Need help building a rig
Post Date: 2009-08-08
gearhead45 View Drop Down
  Quote gearhead45 Quote  Post ReplyReply bullet Topic: Need help building a rig
    Posted: 08 Aug 2009 at 8:51pm
Well I have around 1,200-1,600 to spend on a computer. My computer knowledge is somewhat lacking but I do know the basics. The games played on it will be MMO's, RPGs, and stratagy and FPS. I am unsure of the resolution needed as I don't have a monitor (suggestions would also be helpfull $200 to spend). I don't really know how overclocking works and if it is worth it. I have heard it shortens the life of CPUs. This is the rig I came up with.
Chassis Model: Antec Nine Hundred Two
System Memory: 6GB DDR3 1333MHz Digital Storm Certified by mushkin enhanced (Highly Recommended) (Hand Tested)
Power Supply: 600W Digital Storm Certified (Silent Edition Recommended)
Card Reader: - No Thanks
Video Card: 1x NVIDIA GeForce GTS 250 1GB (Includes PhysX Technology)
LCD Display: - No Thanks
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 Aug 2009 at 8:57pm
Here you go Ticket# 319051 --- Price: $1898 (To see this build click here) Price after current promotion $1798
Motherboard: XFX X58 3X SLI (Intel X58 Chipset) (Supports Triple SLI or CrossFire)
Hard Drive Set 1: Operating System: 1x (160GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Video Card: 1x NVIDIA GeForce GTX 275 896MB (Includes PhysX Technology)
Extreme Cooling: AIR: Stage 2: V8 Cooler Master High Performance Cooler (Compatible With ONLY i7 Processors)
or
Here you go Ticket# 319053 --- Price: $1795 (To see this build click here) Price after current promotion $1695
of course this one your oc might be around 3.0GHz cause you don't have a great cooler.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 Aug 2009 at 9:02pm
venom View Drop Down
  Quote venom Quote  Post ReplyReply bullet Posted: 08 Aug 2009 at 10:34pm
I would suggest not getting that XFX motherboard, it is a POS.
  Quote gearhead45 Quote  Post ReplyReply bullet Posted: 09 Aug 2009 at 2:22am
Alright thank you. Is over clocking needed for a computer of these specs. considering the prebuilt and then getting more 3g memory and a coolmaster v-8
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 Aug 2009 at 2:54am
overclocking makes the biggest difference in your PC speed.
  Quote gearhead45 Quote  Post ReplyReply bullet Posted: 10 Aug 2009 at 3:21am
So would this build be better  Of course the less money the better as I am real tight on money. I'm leaning more towards the AMD system but would like to know how these two compare.
$1,875  319419
Processor: AMD Phenom II X4 955 (3.2GHz) (Quad Core) (Black Edition) (8 MB Cache) AM3 Socket
Motherboard: Asus M4A79T Deluxe (AMD 790FX Chipset) (Socket AM3)
System Memory: 4GB DDR3 1600MHz Corsair DHX (High-Performance)
Video Card: 1x NVIDIA GeForce GTX 275 1792MB (Includes PhysX Technology)
Extreme Cooling: AIR: Stage 1: CLEARANCE HOT SELLER OCZ Vanquisher 775 CPU Fan  (Not Compatible With i7 Processors)
OR  319421  $2,095
System Memory: 6GB DDR3 1600MHz Corsair Dominator DHX (High-Performance)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 10 Aug 2009 at 3:54am
Well the 920 will perform better with 8 threads however not oced it will be slowe then the amd, the x58 will have more pci slot and room for growth down the road, and you have 6GB of ram.
in the amd system you should drop the 275 to the 896MB version, you will not notice any difference.
  Quote <8) slunK parade Quote  Post ReplyReply bullet Posted: 10 Aug 2009 at 4:53am
just close your eyes and select random parts from the list, thats the best way to doit
