Need advice on two builds?
Post Date: 2013-06-05
StormChaserXX7 View Drop Down
  Quote StormChaserXX7 Quote  Post ReplyReply bullet Topic: Need advice on two builds?
    Posted: 05 Jun 2013 at 6:33pm
New here to DigitalStorm, thanks to a recommendation from a friend who loves their gaming rig purchased through this site.
After much tinkering, I have two builds in mind. I am leaning towards the Bolt config, because I'd rather not blow up my credit card more than necessary. However, I wouldn't be against investing a little more, if worth it, for the ODE config I made. Any suggestions or advice would be greatly appreciated.
836111 Bolt
Chassis Model: Special Deal Hot Seller - Pre-built Digital Storm Bolt - Level 3
Exterior Finish: Metallic Dark Grey Gunmetal Matte Finish with Black Vents and Black Stand
Motherboard: ASUS P8Z77-I Deluxe (Intel Z77 Chipset)
Power Supply: 500W Gold Plus Series Digital Storm Certified BOLT Edition (Enhanced Quiet Operation)
Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Corsair) (Model: Neutron GTX Series) (SATA 6Gbps)
Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital/Seagate (7200 RPM) (64MB Cache)
Optical Drive 1: DVD/CD 8x Multi-Drive (Writes and Reads DVDs, CDs)
Video Card(s): 1x NVIDIA GeForce GTX 780 3GB (Includes PhysX)
Extreme Cooling: High Performance Cooler with Five Heatpipes
CPU Boost: Stage 2: Overclock CPU 4.5GHz to 4.8GHz
Display: Asus 24 inch VG248QE Series (144Hz Refresh Rate) (Black) (1ms Response Time) (LED Backlight)
Keyboard: Logitech Media Combo MK200 Keyboard and Mouse
Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Extra Large)
836115 ODE
Chassis Model: Special Deal Hot Seller - SilverStone TJ09 (FREE Blue Exotic Exterior Paint Finish)
Motherboard: ASUS Sabertooth Z87 (Intel Z87 Chipset) (Features Thermal Armor and Thermal Radar)
System Memory: 16GB DDR3 1866MHz Corsair Dominator DHX (High-Performance)
Sound Card: Creative Labs Sound Blaster Recon3D Fatal1ty Professional 5.1
Chassis Airflow: Upgrade All Fans to Corsair Airflow 120mm Performance Edition (Up to 6 Fans)
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 06 Jun 2013 at 7:13am
Hi StormChaser...  Welcome to the forums.    Both are real nice builds, but for the money, the Bolt will give you pretty much the same gaming for a lot cheaper.
The advantage of build 2 is the modular power supply with 7 year warranty, newer gen cpu/mobo and the sound card and a case easier to work on.  Plus, with build # 2 you could add another card in sli if needed, but most don't.
If you don't plan on sli, don't need the sound card, and the integrated sound is very good, and don't care about the very modest 10-15% better performance with newer Haswell cpu, then go Bolt.
Tough choices, but for the money, the Bolt will give the same gaming.  But, small form factor cases do have limitations, like harder to work on, no extra Pcie slots for add-on cards.
Hope this helps and good luck. Big%20Smile
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 06 Jun 2013 at 7:23am
If the second one is suppose to be a ODE config why does it say SilverStone Tj09?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 06 Jun 2013 at 7:26am
He probably started off in ODE section and swapped cases.  Good point, though.  Not really an ODE config.   That's why I said, build # 2.  Hahaha
Edited by bprat22 - 06 Jun 2013 at 7:27am
  Quote StormChaserXX7 Quote  Post ReplyReply bullet Posted: 06 Jun 2013 at 6:51pm
Oops, I didn't realize I selected the Silverstone instead of the ODE.
In any case, thanks for the tips. I have done some more research and went over some financial things with my girlfriend....and decided to go with this as my final build (which I hope to order this month or next) :
836589
System Memory: 16GB DDR3 2133MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested)
Display: Asus 24 inch 248 Series (Widescreen) (Black) (2ms Response Time) (LED Backlight)
Edited by StormChaserXX7 - 06 Jun 2013 at 6:53pm
