Need help making my system stable again...
Post Date: 2010-02-25
intellax View Drop Down
  Quote intellax Quote  Post ReplyReply bullet Topic: Need help making my system stable again...
    Posted: 25 Feb 2010 at 10:02pm
I've been banging my head against the wall for weeks... weeks... and weeks... so, time to ask for some help.   Necessary background...
 When I received my computer from DSO in October of 2008, it was OC'd to 3.54 ghz and was very stable.  I tweaked it a bit and got it to 3.83 without too much of a vcore jump, and I was happy, although I did eventually drop it back down to 3.54 ghz because I wasn't seeing much a difference anyway.  Then both of the RAM sticks went bad, and DSO sent me replacement sticks.  Ever since the memory swap, which I believe was last spring or summer, I've had nothing but problems, but I've been living with them for awhile.  After stumbling across an article on the memory I had (Corsair DDR3 @ 1333 XMS (full specs to follow), I realized that, for some reason, that this memory defaults to the incorrect voltage and timings, specifically, 7-7-7-20 @ 1.5v, instead of the rated 9-9-9-24 @ 1.7.  After changing the timings and voltage I am no longer getting memory errors, as far as I know.  But, however, my overclock was no longer stable so I set out on getting it back to stability.  (As an aside, about two weeks ago I got a second GPU and installed it in SLI... problems existed long, long before the second GPU was added, but who knows).
After fussing with it for quite a while, I reset the CMOS and started fresh, with default settings (with the exception of changing the memory timings/voltage to their proper values).  I ran MEMTEST to ensure the RAM was still good - it's passed two 8 hour sessions with no problems (each stick of the old ram failed within 20 minutes, regardless of the DIMM it was in).
I have done so much research, and have followed the guide from EVGA forum and linked by Kelly here.  Although I have yet to have it fail to POST, it either restarts within 3 seconds of ANY stress test (OCCT, Intel Burn) or freezes (80% restarts, 20% freezes).  Yet to  successfully complete a stress test of any kind since defaulting the CMOS.
All I want is to get the computer back to 3.54 ghz and stable.  It's still under warranty, but I do not believe this is hardware related (at least, not yet) so there's no reason to get DSO officially involved (although if any of them want's to chime in, that would be great :)).
Any help will be greatly appreciated.
Here are the relevant specs:
-EVGA 790i FTW mainboard
-860W PC Power & Cooling
-Intel Core 2 Quad Q9550 2.83GHz (frostbite liquid cooled)
-4GB DDR3 1333MHz Corsair XMS DHT @ 9-9-9-24, 1.7v
-2 x NVIDIA GeForce GTX 280 1GB (SLI)
-Microsoft Windows 7 Home Premium (64-Bit Edition)
And here are the current BIOS settings and the specs of my computer.  I can boot into OS, and do quite a bit actually, but restarts/freezes within seconds of any stress test.
