Need help first time buyer!
Post Date: 2011-03-09
Danman96 View Drop Down
  Quote Danman96 Quote  Post ReplyReply bullet Topic: Need help first time buyer!
    Posted: 09 Mar 2011 at 8:54pm
Hi everyone, first time buyer so I need to make sure my configuration is pretty good, I've never really bought a huge gaming computer so this is my first time.
My budget is around 2,500 give or take a little, And I also I have no idea what to buy as a monitor...
I want this computer to basically run all games with ease and let me play them, my laptop can hardly run any so it'll be a big change!
I'll be using it mainly for gaming, starcraft 2, battlefield 2, etc.
No special needs unless someone can give me some good advice for some...And now the build...Also is the pre overclocking really necessary for gaming? I would like a relible computer and no failures.
http://www.digitalstormonline.com/comploadsaved.asp?id=497823
I still need a monitor, Also I was wondering if there would be a big change between the gtx 570 graphics card and the gtx 580...Thank you very much.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 Mar 2011 at 9:45pm
you build your pc around your monitor pretty much, otherwise you can endup with too much power that will not be noticed and wasted or too little power.
so lets go with monitor first, what is the budget for monitor?
  Quote Danman96 Quote  Post ReplyReply bullet Posted: 10 Mar 2011 at 7:27am
Alright, I'm not too sure, my whole budget is around 2,400-2,500 and where the computer sits right now I could pay up to around 200-300 for a good monitor.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 10 Mar 2011 at 1:36pm
here is a great one:
Dell UltraSharp U2311H 23
that is an ips panel, which means it has great picture quality.
what do you think?
  Quote Danman96 Quote  Post ReplyReply bullet Posted: 10 Mar 2011 at 3:26pm
That monitor looks really good, we will jus have to see if it will fit in with the fuget after any changes you can make to my build, so any tips on my build?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 10 Mar 2011 at 6:35pm
Well like I said, once we know the res of the monitor, we have an idea of what it takes to run certain games on them.
your build looks good, but you need to change the psu to a corsair brand, and keep in mind that you won't be able to do sli in that system, you need to change psu to 1000w corsair to do sli.
Here you go Ticket# 498387 --- $2223 (To see this build click here)
Hard Drive Set 1: Operating System: 1x (1TB Western Digital Caviar (7200 RPM) (64MB Cache) (Model: Black Edition WD1002FAEX)
Boost Processor: FREE: Overclock the processor between 3.6GHz to 3.9GHz
this has room to grow and in sli you will have pci lanes open for other pci cards.
that with the dell monitor, total comes to $2542
Edited by DST4ME - 10 Mar 2011 at 6:36pm
  Quote Danman96 Quote  Post ReplyReply bullet Posted: 10 Mar 2011 at 8:50pm
That looks really good! Should I add anything or you know? Im sorry im new to this!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Mar 2011 at 2:31am
Yes Ask DS specifically for this fan to be added to the top, so you endup with 4 x 200mm fans:
haf 200mm non led fan
  Quote Danman96 Quote  Post ReplyReply bullet Posted: 14 Mar 2011 at 4:42pm
Hey is this monitor close to that one? This one is a bit cheaper and I can pick it up at my local bestbuy...http://m.bestbuy.com/m/e/product/detail.jsp?scr=&pid=1218172811948&skuId=9777681#review-9
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 14 Mar 2011 at 5:04pm
Doubt it's IPS. TFT monitors pale in comparison to IPS.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote Danman96 Quote  Post ReplyReply bullet Posted: 14 Mar 2011 at 6:30pm
Sorry could you clear that up a little I am a real this noob about this.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Mar 2011 at 11:52pm
what do you think?
when you look at monitors, right now basically you looking at 2 types (there are more out there but for the most parts, gamers are dealing wtih these 2), TN panel and IPS panel.
look for a monitor that has the same Viewing Angle, both vertical and horizontal, and is at or above 170°, this is a sign of a quality panel on a monitor, assuring great picture quality, IPS panels are among one of those, TN panels are not, as they have lower picture quality.
The monitor you have posted is most likely a TN panel, and if you put it next to the Dell I mentioned with the IPS panel, You will clearly see the picture quality and much better it is in the Dell.
So in short the monitor you posted is nothing like the one I posted in picture quality. aka everything looks much better and cleaner and crisper on the Dell. Not all Dells, just the IPS panel ones.
Hope that helps a bit.
