Need help configuring a gaming PC.
Post Date: 2019-01-27
PcGamer5454 View Drop Down
  Quote PcGamer5454 Quote  Post ReplyReply bullet Topic: Need help configuring a gaming PC.
    Posted: 27 Jan 2019 at 1:01am
$4500
High Performance Gaming
[Please Type Here]
[Please Type Here]
Saved Ticket #: 2231471
I am looking to build a high performance gaming PC and could use some feedback on picking my components. I have some basic knowledge but could use some expert advice. Thank you in advance!
Edited by PcGamer5454 - 27 Jan 2019 at 1:02am
  Quote Snaike Quote  Post ReplyReply bullet Posted: 27 Jan 2019 at 1:39am
The Smart Guys® will be along shortly to help you get the best for your needs. I know the first question they are going to ask is resolution. What resolution will you be using for your monitor(s)?
Welcome to the forums.
  Quote PcGamer5454 Quote  Post ReplyReply bullet Posted: 27 Jan 2019 at 6:22am
lol. I am targeting 4K.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 27 Jan 2019 at 7:30am
Take a look at this.
Config ID 2231709
Go to the forum main page and click on "Load Config" in the upper right corner. Enter just the #.
This is basic, and comes in $750 under budget. The choices are for quality and 5 year warranties that come with them.
You need the 2080 Ti for best performance at 4K.
The Internal Lighting is free.
If you want to spend a little more, consider upping your primary drive to 1 TB Samsung 970 EVO. Go for 32 GB of RAM. Put something into some colorful fans if you'd like. Up your warranty.
That's about it. Your system will be a great gamer. I will never recommend custom cooling, and I don't recommend overclocking, especially on video cards (warm enough already). For the CPU, 5 Ghz on Turbo is plenty fast IMO. Keeps things simple.
Hope it helps you.
