Need Help Deciding
Post Date: 2008-08-28
Iraq Now View Drop Down
  Quote Iraq Now Quote  Post ReplyReply bullet Topic: Need Help Deciding
    Posted: 28 Aug 2008 at 12:17am
Hey guys,
I was looking over configurations, and I need help deciding on which rig I should get. I am going to use it for MMO gaming mostly, (Warhammer Online) and when Diablo 3/Fallout 3 come out for those as well.
Now, here are the specs on comp build 1.
CPU: Q9450 @2.66
MB: 750i
RAM: 2GB DDR2 @1066mhz
HDD: 500GB WD@7200 rpm
GPU: 2x 8800GT
OS: XP Pro
PSU: 750W
Now, with that hardware, and overclocked I can get it for $2096.00
Build #2
CPU: E8600 @3.33
MB: Intel P45 (1600mhz)
RAM: 2GB DDR2 @ 800mhz
HDD: 500GB @7200
GPU: GTX 280 extreme edition @700mhz
OS: Vista Ultimate 64bit
PSU: 850w
This one is not overclocked, but I get it for $1,858.00
Please, let me know which ya'll think is better.
Thanks all
Matt
"Thick as your thumb?Now, you can't do much damage with that now can you? Maybe it should have been rule of wrist instead!" Boondock Saints
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 28 Aug 2008 at 12:35am
wat resolution?
I think you have the good stuff spread across both builds =\
I'd take
Q9550 (higher multiplier and it's the same price as Q9450)
4GB DDR2 (speed.. up to u)
Radeon HD4870 (if you playing at 1900x1200+, get another.)
Vista Premium 64
750W or 850W psu.. (up to u again)
just a fyi.. warhammer online has known issues with SLI. and you seriously do want 4gb of ram for MMOs.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 28 Aug 2008 at 12:54am
Q9450 and as skyr said, go with 4GB of ram.
  Quote Iraq Now Quote  Post ReplyReply bullet Posted: 28 Aug 2008 at 1:18am
Cool thanks guys, the RAM is a easy upgrade :) Not sure if I will upgrade the vid card, I will have to see after WAR comes out (hopefully they fix the SLI issue before mid-October so when I get back to the states it works fine :)
Matt
Edited by Iraq Now - 28 Aug 2008 at 1:20am
This page was generated in 8.691406E-02 seconds.
