Need help making my choice!
Post Date: 2013-11-29
Kaori View Drop Down
  Quote Kaori Quote  Post ReplyReply bullet Topic: Need help making my choice!
    Posted: 29 Nov 2013 at 6:44pm
I was wondering if someone with more knowledge about computers could lend me a hand.  I'm currently trying to decide between the Vanquish 2-3 and the Bolt 1.  My budget is around 1300 before tax and shipping and I'm trying to get the best bang for my buck.  I really like the size of the Bolt but if it's not the end of the world of the Vanquish can configure much better for the value.  Hoping to order tonight.  Thanks in advance to anyone willing to lend me a hand with this, I really appreciate it.
Budget: $1300
Usage: WoW (25 man raiding) , LoL, Diablo 3
Edited by Kaori - 29 Nov 2013 at 8:07pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 30 Nov 2013 at 3:31am
Hi Kaori... Welcome to the forums.
The Vanquish 3 will give you the same gaming performance as the Bolt level 1 for $200 less money. The Vanquish 3 also has a newer generation cpu but not really a difference you might notice.
The Bolt does give you a very good ,compact, good looking gaming rig for a bit more. They are both upgradable but the Vanquish would be easier for most to work on.   You really can't go wrong with either but the Vanquish is tough to beat for the money.
Good luck.
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 30 Nov 2013 at 7:42am
L3 Vanquish has the better specs for less money. Also will be easier to upgrade going forward...
danjw1 View Drop Down
  Quote danjw1 Quote  Post ReplyReply bullet Posted: 01 Dec 2013 at 6:52am
The L3 Vanquish is the best bang for the buck, no doubt about that.
