Need help building a config
Post Date: 2018-11-29
gpcook View Drop Down
  Quote gpcook Quote  Post ReplyReply bullet Topic: Need help building a config
    Posted: 29 Nov 2018 at 12:03pm
$3,000
I have no idea which case, etc that I want. Lots of options!! Here’s what I have in mind for my 3rd DS system:
•     I will use my 27” 2560X1440 59HZ monitor, keyboard, mouse, 2 speakers.
•     Budget of around $3,000.
•     Would like:
o     Intel and NVIDIA. I was thinking maybe a 9600k or 9700k from browsing the forum.
o     Probably two 500g SSD and a 1TB HDD for boot drive cloning (I’ve has 2 SSD failures in the past few years).
o     Built to last for 5+ years (mine is 5.5 years old).
o     Mid-tower is probably ok. My current PC is huge and heavy.
I started to build a config but at 77 my brain was getting lost. Help would be appreciated to get me started. One case I didn’t like was the Velox, it appears to open on the right. I want the standard opening (the left side when facing the PC front).
A system for gaming with max resolutions; FPS solo and online (Arma3, Division, etc), strategy games, RPG’s, some sims. Nothing else to speak of besides email and web surfing.
Quiet. USB and headset connections preferably in front.
Saved Ticket #: none
[Please Type Here]
  Quote Cretae Quote  Post ReplyReply bullet Posted: 30 Nov 2018 at 2:03am
Welcome back gpcook. I've configured this build. It comes in right at your price point, and includes your most important features.
Digital Storm Desktop - Config ID 2122309
1
$2,972.00     $2,972.00
Processor: Intel Core i7-9700K (4.9 GHz Turbo) (8-Core) 3.6 GHz
Motherboard: MSI MPG Z390 GAMING PRO CARBON AC (Intel Z390 Chipset) (Up to 3x PCI-E Devices)
System Memory: 16GB DDR4 3000MHz Digital Storm Performance Series
Power Supply: 750W Corsair RM750x (Fully Modular)
Optical Drive: - No Thanks
Storage Set 1: 1x SSD M.2 (512GB Samsung 970 PRO) (NVM Express) (Extreme Performance)
Storage Set 2: 1x SSD M.2 (512GB Samsung 970 PRO) (NVM Express) (Extreme Performance)
Storage Set 3: 1x Storage (2TB Seagate / Toshiba)
Graphics Card(s): 1x GeForce RTX 2070 8GB (VR Ready)
Extreme Cooling: H20: Stage 2: Corsair H110i GT - 280mm Liquid CPU Cooler (Fully Sealed + No Maintenance)
Airflow Control: - No Thanks
Virus Protection: Windows Defender Antivirus (Built-in to Windows 10
Branded Gear: - No Thanks
I've cleaned up the config a little by deleting some of the unselected options.
Please note:
1. I've used higher end parts within budget. You could save $ in several places by making some trims which would not substantially reduce quality or performance. I'll point those out.
2.CPU: You could save with the i5 9600K or the i7 8700K. Either would perform well for several years to come. Strictly in gaming, you would barely know a difference.
3.The mobo is my favorite pick for features, cost, and reliability.
4.Power supply is the best pick for price/headroom. Name brand, 5 year warranty.
5.Storage: You could save a bit here without giving up much. The Samsung 970 PRO is the top choice, but you would never see much difference with the 970 EVO 500 GB. You could get the PRO for primary and back it up with the EVO for your secondary. They both carry 5 year warranties from Samsung, but the PRO is a bit more cutting edge, a little bit faster, but not really necessary for consumer uses. They are both so darn fast, you'd never notice the difference IMO.
6.GPU: The RTX 2070 is being touted as THE card for 1440p. Fact is, it will get you great frame rates in the vast majority of games, but you may have to ease back on settings a wee bit in the few which are poorly optimized. IMO, that's the price/performance standard for your need. a better choice would be a GTX 1080, but no longer available here as Nvidia sells out of inventory. With your high res, you could easily turn down some anti-aliasing if you needed to for a performance boost.
7.IDK why the larger reservoir is $10 cheaper, but I figure the more cooling real estate the better. Definitely want to stick with a Corsair AIO for reliability and that always fun-to-have 5 year warranty.
8.The Internal lighting is free. Just adds a little pizazz. Colors can change, you can pick one and stay with it, or turn it off. You can upgrade your case fans for even more pizazz, better cooling, but it's not needed. There's some purty Corsair ones on promo, and the top-end PROs are virtually silent.
9.We don't like to recommend the overclocks. My view is everything is so darn fast already, squeezing isn't necessary.
That's my take, hope it helps. I'm not the sharpest knife in the drawer, I hope my colleagues will deconstruct as needed. Or y'all come back with questions.
Edited by Cretae - 30 Nov 2018 at 2:06am
  Quote gpcook Quote  Post ReplyReply bullet Posted: 30 Nov 2018 at 10:37am
Thanks Cretae, that's a lot of great info! I will check it out in detail.
  Quote gpcook Quote  Post ReplyReply bullet Posted: 10 Dec 2018 at 9:25pm
I've taken into consideration Cratae's config and notes and modified the config a bit.
1. The 8700 CPU sounds like a good idea.
2. I want the quiet fans, would the Corsair ones on promo be good or do I need to upgrade to the PROs? Don't really care about how pretty they are.
3. I also decided to go with 970 EVOs and forget the PROs. Sounds like I won't notice the difference. Also will backup to external drives.
