Need help on new PC build
Post Date: 2009-08-03
edistoriverrat View Drop Down
  Quote edistoriverrat Quote  Post ReplyReply bullet Topic: Need help on new PC build
    Posted: 03 Aug 2009 at 11:09pm
I am looking to build a pc to these specs.  I do a lot of storage, movies, music, and pics, and a lot of gaming so I needed a pc to cover all areas.  Am I working on overkill or will this setup give me the guts I need and still perform?  Any advice will be helpful. Like whats not going to work with what etc.
Exterior Finish: - EXOTIC StormBlue High-Gloss Automotive Paint Finish
Interior Finish: - EXOTIC StormBlue High-Gloss Automotive Paint Finish
Trim Accents: Paint All Trim Accents: Chassis Vents, Grills, Screws, and Hose Clamps (Red)
Processor: Intel Core i7 Extreme Edition 975 3.33GHz (Quad Core) (Extreme Performance)
Motherboard: EVGA X58 Classified 3X SLI (Intel X58 Chipset) (Supports Triple SLI or CrossFire)
System Memory: 12GB DDR3 1600MHz Digital Storm Certified by mushkin enhanced (Highly Recommended) (Hand Tested)
Power Supply: 1200W PC Power & Cooling (Dual/Triple/Quad SLI Compatible) (Recommended)
Card Reader: External USB Digital Media Card Reader (Black)
Hard Drive Set 1: Operating System: 2x (2TB Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Hard Drive Set 2: Multimedia\Data: 2x (2TB Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Hard Drive Set 3: Backup\Misc.: 2x (2TB Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Optical Drive 2: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) (LightScribe Edition)
Video Card: 2x SLI Quad (NVIDIA GeForce GTX 295 1.792GB) (Includes PhysX Technology)
Add-on Card: Pinnacle PCTV USB HD Pro Stick (HDTV, Video Recording, Video Capture)
Sound Card: Creative Labs X-Fi Titanium Fatal1ty Champion (Includes Front I/O) (PCI-Express Slot Based)
Extreme Cooling: AIR: Stage 2: V8 Cooler Master High Performance Cooler (Compatible With ONLY i7 Processors)
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Blue)
Enhancements: LCD NZXT Sentry LX Temperature Display & Fan Controller (Requires Chassis Airflow Upgrade)
Windows OS: Microsoft Windows XP Home (Includes Service Pack 3) 32-Bit Edition
Benchmarking: 3D Mark Vantage Advanced Edition (By: Futuremark) (Pre-Install) (Vista Compatible Only)
Install/Test Game: Call of Duty: World (Pre-Install, apply updates, and test gameplay with my syste
LCD Display: Samsung 24 inch (Widescreen) (Black) (High-Performance Gaming Display)
Surge Shield: PC Power & Cooling 1500VA Uninterruptible Backup Surge Conditioner
Speakers: Razer Mako THX Advanced Speaker System (2.1 System) (Includes Subwoofer)
Keyboard: Microsoft Multimedia Desktop 3.0 (Multimedia Keyboard + Optical Wheel Mouse)
Mouse: Razer DeathAdder Gaming Mouse (High-Speed Gaming Grade)
External Storage: Corsair 32GB Flash Survivor Ultra Rugged USB 2.0 Drive
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 03 Aug 2009 at 11:12pm
You need a 64-bit operating system to utilize more than 4GB of ram. Go with Windows Vista 64-bit and you'll be able to upgrade to Windows 7 when it is released in October.
You don't need 2x GTX 295 when you are only going to be gaming on a 24" monitor. 2x GTX 275 would be more appropriate.
12gb of ram might also be a bit much unless you do some serious video / photo editing. I'd stick to 6GB and add some more later if needed.
Edited by skyR - 03 Aug 2009 at 11:13pm
Kryhavoc View Drop Down
  Quote Kryhavoc Quote  Post ReplyReply bullet Posted: 03 Aug 2009 at 11:28pm
GOOD FRICKIN' LORD!
I don't even know where to begin...
I can't wait for DST4ME to see this.
To save him time, you are definite set on 24" monitor, cause with some cost savings of some of the stuff you can cut out, you could get a 30" monitor.  Not sure why you are going with Windows XP with all that, Windows Vista 64-bit is what you would need.
Are you into serious heavy video editing or something, otherwise your are going way overboard.
Your hard drives are gonna be killer on your work times for seek times and other stuff like defragging.  I believe DST4ME can post a link on how to create your own portable hard drive for a lot cheaper and unless you are doing major video editing, you could get by a lot better with using the portable storage to keep stuff off your main hard drives until you needed.
