Need help identifying this noise
Post Date: 2021-07-10
ArcherZ View Drop Down
  Quote ArcherZ Quote  Post ReplyReply bullet Topic: Need help identifying this noise
    Posted: 10 Jul 2021 at 6:37pm
Out of nowhere my lumos began making the noise heard in the video. I am wondering if it is a fan or maybe the AIO pump? Help is appreciated :).
https://youtu.be/pU5AC2zpsFc
MrCheetah View Drop Down
  Quote MrCheetah Quote  Post ReplyReply bullet Posted: 10 Jul 2021 at 8:28pm
Have you tried the suggestions/solutions in this thread
  Quote ArcherZ Quote  Post ReplyReply bullet Posted: 11 Jul 2021 at 5:37am
No. I will probably just open a support ticket like the guy in the post did. I definitely am not opening the back of this pc up to fix it. I bought from DS because I have zero skill in computers lol.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 13 Jul 2021 at 12:29am
Are you sure nothing is touching the blades of the top right radiator fan? It is not spinning smoothly. Doesn't sound like air in the pump system.
Keep us posted.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 13 Jul 2021 at 3:53am
hoserator may be onto something.
ealderson View Drop Down
  Quote ealderson Quote  Post ReplyReply bullet Posted: 13 Jul 2021 at 7:35am
Try cranking down the AIO pump from 100% to something lower. That's the easy way to quickly eliminate it as the source. I can't tell 100% from the video if it is the same noise as mine or not, but that fixed mine. If you open the case and hold the hoses on the AIO can you "feel" the noise/clicking/vibration in the hoses? I could with mine so that could be another possible clue.
ScuffedMcjagger View Drop Down
  Quote ScuffedMcjagger Quote  Post ReplyReply bullet Posted: 14 Jul 2021 at 8:52pm
that really sounds like something is rubbing against a fan.
  Quote ArcherZ Quote  Post ReplyReply bullet Posted: 15 Jul 2021 at 5:36am
Keep us posted.
I noticed that too but upon looking into it I didn't see any blockage. With the pc off I spun it with my hand and felt nothing hitting the blade. Luckily there has not been performance issues resulting from the noise. I have the flu right now but when I feel better I will try looking into it again though.
  Quote ArcherZ Quote  Post ReplyReply bullet Posted: 15 Jul 2021 at 5:38am
Do I need software to lower the pumps power? On my DS control board I only can control the fans.
  Quote ealderson Quote  Post ReplyReply bullet Posted: 15 Jul 2021 at 6:04am
If your mobo is controlling your AIO then you will either need to download whatever software they have for setting stuff or get into the BIOS and see if you can set it there. What brand is your mobo?
Another idea - if you don't want to mess with that you could try tilting the PC all the way sideways (the open side down - so the DS logo on the AIO faces the floor). When my AIO was making noise it completely stopped when the PC was lying on its side. Might be another way to quickly eliminate that as a possibility.
  Quote ArcherZ Quote  Post ReplyReply bullet Posted: 15 Jul 2021 at 6:26am
My mobo is MSI.
