Need Advice
Post Date: 2009-12-14
tanamerra View Drop Down
  Quote tanamerra Quote  Post ReplyReply bullet Topic: Need Advice
    Posted: 14 Dec 2009 at 10:03am
New to gaming desktops and not familiar with Digital Storm. If i order a rig with the 975 3.33 cpu and dual lATI 5870 gpu's is water cooling needed or can i get away with the upgraded air cooler? Do not plan to do any heavy over clocking.
Thanks,
Tanamerra
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Dec 2009 at 2:35pm
none of that is needed, tell me what is your budget? and what resolution will you be gaming at, and I will show what you need and what you won't see a difference from.
Edited by DST4ME - 14 Dec 2009 at 2:35pm
  Quote tanamerra Quote  Post ReplyReply bullet Posted: 14 Dec 2009 at 3:53pm
DST4ME,
Gaming at 1900X1200 most likely. Planned on the monitor that Digital Storm has on their website.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Dec 2009 at 3:57pm
ok what is the budget?
  Quote tanamerra Quote  Post ReplyReply bullet Posted: 14 Dec 2009 at 5:10pm
$5,000.00 including delivery by Christmas.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Dec 2009 at 5:51pm
LC is not a nessessity, but it does give better temps:
LC system:
Here you go Ticket# 364169 --- Price: $4438 (To see this build click here) Price after current promotion $4088
Chassis Model: Cooler Master HAF 932 (Black OPS Edition)
System Memory: 6GB DDR3 1600MHz Digital Storm Certified (Highly Recommended) (Hand Tested)
Hard Drive Set 1: Operating System: 1x (256GB Solid State (By: Corsair) (Model: CMFSSD-256D1)
Hard Drive Set 2: Multimedia\Data: 1x (1TB Seagate/Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Single Video Card
Warranty: 5 Year Platinum Care Extended Parts & Labor Warranty (Highly Recommended)
Air system:
Here you go Ticket# 364173 --- Price: $3813 (To see this build click here) Price after current promotion $3513
  Quote tanamerra Quote  Post ReplyReply bullet Posted: 14 Dec 2009 at 6:27pm
Thanks for the options but not exactly what i am want. Prefer 975 cpu, dual 5870 gpu's and duel hardrives in raid 0.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Dec 2009 at 6:37pm
these systems will be faster then 975 and they cost less.
at your resolution you are not going to know the difference between 1 x 5870 and 2 x 5870, and by that I mean I can come and take one out in the middle of the night and you would never notice the difference the next day.
you using this to play games right? if yes what games?
that corsair will beat most dual drives in raid, and you don't have to worry about data loss due to raid failure.
Edited by DST4ME - 14 Dec 2009 at 6:37pm
  Quote tanamerra Quote  Post ReplyReply bullet Posted: 14 Dec 2009 at 7:26pm
DST4ME,
Appreciate your advice. Talked to DS today and worked out the system i was looking for. Will post it and a review after arrival.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Dec 2009 at 8:06pm
My pleasure good luck
