Need Guidance for 'puter
Post Date: 2011-05-22
Roonie View Drop Down
  Quote Roonie Quote  Post ReplyReply bullet Topic: Need Guidance for 'puter
    Posted: 22 May 2011 at 11:28am
config # 546625   Need upgradability. Dell monitor (UltraSharp U2311H)and dual gpu in future
Budget $1900-2,000 Use games, online, multiplayer, music organizer and player. Plan sound card and SSd Intel 120 hard drive for oper. system in future. Want max frames per second on games and future.
Questions:- House has electronic air filter that charges air particles so all dust collects on walls, etc. I blow out enclosed case every 6 months now. IS this Still good for this build or recomendations?  -Gpu cards- How fast do you need for online gaming? -Is it the modem, computer or cable speed that holds you back or is there a place to find out the answer? Any recomendations( I Know Nothing!)
Thanks
DougIm%20with%20Stupid
  Quote Alex Quote  Post ReplyReply bullet Posted: 22 May 2011 at 8:34pm
I reviewed your configuration (http://www.digitalstormonline.com/comploadsaved.asp?id=546625) and it looks great to me. The card you have currently selected is a great mid-range performer. I was able to create ticket # 547187, by upgrading the video cards to a GTX 570 and changing the motherboard to the Sabertooth which is still great. It came out to exactly $2,000 as well.
In terms of online gaming, if you have a DSL or cable connection that is a 1MB connection, you should be perfectly fine.
zangetsu View Drop Down
  Quote zangetsu Quote  Post ReplyReply bullet Posted: 23 May 2011 at 5:01am
Alex's build is solid. You can't go wrong with that. If you could up your budget just a tad more and get the 2600k, you would be glad you did!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 23 May 2011 at 4:21pm
IMHO this is a better build, and more powerful:
Here you go Ticket# 547753 --- $2002 (To see this build click here)
Hard Drive Set 1: Operating System: 1x (1TB Western Digital Caviar (7200 RPM) (64MB Cache) (Model: Black Edition)
Extreme Cooling: AIR: Stage 1: Corsair A70 Dual 120mm Fans High Performance Cooler
Boost Processor: FREE: Overclock the processor between 3.3GHz to 3.9GHz
Ask DS specifically for this fan to be added to the side, so you endup with 3 x 200mm fans:
haf 200mm non led fan
Edited by DST4ME - 23 May 2011 at 4:21pm
