Need Help ASAP
Post Date: 2020-07-19
Srr_Superman View Drop Down
  Quote Srr_Superman Quote  Post ReplyReply bullet Topic: Need Help ASAP
    Posted: 19 Jul 2020 at 9:27am
What do yall think of this config 3259588 or 3259625 would it be great for streaming ready to place my order was just checking on input before i do
Edited by Srr_Superman - 19 Jul 2020 at 10:27am
  Quote Cretae Quote  Post ReplyReply bullet Posted: 20 Jul 2020 at 3:47am
You do not need a 10850K. You can get one if you want, but the 10700K is all you will need for many years.
The 1000W power supply is a total waste of money. You will never need that much power in this rig. The 850W, whichever brand they give you will have a better warranty. Spend that money on an NVMe SSD for your primary drive!!!!!
  Quote Srr_Superman Quote  Post ReplyReply bullet Posted: 20 Jul 2020 at 10:09am
Ok thanks alot, already placed my order using the 3259625 config.
Edited by Srr_Superman - 20 Jul 2020 at 10:17am
