Need advice - wireless card/usb adaptor
Post Date: 2008-10-14
intellax View Drop Down
  Quote intellax Quote  Post ReplyReply bullet Topic: Need advice - wireless card/usb adaptor
    Posted: 14 Oct 2008 at 6:36pm
Hey there DSO community!
I just ordered my new rig, found below, and need some advice.  I had originally linksys 300n wireless card in the config, but when someone from DSO called me they suggested I drop it and find it cheaper elsewhere.  But now I'm not sure which card I want and am open to any suggestions.  A lot of the cards I've been looking at apparatnly don't support 64-bit vista according to users at newegg... but reviewers are often wrong over there too.  I just need help finding a solid wireless card that supports 64 bit Vista.
So, I ask you O'great DSO community - which wireless card should I be looking at?  It does not have to be a "N" supporting card as I have not upgraded my router yet, but will in the next few months.  Also, I do not care whether it's a PCI or USB card.
Power Supply: 860W PC Power & Cooling (ESA Edition) (Dual SLI Compatible)
System Memory: 4GB DDR3 1333MHz Corsair
Hard Drive 1: 750GB Western Digital (7200 RPM) (16MB Cache) (SATA) (Extreme Speed)
Video Card(s): NVIDIA GeForce GTX 280 1GB (Includes PhysX Technology)
Modifications: NVIDIA Enthusiast System Architecture (ESA) System (Install, Test, Optimize Computer)
Memory Boost: Yes, Overclock memory timings (Includes Memory Fan Kit Installed)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Oct 2008 at 8:13pm
lol ok can I ask you to go with the green lights? you would be the first and I would love to see how it looks in green
didn't DS adivse of a router that will work on vista 64?
  Quote intellax Quote  Post ReplyReply bullet Posted: 15 Oct 2008 at 11:28am
Sorry - lol - no green lights here!  Oh and you mean wireless adapter not router right?  My router works fine :)
I didn't think to ask them when they called to discuss my order, he just said I could find a wireless card cheaper elsewhere.  So of course I went to newegg and this one seemed like a reasonable one http://www.newegg.com/Product/Product.aspx?Item=N82E16833124069&Tpk=WMP-300N but most of the comments says not 64bit compatible.  I looked around and then there were so many choices I couldn't decide on one, and a lot of comments on them say no 64 bit compatible.
After reading around, however, it seems that the one linked above is indeed 64 bit compatible, so I may just get that one if there are no better suggestions.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Oct 2008 at 4:37pm
aslong as you search for the same products that DS offers they will work with 64bit