Build 2136234
Processor: Intel Core i7-8700K (4.7 GHz Turbo) (6-Core) 3.7 GHz
Optical Drive: External USB - DVD/CD 8x Multi-Drive (Writes and Reads DVDs, CDs)
Storage Set 1: 1x SSD M.2 (500GB Samsung 970 EVO) (NVM Express)
Storage Set 2: 1x SSD M.2 (1TB Samsung 970 EVO) (NVM Express)
Chassis Fans: Corsair ML PRO Series (High Static Pressure) (Magnetic Levitation)
  Quote hoserator Quote  Post ReplyReply bullet Posted: 11 Dec 2018 at 5:46am
Hi gpcook,
When Cretae speaks there is little to add. I can only point out that the warranty is for only 1 year parts and I prefer W10 Pro for the added ability to control certain "advancements".
Also the 9900K, 9700K and 9600K will use a solder thermal interface material.
This helps a lot in heat dissipation. The 8000s run hot! You will not have any problem with the chosen AIO but just mentioning.
Keep us posted.
Edited by hoserator - 11 Dec 2018 at 1:59pm
  Quote Cretae Quote  Post ReplyReply bullet Posted: 11 Dec 2018 at 2:46pm
Looks very good! I see you liked the PRO fans. Our fave guru, bprat22, has them and swears by them. Dead quiet.
Although hoserator is correct about the paste vs solder situation, I didn't bring it up because just 3-4 months ago the choice didn't exist. As I sit, my 8700k is maxing out at 52C on the same cooler you picked. Since 80C would be acceptable, I don't think its worth extra $.
If it bothers you, the i5 9600k is very close to the 8700k in performance for gaming and it's a soldered chip at the same price point.
I think overall, you are going to be thrilled with your new rig!
  Quote gpcook Quote  Post ReplyReply bullet Posted: 12 Dec 2018 at 1:37pm
Stage 1 overclocking is a free promotion. Should I go for it?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 12 Dec 2018 at 1:43pm
I personally wouldn’t. Not much to be gained, if anything, plus just added heat across all cores instead of the fewer that gaming uses.
It won’t hurt, so up to you.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 12 Dec 2018 at 1:44pm
With the performance you get from turbo at 4.7 at 4.6 on the first two cores of the 8700k, the overclock is not much of an enhancement. It does push temps up quite a bit on a chip some already think runs high. We haven't been recommending it here.
  Quote gpcook Quote  Post ReplyReply bullet Posted: 12 Dec 2018 at 3:35pm
ok, no overclocking.
One more thought.... I'm thinking of saving some $$$ till after the new year. Looks like the 970 EVO is just a plug-in card like a sound card rather than a "box" that I would plug a power and data cable into like I've been used to from 5 years ago. I imagine it's super easy to add a SSD later and eliminate the 2nd one in my config. Right?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 13 Dec 2018 at 6:41am
Correct.  Big%20Smile
  Quote Cretae Quote  Post ReplyReply bullet Posted: 13 Dec 2018 at 11:28am
If you're going to bring saving $ into the discussion, IMHO, an NVMe is more than you really need for storing and loading games efficiently. I wasn't going to persuade you otherwise if that's what you wanted, but a much cheaper SATA SSD would be able to serve you as your game storage. With the overall speed of everything in your system, from the CPU to RAM to GPU, SATA SSD storage would never seem slow. Because of the difference between performing multiple operations on a variety of data where an NVMe would shine, and more simply loading coded operations from a game directory, the performance would be very similar. NVMe capability is not really worth extra bucks for gaming.
If you were to opt for the 250GB Samsung EVO and the 1TB 860 EVO SATA SSD, it would save you about $150 and you'd never know the difference.
  Quote gpcook Quote  Post ReplyReply bullet Posted: 14 Dec 2018 at 11:37am
So I was looking at the 1TB 860 EVO SATA SSD and noticed only the "boxed" (don't know how else to say it) version is offered. Why isn't the version that plugs in like a M.2 offered? If I waited till later to pick up the 1TB would the 860 M.2 style work in this system?
I hope I was clear.....
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 14 Dec 2018 at 11:59am
The 860 only uses a SATA interface, even in its m.2 form factor.    DS might not have it because you can get the standard 860 evo, non m.2, plug it into a mobo SATA slot using SATA cable and save the m.2 for NVME pcie drives like the 970 that are many times faster.
Their DS m.2 is also a SATA Drive so only they can say why not the 860.
M.2 can be either a SATA or NVME. They look the same but pin layout determines which.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 14 Dec 2018 at 2:44pm
I just saw that the difference between the 1TB NVMe and the 1TB SATA "box" is just $23!? The SATA version is very expensive here, and I don't recommend you order it with your system, if you want to go that way. Are you leery of installing one yourself?
In any event, I think you might prefer to save your other M.2 mobo slot for an NVMe you might want at some future point. I wouldn't waste it on a SATA drive.
The SATA 1TB 2.5" drive is currently on sale on Amazon for a ridiculously low $147.00. Your rig will come with a power hook-up and should have an unused SATA cable as well. I just installed one of those, and I had several power hook-ups and one free SATA cable budled with the wiring tucked behind the motherboard. I bought mine last summer and paid $230 for it.
I didn't mean to complicate your life with TMI, but I just hope to help you make informed decisions.
  Quote gpcook Quote  Post ReplyReply bullet Posted: 14 Dec 2018 at 2:55pm
Outstanding! I will get the "box" version from Amazon. All these different formats were confusing me. You have cleared it up for me, I feel pretty informed now. I also ran across another version of the 860 that's a square card. Jeeez.
Thanks for the replies guys.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 15 Dec 2018 at 9:55am
Our pleasure. Glad you could sort it all out!
