give you an idea (the rig in my signature):
UserBenchmarks: Gaming 279%, Desktop 115%, Workstation 279%
AI Overclock is set to Auto, XMP II/2.0 enabled for the RAM
In full disclosure, I don't know how their tests/algorithms work. So, I am unsure if the monitor being only 1080p (connected to a 3090) is accounted for. The monitor, noted in the benchmark report but not obvious, is an Acer ED320QR S. I haven't upgraded to a 4K model yet. It has been a difficult decision.
  Quote MrCheetah Quote  Post ReplyReply bullet Posted: 27 Oct 2021 at 9:33pm
Great spot/catch! Also good work by DS being right on top of the release.
@AlphaFX: With what @Nomad1970 said, you may want to strongly consider something such as:
Config #: 4148442
  Quote Cretae Quote  Post ReplyReply bullet Posted: 28 Oct 2021 at 3:52am
I agree wholeheartedly with my friends! Get the "instant upgrade" MrCheetah is recommending. What a break you're getting with this timing!
@Nomad: I might have taken a day or two to even notice this breakthrough. Many thanks for being on the ball, and shouting out!
  Quote hoserator Quote  Post ReplyReply bullet Posted: 28 Oct 2021 at 11:44pm
The pc makers got their supply before it comes out to the consumer. Intel is trying to make us forget the 11 series chips. We'll see how the 12s do.
areobee View Drop Down
  Quote areobee Quote  Post ReplyReply bullet Posted: 29 Oct 2021 at 10:56am
My only beef with the Velox case is the motherboard is mounted upside down because its open on the right side. Any text on items such video card will be upside-down
  Quote Cretae Quote  Post ReplyReply bullet Posted: 29 Oct 2021 at 11:10am
Not to my taste.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 29 Oct 2021 at 1:20pm
Ahh, but the heat from the gpu gets sucked up by the top fans and does not pass over the cpu! I like the upside down position.
Like Snaike always states: That's why there's vanilla and chocolate.
Smile
  Quote MrCheetah Quote  Post ReplyReply bullet Posted: 29 Oct 2021 at 2:48pm
Indeed.
Agreed, inverted/reverse ATX is the best layout for non-water cooled graphics cards. Even with OCPD, I'd be willing to deal with upside down labels/logos for the operational improvements. Some people aren't, and that's okay -- see above.
fwfdfireman View Drop Down
  Quote fwfdfireman Quote  Post ReplyReply bullet Posted: 29 Oct 2021 at 6:58pm
Love my Velox. Upside down letters on the GPU don't bother me. Runs so cool and quite. With the AIO DS dual fan water cooler for the CPU, everything runs just that much cooler.
I am sold on the Velox!
Old Gamers Never Die!
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 01 Nov 2021 at 4:54pm
fwfdfireman,
I am looking forward to my new cool running Velox to show up some day!
  Quote hoserator Quote  Post ReplyReply bullet Posted: 02 Nov 2021 at 2:12am
When the gpu(s) is(are) positioned upside down you get to see the best part of the hardware. Even on HydroCoppers you get to see through the clear water block. You'd think that the gpu mfg would put the best part on top but ....you only get to see it upside down! lol
  Quote fwfdfireman Quote  Post ReplyReply bullet Posted: 02 Nov 2021 at 6:18am
fwfdfireman,
You are going to love it!
And horserator is right, I do like the fact that I actually see the x3 fans on my GPU kick on when I am running a game.
JamesAstro View Drop Down
  Quote JamesAstro Quote  Post ReplyReply bullet Posted: 02 Nov 2021 at 10:48am
My favorite feature of the Velox is how quiet it is. It has five 140mm fans than can push high volumes of air with a low fan speed, plus one 120mm fan in the rear. I have mine set to keep the fan speeds at 800 RPM until the GPU temp exceeds 70C. It rarely hits that temperature, so the machine hardly makes any noise.
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 02 Nov 2021 at 11:38am
My 12 year old Digital Storm is in a Cooler Master HAF 932 case that always kept the old beast pretty cool. The Velox seems like it will be a cool running case too. Just need the new computer to hurry up and get here.
  Quote AlphaFX Quote  Post ReplyReply bullet Posted: 05 Nov 2021 at 1:28pm
This took me forever to make a decision. I even made it to stage 3 with my first posted build and caved. I went with the alder lake i7 and DDR5
Config #: 4148442
  Quote Cretae Quote  Post ReplyReply bullet Posted: 06 Nov 2021 at 2:14pm
