need advice pwease!!!!!
Post Date: 2012-09-02
INSjester View Drop Down
  Quote INSjester Quote  Post ReplyReply bullet Topic: need advice pwease!!!!!
    Posted: 02 Sep 2012 at 6:56am
[ey lets say 6k...but cheaper would be nicer hehe]
[4-way 2d nvidia surround..ultra-high res without a drop of fps below 30fps..on basically any game...i want a wow factor..wc for chip set, gpu, and cpu...led fans...case lighting..something that looks awsome and runs like a champ basically]
[hmmm mainly gaming mmorpg...fps...rts...rpg...1080p videos..movies...streaming content offline...download like hundreds of shows lol ..and basic internet stuff lol..nothing to grand]
[alot of storage..but set of ssd in raid 0..and ill leave rest to you guys]
Saved Ticket #: [heres one of many ive built....724761
[Chassis Model: Special Deal Hot Seller - Black OPS HailStorm Edition
System Memory: 16GB DDR3 2133MHz Corsair Dominator GT with DHX (High-Performance)
Power Supply: 1200W Corsair Pro Gold Series (CMPSU-1200AX) (Dual/Triple/Quad SLI Compatible)
Expansion Bay: - No Thanks <b></b>
Hard Drive Set 1: Operating System: 2x (120GB Solid State (By: Intel) (Model: 520 Series) <b></b>
Set 1 Raid Options: Configure HDD Set 1 to a Raid 0 Config - Stripe Performance (Requires Two HDDs)
Hard Drive Set 2: Multimedia\Data: 1x (600GB Western Digital VelociRaptor (10K RPM) (32MB Cache) (Model: WD6000HLHX) <b></b>
Hard Drive Set 3: Backup\Misc.: 1x (600GB Western Digital VelociRaptor (10K RPM) (32MB Cache) (Model: WD6000HLHX) <b></b>
Optical Drive 1: ASUS Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Model: BC-12B1ST)
Video Card: 1x NVIDIA GeForce GTX 690 4GB (Includes PhysX)
Add-on Card: - No Thanks <b></b>
Sound Card: Creative Labs Recon3D Fatal1ty Champion 5.1 (Includes Front I/O) (PCI-Express Slot Based)
Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Single Video Card & Chipset <b></b>
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Red) (Up to 6 Fans)
Internal Lighting: Internal Chassis Lighting System (White)
Enhancements: Touch V12XT Aerocool Temperature Display & Fan Controller (Requires Chassis Airflow Upgrade)
Chassis Mods: HailStorm & 950Si: Processor & Video Card Area: Drill and Mount Two Side Window 120mm Fan Blow-Holes
Noise Reduction: Noise Suppression Package Stage 2 (Optimized Airflow & Fan Speeds with Noise Dampening Material)
Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz <b></b>
Virus Protection: Trend Micro Titanium Internet Security
Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty]
thanks ahead guys/girls...will be glad to here from you =)
PANDAS will role the world!!!!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 02 Sep 2012 at 7:46am
Hi INSjester.   Welcome to the forums.
That is a awesome rig you put together.  It certainly meets the Shock and Awe factor.
If you want to save some money, and who doesn't,  I would suggest dropping the ram to the DS 16GB 1600Mhx sticks and save $166.  You'll never see the difference with the other unless you want to oc the ram , or do ram intense apps like Lightroom, video editing, etc.
Drop to Win Pro, unless you do languages or there is something unique with Ultimate you need.  Saving is another $48.
Drop the Noise reduction package for another $79 saved.  With the side window cut, the noise reduction is pointless i would think.
The added fans , cut in the side  window and Fan control aren't needed with water cooling, but if its for eye candy then why not?  Nothing wrong with a great running and looking pc if the budget allows.
Increase overclocking to stage 2.  The rig can handle it.
Seems like a ton of storage, but you know what you need.
Another $300 saving would be to go with the 3820, 4 core cpu insteaf the 6 core 3930k chip.  For gaming, the 4 core 3820 cpu is all you need.  The 3930k is usefull for the ram intense apps like I stated for the ram sticks.  Nothing wrong with the 3930k chip, just a way to save a few bucks.
Hope this helps and As-IS, the rig you put together is great.
Best of luck.  Big%20Smile
 Almost forgot. Oops   Grab the free t-shirt.   It's the law. Big%20Smile
Edited by bprat22 - 02 Sep 2012 at 7:48am
  Quote INSjester Quote  Post ReplyReply bullet Posted: 02 Sep 2012 at 7:53am
lol ...thnx for your advice bpratt
  Quote FrankW Quote  Post ReplyReply bullet Posted: 02 Sep 2012 at 9:28am
Hi INSjester,
bprat22 gave you some very good advise. His comment on the two side fans is right on. This is an option for Air cooling the GPUs. Since you are using stage 6 LC you don't need this option. It will just add more noise. With the side window there is not much noise damping they can add. If the fans are hooked up to the fan controller then you don't need DS to optimize fan speeds. Ask DS specifically if all of the fans are hooked up to the fan controller. I don't think the RAD fans are. So you will only be controlling a couple of fans, maybe?
Great build.
Edited by FrankW - 02 Sep 2012 at 9:28am
  Quote INSjester Quote  Post ReplyReply bullet Posted: 02 Sep 2012 at 10:52am
than you!!!
Orange7 View Drop Down
  Quote Orange7 Quote  Post ReplyReply bullet Posted: 02 Sep 2012 at 3:20pm
Is your signature a pun, or a misspelling?
Edited by Orange7 - 02 Sep 2012 at 3:22pm
DS xm15 Stage 4
i7-3820 (2.7GHz/3.7GHz)
16GB 1600MHz DDR3
GT 630, 1GB
240GB Intel 520
