Need help Customizing a Rig!Post Date: 2013-08-22 |
| Author | ||
Scorp
Joined: 14 Aug 2010 Online Status: Offline Posts: 98 |
Topic: Need help Customizing a Rig!Posted: 22 Aug 2013 at 7:08am |
Hello again everyone!
Three years ago, I built my first DSO rig and it was and still is a frikking monster. The thing is, I'd like a new monster as well now. I have a budget of around $3400 and I am looking for something more quiet than the rig I currently have, which is pretty much all air-cooled, the the SLI 480s housed by the HAF-X get pretty loud and obnoxious. My current pc is also a dust generator, and that's something I hope to fix with my new build. Some things to take note of / I'd like: Quiet Rig Avoid dust as much as possible Would last me 3+ years I do pretty heavy gaming, especially with the new gen of games that are coming out considering the new consoles. Here are the specifications of what I am thinking about building, but feel free to give me suggestions, that's what I'm here for! Specifications: Chassis Model: Special Deal Hot Seller - Hailstorm II Edition Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 4770K 3.50 GHz (Unlocked CPU) (Quad Core) Motherboard: ASUS Sabertooth Z87 (Intel Z87 Chipset) (Features Thermal Armor and Thermal Radar) <b></b> System Memory: 16GB DDR3 2133MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 750W Corsair CX Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (256GB Solid State (By: Samsung) (Model: 840 Pro Series) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: ASUS Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Model: BC-12B1ST) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x NVIDIA GeForce GTX 780 3GB (Includes PhysX) Add-on Card: USB 3.0 4-Port PCI Express Card Sound Card: Integrated Motherboard Audio Extreme Cooling: H20: Stage 3: Digital Storm Exotic Custom Cooling System (CPU Only) H20 Tube Color:White Tubing with High-Performance Fluid (UV Lighting Reactive) Chassis Airflow: Upgrade All Fans to Corsair Airflow 120mm Performance Edition (Up to 6 Fans) Internal Lighting: Internal Chassis Lighting System (White) Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires Pro/Deluxe/Sabertooth Motherboard) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: - No Thanks Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty Direct Load URL: http://www.digitalstormonline.com/comploadsaved.asp?id=861257 Would appreciate all the help I can get! Edited by Scorp - 22 Aug 2013 at 8:52am |
Posted: 22 Aug 2013 at 7:43am |
Hi Scorp... Real nice rig. Not much to say, except I would drop the ram to 1600Mhz. The faster ram is seldom needed and can cause overclock issues .
I would change the psu to the EVGA 750w SuperNova. A Gold psu with full modular wiring, meaning the harness stays put if the psu is changed and the EVGA has a much longer warrant, 3 years vs 10 years. If your plans are to stay with a single card, the 750 w is great . If you want the option to go sli, then up the psu. Not sure what you have for devices, but the add-on USB card might not be needed. The 900D case has 4x USB 2.0 and 2x USB 3.0 on front I/O panel and the mobo has 4x, both USB 2.0 and 3.0 on back panel. Grab the free t-shirt. You might have one from before but another is always nice. Good Luck. |
Scorp
Posted: 22 Aug 2013 at 8:01am |
Thanks bud! :D My logic behind the PSU is that my current rig uses a AX1200W corsair one which I will be switching with the PSU I have installing in this new rig. You're probably right about the Ram and the USB slots though. When it comes to the fans and cooling, do you think this build is as quiet as it could be? Also I'd like to avoid dust if at all possible...>.< |
Posted: 22 Aug 2013 at 8:10am |
That 1200 watt should do it.
Feedback from other 900D users and the Hailstorm 2 here on the forums is that the rig is quiet. I think, as-is, the cooling and fans are real nice. As far as dust.... gaming rigs with all the fans love to pick up dust. Just a fact of life for great gaming. My best advice, and what a lot of us ole' timers have done, is to keep the rig at least 2 feet off the floor, on a small desk, file cabinet, etc next to your gaming. I have cats, forced hot-air heat and dust and I get very little dust in my 600T case. The floor is where the dust, hair, etc like to linger. The floor is poular for a rig, but higher up is much better. Edit....something to ask DS via email/phone, is if the Corsair AF 120 fans on the 900D come with the stepdown adapter, a resistor pac to lower rpm if quiet is the priority. Of, course, lower rpm is less airflow, so temp checks would be good. Edited by bprat22 - 22 Aug 2013 at 8:18am |
Scorp
Posted: 22 Aug 2013 at 8:21am |
Makes sense! Thanks! I was also wondering whether I should use the given fans or somehow try to get DS to put in SP120s ? |
fstcvc
Joined: 06 Jul 2013 Online Status: Offline Posts: 2551 |
Posted: 22 Aug 2013 at 8:25am |
I agree with bprat22 on both the RAM and USB - 1600 should be fine and the included ports should be enough unless you have tons of things to plug in.