Last info needed is your budget that you are willing to spend.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 04 Aug 2009 at 12:03am
what is your ticket number?
do you need a tv card?
do you need a bluray?
do you need a Backup Surge Conditioner?
do you need the benchmark software?
do you need the External Storage?
do you need 4TB of storage? how much files total do you have now?
We would say overkill but that would be an understatement
Edited by DST4ME - 04 Aug 2009 at 12:03am
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 04 Aug 2009 at 12:33am
You got to get the t-shirt!!! It was the best thing in the box!!  I wear mine as often as I can.  The computer was great and the t-shirt proves that you have the best PC that money can buy!!!!
Thumbs%20Up
Zardoz8719 View Drop Down
  Quote Zardoz8719 Quote  Post ReplyReply bullet Posted: 04 Aug 2009 at 6:30am
Kryhavoc says he doesn't know where to begin...I think the starting point might be getting that 2nd mortgage approved Clap to pay for this puppy.  And I gotta agree with Onkel_Ken...after getting everything but the kitchen sink...the last line for t-shirts should have said "yes" too Angry
Please to take "no offense" we're with you--not against you...  And if I haven't mentioned it yet--welcome aboard, glad to have you.  It's just that you brought a smile to a couple of our faces...remembering the thrill of wanting it all--and getting it delivered too.
DST4Me will help you work out the kinks...and (minor) areas of overkill...and when you're done you'll have a lean, mean, machine--and enough money left over for that 30"+ monitor that Kryhavoc mentions.    Ermm
  Quote edistoriverrat Quote  Post ReplyReply bullet Posted: 04 Aug 2009 at 7:27am
OK,               Ticket Number: 316849
TV card,
Blue Ray
Surge Conditioner
Benchmark Software
External Storage
I guess can go, I was kinda just trying to cover all bases, Although I did want to have a second optical drive as backup.
As for the storage space, I have leftover harddrives laying around that are full of pics, videos, movies etc.  I seem to never have enough space, and yes I know I was going overboard on the storage, but I wanted that jump anyway.  I figured tuck it all in the pc.
If thats too much on the pc, I am open for suggestions
A 30 " monitor, I wanted but was not too sure my eyes could adjust from this thing I now have.
Oh,   Windows Vista,  for what I now have SUCKS,  I have a few Norton products that are ( govt.  issue ) and would not work on Vista, no program upgrades avaliable to me now.  I don't want to part with them.  If I thought they would work on Windows 7, I might would give up Win XP.  Guess I will anyway if I really need to.  What are your thoughts on this.
By the way, Thanks to everyone now for your input.  It all helps.  This is a big leap for me, and yes, in the end I will order the shirt too,
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 04 Aug 2009 at 1:12pm
edistoriverrat there is nothing wrong with vista, if you need help to find your way around it we can help you but there is nothing wrong with vista, also like to pointout to you that norton is not one of the best av's around but even tho it works on vista perfectly, you just need the version that works on vita 64bit.
if you are going to get xp then you may as well not get this pc cause you will not be able to use all of the resources of this pc with xp, it can't see and use no more the 4GB of total ram., the gpus we give will have close to 3GB of ram alone, you will be left to operate with 1GB of ram for everything else, which basically means your pc will not be able to do nothing.
get yourself one of those 3 or 4 slot external enclosure and put 4TB of HDD in there and put all the stuff you have laying around in those.
so you said you wanted a 30" monitor then here is a system that will run a 30" for you in gaming:
Here you go Ticket# 317163 --- Price: $6821 (To see this build click here) Price after current promotion $6321
System Memory: 6GB DDR3 1866MHz Digital Storm Certified by mushkin enhanced (Highly Recommended) (Hand Tested)
Hard Drive Set 1: Operating System: 1x (128GB Solid State (By: Corsair) (Model: CMFSSD-128GBG2D)
Optical Drive 1: Blu-Ray Writer/Reader (Burn Blu-Ray discs and play them)
Video Card: 3x SLI Triple (NVIDIA GeForce GTX 275 896MB (Includes PhysX Technology)
Extreme Cooling: H20: Stage 3: Specialized FrostBite Separate Dual Loop System for CPU & Three Video Cards
Liquid Color:UV Redish Pink: Medium Glowing Non-conductive Fluid (Requires H20: Stage 3 & UV Lighting)
LCD Display: - No Thanks
Warranty: 5 Year Platinum Care Extended Parts & Labor Warranty (Highly Recommended)
if you are going to go with a 24" insead of a 30" then you need to tell me so I can adjust a few things.
this system cost less then your config but will eat your config up
Edited by DST4ME - 04 Aug 2009 at 1:12pm
