Need advice on Rig
Post Date: 2013-04-05
Mercy4Hire View Drop Down
  Quote Mercy4Hire Quote  Post ReplyReply bullet Topic: Need advice on Rig
    Posted: 05 Apr 2013 at 3:23pm
Hey all,
I am looking to get started on a rig, but this is my first time looking around for a desktop that can match my needs.
I want to spend between $800.00-$1200.00 on the Rig, does anyone have any good suggestions on the setup/price range for a rig.
I like to game, between MMORPG's-FPS's so i need something that can handle the stress load seemlessly.
Thank you for you imput and can't wait to see the advice given.
Nomad1970 View Drop Down
  Quote Nomad1970 Quote  Post ReplyReply bullet Posted: 05 Apr 2013 at 3:38pm
If you can squeeze just a little more, a Bolt level 2 might be a good choice.
My Precious 2
I7-9700 oc 4.7GHz
SSD M.2 1TB Samsung 970 EVO
240GB Samsung 860 Pro SSD
1TB W.D. HD
EVGA GTX 1080Ti
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 05 Apr 2013 at 4:21pm
I would also check out the Marauder lvl 3 for a bit more. The gtx 660ti will game real nice. You didn't mention your monitor resolution but the Marauder 3 will play most games on high to very high on a 1920x1080 resolution monitor.
Plus, with Digital Storm, you have a professionally built computer with excellant support.
Good luck.
Solidus1833 View Drop Down
  Quote Solidus1833 Quote  Post ReplyReply bullet Posted: 05 Apr 2013 at 5:32pm
if i were you and i went with the Marauder like bprat says lvl 3 is your best bet.. that 660ti card is the best all around card for great gaming. now you arnt going to max crysis 3 on that sucker but if you tweak the settings right it will handle the load just fine i think. It is a great card, i believe it is the highest selling card from nvidia for its price/performance ratio with people on tight budgets.
  Quote Mercy4Hire Quote  Post ReplyReply bullet Posted: 05 Apr 2013 at 6:21pm
Hey,
Thankyou all for the information and helpfullness, i will try to do a little research and some homework in the comparison between the different Rig's
This page was generated in 3.222656E-02 seconds.
