Need assistance with custom buildPost Date: 2010-02-13 |
Author | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
yahtzee
Newbie Joined: 13 Feb 2010 Online Status: Offline Posts: 44 |
Topic: Need assistance with custom build Posted: 13 Feb 2010 at 10:50pm |
I do not play any games on my pc. I use it for video editing and photo work in CS3 along with office apps and internet/email. I currently have a Dell P4 3ghz with 4gb of RAM. I am realizing quickly after reading about DS pc's that even though I am not a gamer it would make sense for me to consider the higher quality gained by buying from DS.
I have a few questions: 1. The opening that I store my tower in is only 17 3/4" tall. Are there any towers that are shorter than that? All I have seen is the really tall towers. 2. Would there be a noticeable difference between 6gb and 12gb of RAM? 3. I'd like to build a PC that includes: Core i7-920, 6 or 12gb of RAM, 1.5 TB HD and 1gb video card (type tbd). Anything I should be aware of or make certain is included in my build? Thanks! |
Quote Reply Posted: 14 Feb 2010 at 12:15am | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
not sure if you need 12GB for cs3 if your dell with 4GB is doing it then 6GB with this pc should be more then enough.
Here you go Ticket# 384487 --- Price: $2594 (To see this build click here) Price after current promotion $2594 Copy of Specifications: Chassis Model: Special Deal Hot Seller - Cooler Master Elite 310 Exterior Finish: - Not Available Trim Accents: - Not Available Processor: Intel Core i7 920 2.66GHz (Quad Core) Motherboard: !SALE: EVGA X58 3X SLI (Intel X58 Chipset) (Supports Triple SLI or CrossFire) System Memory: 6GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 750W Corsair TX (Dual SLI Compatible) Expansion Bay: - Not Available Hard Drive Set 1: Operating System: 1x (256GB Solid State (By: Corsair) (Model: CMFSSD-256GBG2D) Set 1 Raid Options: - Not Available Hard Drive Set 2: Multimedia\Data: 1x (1TB Seagate/Hitachi/Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme Speed) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 22x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x ATI Radeon HD 5770 1GB Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 1: Noctua Dual 120mm Fans High Performance Cooler (Compatible With ONLY i7 Processors) H20 Tube Color:- Not Available Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: - No Thanks Enhancements: - Not Available Chassis Mods: - Not Available Noise Reduction: - Not Available Boost Processor: FREE: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Requires Air Cooling Upgrade) Boost Video Card: - Not Available Boost Memory: - Not Available Boost OS: - Not Available Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based) Virus Protection: - Not Available Office: - Not Available Benchmarking: - Not Available Install/Test Game: - Not Available Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 5-10 Business Days After Order Is Successfully Processed Warranty: 3 Year Platinum Care Extended Parts & Labor Warranty you don't want a big drive for os always remember: HDD1 = fast drive: os/apps/games HDD2 = regular large drive: media/personal/work file storage Don't fill up your HDD1 more then 50%, if think you will need more room for it then pick a bigger one. if you don't like the cost of ssd then go with a veloci Edited by DST4ME - 14 Feb 2010 at 12:17am |
yahtzee
Quote Reply Posted: 14 Feb 2010 at 10:14am | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
I probably wont spend the extra cash on a SSD but thanks for clarifying how to set it up....i may just go 500gb caviar black on OS drive and 1.5TB on 2nd. How many available HD bays do I have?
Also, it seems difficult if not impossible to find measurements of the case? Any insight? |
Mekerek
Newbie Joined: 04 Feb 2010 Online Status: Offline Posts: 34 |
Quote Reply Posted: 14 Feb 2010 at 10:52am | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
yahtzee
Quote Reply Posted: 14 Feb 2010 at 12:31pm | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
where did you find that?
Herniter
Groupie Joined: 18 Oct 2009 Online Status: Offline Posts: 133 |
Quote Reply Posted: 14 Feb 2010 at 5:12pm | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
No clue but: From Newegg - http://www.newegg.com/Product/Product.aspx?Item=N82E16811119201&cm_re=cooler_master_310-_-11-119-201-_-Product
yahtzee
Quote Reply Posted: 14 Feb 2010 at 5:30pm | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Thanks....so question about the OS hard drive...it only needs to be big enough to hold the OS? Should be some performance increase by NOT installing it on a big TB drive?
Quote Reply Posted: 15 Feb 2010 at 12:40am | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
find info on case here
6 HDDS bays, go with a 1TB HDD as HDD2 then the 1.5 TB HDD don't have a great rep in the near past, not sure if all is worked out or not. as I said it needs to be big enough os that its not 50% full after you put os and whatever apps and etc you want to put on it. smaller driver is easier to scan, backup, defrag etc. if both drives have 32MB cache then you should not notice a big difference at all. Edited by DST4ME - 15 Feb 2010 at 12:40am |
yahtzee
Quote Reply Posted: 15 Feb 2010 at 10:33am | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
How does this one look?
http://www.digitalstormonline.com/comploadsaved.asp?id=384943 Edited by yahtzee - 15 Feb 2010 at 10:41am |
Quote Reply Posted: 15 Feb 2010 at 2:39pm | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
not good.
psu needs to be corsair. the micor mobo has only 3 pci lanes, with the gpu will be only 2 and it maxes out at dual sli. I love the 275 but it does not support dx11, for future games and dx11 support 5770 is better. asetek sucks, if you want go with Noctua d14 tho the u12 is great also. no point in gpu oc here, you will see no gains. you picked a 24" monitor, thats gonna have 1900 x 1200 rs, for that res you gonna want a 5870, high oc 5850, or 2 x 275 or 2 x 5770, remember one card solution is always best. in short I would not recommend that build. |
