Need help finalizing my computer!
Post Date: 2012-10-26
Frido View Drop Down
  Quote Frido Quote  Post ReplyReply bullet Topic: Need help finalizing my computer!
    Posted: 26 Oct 2012 at 6:57pm
Budget: Less than or equal to $3,000
So i'm coming real close to making a purchase but I want to make sure the system I customized is the "best" possible configuration for my budget, both for cost and performance. The main use of this computer will be for gaming. Please tell me your opinions and whether there are important additions/deductions that should be made to the current configuration.
Cheers!
-Andy
Saved Ticket #: 743573
Specifications: ($2,986.00)
Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Corsair) (Model: Neutron GTX Series) (SATA 6Gbps)
Optical Drive 1: ASUS Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Model: BC-12B1ST)
Video Card(s): 1x NVIDIA GeForce GTX 680 2GB (Includes PhysX)
Speakers: Logitech 2.1 System (Model LS21) (Includes Subwoofer)
Keyboard: Razer Arctosa Gaming Keyboard (USB)
Mouse: Razer Deathadder (Infrared 3500 dpi) (Gaming Mouse) (USB Wired)
Warranty: Life-time Expert Customer Care with 4 Year Limited Warranty
Edited by Frido - 26 Oct 2012 at 6:59pm
caver View Drop Down
  Quote caver Quote  Post ReplyReply bullet Posted: 26 Oct 2012 at 9:02pm
Looks real good.  Only comments I would make are that I would want a 240GB ssd since 120 will fill up quick with a OS and games, but a 120 will do fine.
Same with the motherboard, I ended up going with the ASUS deluxe for that chipset rather than the Rampage, based mostly on the fact that the deluxe had some extra features and is still set up for easy overclocking, but either will be a great board.
No free T shirt?
Finally, you can request an extra fan in the comments for the HAFX that goes up top (for a total of 2 top 200mm fans) for $30.
*edit* just saw the $3000 limit.  I'd say keep the 120 SSD, get a DLX  mobo and add the fan and T shirt in that case.
Edited by caver - 26 Oct 2012 at 9:05pm
i7 3930K 3.2GHz OC
ASUS P9X79 DLX X79
32GB DDR3 1600Mhz DSC
2x 240GB Solid State
EVGA Classified GTX680 4GB