If possible, you might consider sending your PSU to DS to have them install it. If that's not possible, maybe see if they can just wire it up and test using the 1200 but not include it (may be some fees but not as much as buying a full PSU). That way all you have to do is plug and play... The 1200 is fully modular so it's at least worth asking about having this done...
Dust is tough but the 900D case has filters on the intakes so that will help some. It's impossible to keep it all out unless your working in a clean room environment.
i7 4770K @ 4.5GHz Asus Maximus VI Extreme 16GB Corsair Dominator Platinum 3xSLI EVGA SuperClocked GTX TITAN Samsung 840Pro SSD 256GB+512GB HydroLux+XSPC CPU/MoBo/GPU Liquid Cooling |
Posted: 22 Aug 2013 at 8:26am |
I believe the SP's are for rads, coolers etc with the added Static Pressure needed to force through the fins. For case fans, I'd think the AF would be better.
The added fans do come with colored rings for a real nice look, plus a quality fan. Not sure how the performance stacks up to the 900D stock fans.
Scorp
Posted: 22 Aug 2013 at 8:33am |
@fstcvc Thanks for the info! I thought about doing that, but that would mean I have a totally useless 3 year old rig perfectly fine rig just sitting there.
@bprat22 great, and you thing the cooling system I put is good enough or should I GPU cooling with it too? Also, does the H2O Stage 3 cool the chipset or just cpu? |
Posted: 22 Aug 2013 at 8:38am |
Stage 3 water is cpu only I believe. The chipset pretty much takes care of itself so no worries.
Putting the card under water isn't needed, but all depends on the budget and how much you plan to push it. If no crazy gpu oc, then air is fine. Plus, water cooling the card means more work if you add a card or need to swap it for problems or upgrade. The 900D case and the card will do just fine on air. Water cool on gpu might be a tad quieter. Card fans can be the noisiest part of a rig. Lots to ponder. Edited by bprat22 - 22 Aug 2013 at 8:42am |
Scorp
Posted: 22 Aug 2013 at 8:41am |
Great! Thanks for all the help, looks like all I need to fix right now is the USB, ram, and the shirt! ;D
fstcvc
Posted: 22 Aug 2013 at 8:43am |
Since the PSU is modular, see if DS will sell you just the wiring and mock it up using a 1200 for testing but not include the actual 1200. That way when you get it, all you have to do is install your 1200 and plug in the cables... |
Stay in touch and let us know how it goes.
Scorp
Posted: 22 Aug 2013 at 8:46am |
But I need another PSU for my current rig, that's the issue here. Would they be able to mock it up for a 1200 and use another PSU that I can easily remove? |
Posted: 22 Aug 2013 at 8:49am |
The EVGA 750 SuperNova is fully modular. You'd need to ask then if the cabling would match. If so, then go EVGA 750 and just swap out the psu's.
Let us know.
Edited by bprat22 - 22 Aug 2013 at 8:50am |
Scorp
Posted: 22 Aug 2013 at 8:51am |
Cool, yea will definitely update you once I decide what I will do. |
danjw1
Joined: 07 Jul 2013 Online Status: Offline Posts: 667 |
Posted: 22 Aug 2013 at 9:05am |
If you are looking for a very quiet system, I would suggest the Corsair Obsidian 550D, which has noise dampening material in the side panels. Cases with side windows are generally going to be noisier then solid panels.
Windows 8 for improved DirectX 11.1 performance. For just CPU liquid cooling, I would suggest stepping down to a closed loop system, so, Stage 2, instead. Custom system require regular maintenance. Edited by danjw1 - 22 Aug 2013 at 9:07am |
fstcvc
Posted: 22 Aug 2013 at 3:22pm |
Usually each PSU uses it's own cabling and it isn't recommended using anything else as it can vary from model to model or company to company. To avoid damaging anything, I wouldn't recommend it. Looks like if you plan on using 2 different PSU's you'll have to rewire both systems...
