need help on gaming computer (mmorpg)
Post Date: 2010-11-05
chaos01123 View Drop Down
  Quote chaos01123 Quote  Post ReplyReply bullet Topic: need help on gaming computer (mmorpg)
    Posted: 05 Nov 2010 at 12:15pm
im looking to build a gaming computer but have little to no idea how to start or a list of what things i would need to get it all up and working. my budget will be based around 1000-2000 dollars but will add on later if i have to.
heres what i need or better (if i can get better that works it'll work also)
pc (recommended)
* Dual-core processor, such as the Intel Pentium D or AMD Athlon 64 X2
* 2 GB RAM
* Multi-button mouse with scroll-wheel
* 256 MB NVIDIA® GeForce® 8600 or ATI Radeon™ HD 2600 or better
supported 3d video cards
http://us.blizzard.com/support/article.xml?locale=en_US&articleId=21085&categoryId=3720&rhtml=y
this is all i know that i need. im not the smartest when it comes to inside computers and ive been with laptops for a few years now. if someone could post some good fans and what other stuff i need to have a working gaming computer built around these specs above or better that would be great.
my brother will be in town for awhile and he is good with building computers so im going to try and learn a bit before he leaves back home. otherwise if anyone has guides to building gaming computers/computers at all that would be also great.
last thing is that when i play wow now with my toshiba laptop. it works ok/fine having all the settings tuned down. but when i log in my latency will either sometimes be 300-400 and stay like that for about 5mins and work its way down to about 100-300 depending on where im at in game.
or i get online and its about 100-200 and slowly while im playing it builds up about +20 close to every 5mins and will either sit around 200-300 latency and goes down abit and up and stays ok, or it keeps rising.
my fps is around 10 while in cities and goes up to 20-30 outside of cities. so if theres anything i can get to go with my gaming computer that will boost my fps higher and maybe get my latency to stay low that would also be great.
final thing that goes along with above is that i would like to have this gaming computer built good enough so that i can play in higher settings. along with keeping good fps and latency, but this thing isn't my highest thing i need done on my list. as long as i can play with low settings and keeps good fps and latency then great!
thats about it sorry for a huge thing to read through. just want to make sure everything is good for when im all done with this computer.
thank you for the help.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 05 Nov 2010 at 12:57pm
youre in luck theres actually a guide designed specifically for people in your place, the link to it is in my signature
the only thing ill suggest: the difference between 1000-2000+ is all the difference in the world with a gaming PC, so the better you can narrow that down, the better we can help you get the most out of your budget. the guide is completely based on price:performance, the striking point for cost effeciency is around $1600-$1850
if you dont care to read the details in the guide, you can just skip to the bottom which will explain the options in the configurator
MagiK View Drop Down
  Quote MagiK Quote  Post ReplyReply bullet Posted: 05 Nov 2010 at 1:09pm
Chaos I highly recommend Enders Buying guide, the build he has in there for roughly $1800 can't be beat on a power per buck basis.
Just in case you get confused...a direct link:
http://www.digitalstormonline.com/forums/forum_posts.asp?TID=11911#136083
Edited by MagiK - 05 Nov 2010 at 1:11pm
  Quote chaos01123 Quote  Post ReplyReply bullet Posted: 05 Nov 2010 at 2:34pm
thank you guys i haven't read through all of this guide yet but just by the looks at the moment im liking this set up.
http://www.digitalstormonline.com/comploadsaved.asp?id=438562
now does this mean i can easily build my pc by filling in these parts i want and they will do the building of the pc for me and ship it out? or would i have to work on building the pc when the parts get here?
cause depending on prices to let them build it and just ship it aren't that bad i would rather do that over me trying to build it.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 05 Nov 2010 at 2:57pm
looks great so far
and it looks like the 920 is back! good way to save some coin!
(no it is no different from the 950)
as far as building/whatever... when you recieve the order it will be fully built, tested, everything installed and updated (except windows updates)
you take it out of the box, remove the foam from the inside the case, hook up your mouse/keyboard/monitor (not included), plug it in with the power cable(is included), and you are up and running, no assembly required
Harrigan View Drop Down
  Quote Harrigan Quote  Post ReplyReply bullet Posted: 05 Nov 2010 at 4:07pm
Another thing that wasn't mentioned was your latency, which is not controlled by your computer. Your internet service provider determines your latency, and since you have been on a laptop, have you been using wireless internet? If so, that is probably the cause of your bad latency. When you get your new computer, make sure to plug your computer directly into your modem/router to see a latency decrease.
Kaleliar View Drop Down
  Quote Kaleliar Quote  Post ReplyReply bullet Posted: 06 Nov 2010 at 5:24pm
Ok first off, lets start with resolution. What screen size? thats most important.
second for latency issues are you using a router?
http://www.wowwiki.com/US_realm_list_by_datacenter that will tell you where your realm is located physically in the US.  if you can, try to be in a realm that is close by.
A i7 has config file tweaks you can use to get it to use 4 of the cores (says all 8 but really doesnt work)
Rock: "We're sub-standard DPS. Nerf Paper, Scissors are fine."
Paper: "OMG, WTF, Scissors!"
Scissors: "Rock is OP and Paper are QQers. We need PvP buffs."
