Need help finding the perfect PC for me
Post Date: 2012-02-15
Vanchacha View Drop Down
  Quote Vanchacha Quote  Post ReplyReply bullet Topic: Need help finding the perfect PC for me
    Posted: 15 Feb 2012 at 5:44am
[$1300]
[I am a pretty avid gamer, and I am looking to play games such as Diablo 3, Guild Wars 2, Star Wars: The Old Republic, Battlefield 3, Skyrim and much more. I know with my budget, I cant really get that top of the line PC that plays everything on Ultra, but I would like a PC that can run these games smoothly. I use a single monitor, at 1600 resolution. I also need a PC as quick as possible, so factoring in the 4 day delivery would be much appreciated]
[Gaming]
[Nothing really...would just like a smooth running computer]
[ I need a PC as quick as possible, so factoring in the 4 day delivery would be much appreciated]
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 15 Feb 2012 at 7:44am
Hi Vanchacha.. welcome to the forums.
For your budget it is pretty tight and I do understand.  Take a look at this and I'll explain later
Config....655652  Cost  $1356
Chassis Model: Special Deal Hot Seller - Cooler Master CM 690 II Advanced
Processor: Intel Core i5 2500K 3.30GHz (Unlocked CPU for Extreme Overclocking) (Quad Core)
Motherboard: ASUS P8Z68-V PRO/GEN3 (Intel Z68 Chipset) (Features Intel Quick Sync Technology)
Hard Drive Set 1: Operating System: 1x (500GB Seagate Barracuda (7200 RPM) (16MB Cache) (Model: ST500DM002)
Video Card: 1x NVIDIA GeForce GTX 560 1GB (Includes PhysX Technology) (EVGA Edition)
It's the i5-2500k chip and gtx 560 graphic card, able to run most games, even BF3 on high settings smooth.  You can't max things out but you already mentioned it's not a problem.
The 690 2 Advanced case is a nice case with room on top and sides to add fans.  The front, top and back cooling fans are pretty good, not like the HafX, but within your $$$.
It has one of the best air coolers, the A70 and I overclocked the cpu to stage 1 because the cpu and A70 can handle it with no problem.  I would like to do stage 2 oc but it's all about the budget.  It isn't much more and does give you more horsepower.
You mentioned a rig to ship ASAP , so another thought would be the ODE #1 because it does have a better cpu and grapphics card and is a pre-configured system that will ship in about 3-4 days.  But is over your budget...$1539
This custom config would prbably take another few days at least to put together.
Take a look and Good luck..Big%20SmileBig%20Smile
Edited by bprat22 - 15 Feb 2012 at 9:30am
