Need advice on what I should get
Post Date: 2013-05-02
Bigjbrews View Drop Down
  Quote Bigjbrews Quote  Post ReplyReply bullet Topic: Need advice on what I should get
    Posted: 02 May 2013 at 12:04pm
Im looking to buy a custom desktop for my gaming needs. I currently use a gaming laptop and I fear it's on it's last leg. My budget is roughly $1000 but there is a tiny bit of room to work with. I'm mostly using it to play games online. I currently just play wow on it but I'm looking to shift from Xbox to just doing pc games. So this would be a new start and just not sure what I should be lookin for to get high- ultra settings and good framrates online. I have a good 24 inch monitor so my only needs are the desktop itself. I'm not doing anything crazy with it just music storage and playing mmos.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 02 May 2013 at 12:24pm
Hi Bigjbrews....   Welcome to the forums.
For your budget I would suggest the Vanquish level 3 .    Its gtx 650ti Boost will give you gaming on high settings for most games.    Extreme settings would be a stretch.     Some MMO s heavily populated will play real nice with an occasional lag when things get heavy but still very good gameplay.
Good luck and hope this helps.
Orange7 View Drop Down
  Quote Orange7 Quote  Post ReplyReply bullet Posted: 02 May 2013 at 2:20pm
I agree with bprat. Honestly, anything that you get from DS should be more than enough for WOW, but the performance jump between the AMD and Intel should justify the expense, especially for MMO's.
DS xm15 Stage 4
i7-3820 (2.7GHz/3.7GHz)
16GB 1600MHz DDR3
GT 630, 1GB
240GB Intel 520