BIOS Version: I790SZ12
**System **
CPU Freq, MHz: 2833.3 GHZ
FSB Reference Clock, MHz: 1333.3
CPU Multiplier: [8X]
PCle x16-1 & 16-2, MHz:  [100]
PCle x16-3, MHz:  [100]
SPPc->MCP Ref Clock, MHz:  [200]
nForce SPP --> nForce MCP:   [5X]
nForce SPP c-- nForce MCP:   [5X]
**Spread Spectrum**
CPU Spread Spectrum: [Disabled]
HT Spread Spectrum: [Disabled]
PCle Spread Spectrurn(SPP): [Disabled]
PCle Spread Spectrurn(MCP): [Disabled]
SATA Spread Spectrum: [Disabled]
**FSB & Memorv Config**
CPU Freq, MHz: [2833.3]
CPU Multiplier: [8.5X]
FSB - Memory Clock Mode: [unlinked]
FSB - Memory Ratio:
FSB (QDR), MHz: [1333.3]
Actual FSB (QDR), MHz: 1333
MEM (DDR),  MHz: 1333
Actual MEM (DDR), MHz: 1333
P1: [AUTO]
P2: [AUTO]
**Memory Timing Setting**
Memory Timing Setting: [manual]
tCL (CAS Latency): 9
tRCD: 9
tRP: 9
tRAS: 24
Command Per Clock: [2T]
** Advanced Memory Settings **
tRRD: [Auto]
tRC: [Auto]
tWR: [Auto]
tWTR: [Auto]
tFAW: [Auto]
tREF: [Auto]
tRFC:
**System Voltages**
CPU Core: [Auto - 1.25]
CPU FSB: [Auto - 1.1]
Memory: [1.7]
nForce SPP: [Auto - 1.3]
nForce MCP: [Auto - 1.500]
CPU PLL: [Auto - 1.5]
GTLVREF Lane 0: [Auto: -30mv]
GTLVREF Lane 1: [Auto: +10mv]
GTLVREF Lane 2: [Auto: +00mv]
GTLVREF Lane 3: [Auto: +00mv]
**CPU Configuration**
Limit CPUlD Maxval: Disabled
Intel Speedstep: Disabled
xPPM Mode: [Native]
CPU Thermal Control: [Disabled]
C1E Enhanced Halt State: [Disabled]
Execute Disable Bit: [Disabled]
Virtualization Technology: [Disabled]
CPU Core 0: [Enabled]
CPU Core 1: [Enabled]
CPU Core 2: [Enabled]
CPU Core 3: [Enabled]
Sorry about the wall'o'text, but I wanted to make sure I included everything that might be relevant.
Edited by intellax - 25 Feb 2010 at 10:03pm
  Quote intellax Quote  Post ReplyReply bullet Posted: 26 Feb 2010 at 3:16pm
Well, I've got it to complete a 5 pass test on Intel Burn without error now, by upping the DIMM voltage to 1.9v.  I then tried 1.8v, restarted after 2 passes.  Passed at 1.85v.  I'm starting to think this entire problem is the memory and it's very odd.
But first off, question: Can I safely run this memory @ 1.85v or 1.9v?  Because when set to auto, the BIOS defaults the memory to run at 1066mhz with 7-7-7-20 @ 1.5.  Now I've got it to pass the Intel Burn test at 1333 mhz with 9-9-9-25 @ 1.85v.   That is the lowest voltage I can get the system to pass ANY stress test.  Corsair has rated the memory to run at 1333 with 9-9-9-24 @ 1.7v - which plain doesn't work.
If it is safe to run this memory at 1.8-1.9v, then I can start to build the overclock again.  If not, I guess I'll have to either get some new RAM ($$) or just run it at 1066 mhz, which kinda sucks, especially since the initial memory and the replacement memory were both rated to run at 1333mhz... Though I guess if I had to get new memory I would probably get 1600 or 1800 anyways... don't really want to spend any money, though, and have these 2 sticks just be worthless :(
Any thoughts would be appreciated, and thanks for your time.
I also found out that the BIOS is outdated - I will be flashing the new BIOS (SZ17) tonight.
Edited by intellax - 26 Feb 2010 at 4:01pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 26 Feb 2010 at 4:46pm
what are your sticks rated at? it will say on the side of the RAM
  Quote intellax Quote  Post ReplyReply bullet Posted: 26 Feb 2010 at 6:20pm
1333mhz
9-9-9-24
1.70v
Also, BIOS updated.
Edited by intellax - 26 Feb 2010 at 6:32pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 26 Feb 2010 at 9:27pm
should not need to overvolt them at all, have you tried upping CPU FSB to 1.2V?
Edited by justin.kerr - 26 Feb 2010 at 9:28pm
  Quote intellax Quote  Post ReplyReply bullet Posted: 28 Feb 2010 at 1:20am
The FSB voltage defaults to 1.4 now... which is somewhat scary, but I have it stable through intel burn and one hour OCCT  @ 3.54 ghz with the ram at 1333... I really can't explain why it's working now, but whatever, I'm happy.  thanks for the replies, really appreciated.
Sort of too bad though... I had my eye on some 1800 mhz RAM, because I'm sure the CPU can go much higher with liquid cooling... maybe I'll still have to get those sticks.... :D
