Need help on rig
Post Date: 2008-10-12
Slater View Drop Down
  Quote Slater Quote  Post ReplyReply bullet Topic: Need help on rig
    Posted: 12 Oct 2008 at 7:24pm
Ticket Number: 194111
Total Price with Instant Savings: $4,212.00
Processor: Intel Core 2 Quad Q9650 3.0GHz (1333MHz FSB) (12MB Cache)
System Memory: 4GB DDR3 1600MHz OCZ Platinum Edition
Card Reader: - No Thanks
Hard Drive 2: - No Thanks
Raid Option: - No Thanks
Hard Drive 3: - No Thanks
Video Card: ATI Radeon HD 4870X2 2GB
TV Tuner: - No Thanks
Sound Card: Creative Sound Blaster X-Fi XtremeGamer (CLEARANCE PRICED)
Modifications: - No Thanks
Windows
OS: Microsoft Windows Vista Ultimate (64-Bit Edition) (For Enthusiasts)
Protection: - No Thanks
LCD Display: Samsung 24 inch (Widescreen) (Black) (High-Performance Gaming Display)
I have a few questions. I see a lot of recommendations for the gtx 280 / 260 after some research for a great graphic card on a 1900x1200 resolution the 4870x2 seems to be what a lot recommend.
Is the XtremeGamer sound card that big of a deal or is integrated fine?
Lastly how well would a  Q9650 be overclocked with liquid cooled CPU? Not overclocked by me by the person who builds it.
I have never bought a custom built PC before and compared to Alienware  you guys seem a lot better quality. If I was to buy this PC should I expect very high quality performance?
  Quote Slater Quote  Post ReplyReply bullet Posted: 12 Oct 2008 at 7:29pm
I also meant to ask does that monitor look like a good choice? I am just full of stupid questions Ying%20Yang
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 12 Oct 2008 at 7:30pm
Alienware is not even comparable with DS.
with DS everything is the same thing you would buy if you were to build the pc yourself.
So you should expect much better quality, customer svc, tech support, better pc.
here you go Ticket# 194120 --- Price: $3491 (To see this build click here)
Motherboard: Asus P5E3 Premium WiFi-AP (Intel X48 Chipset) (Supports CrossFire)
LCD Display: - No Thanks
sli boards support only nvidia, you had the 790i with the 4870x2, if you plan on going crossfire down the road, then you can't use a sli mombo, if you are not gonn go crossfire ever, then you can use the 790i.
you can OC with air, but all the systems I have seen here at DS, all the liquid cooled systems had higher OC speeds.
with air you can expect 3.4 to 3.6GHz oc speed
with liquid you can expect 3.8 to 4.0GHz oc speed
if sound is not important to you, the intergrated will be fine.
Edited by DST4ME - 12 Oct 2008 at 7:33pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 12 Oct 2008 at 7:32pm
monitor is good but check newegg and see if you can do better in price/monitor
there are no stupid questions, ask away
  Quote Slater Quote  Post ReplyReply bullet Posted: 12 Oct 2008 at 7:35pm
Thanks I was hoping you would reply. I have seen you help many other people in other threads. What kind of monitor would you recommend? I am looking for at least a 24 inch. I would like to get some information before I run off and buy a monitor Ouch
Also is that motherboard good? Geek
Edited by Slater - 12 Oct 2008 at 7:40pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 12 Oct 2008 at 7:41pm
I'm not that good in moniters, but skyR one of our mods seems to be the expert, her has a post here, http://www.digitalstormonline.com/forums/forum_posts.asp?TID=3980
see if that helps
its been my pleasure to have helped you.
anyother questions you have let me know
  Quote Slater Quote  Post ReplyReply bullet Posted: 12 Oct 2008 at 7:47pm
I thought the 1600MHz was the best for overclocking you replaced it with a 1333?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 12 Oct 2008 at 7:55pm
yes we have a discussion about it here:
http://www.digitalstormonline.com/forums/forum_posts.asp?TID=4213
also look at the charts in there and you wills there is very little gain vs price to go with 1600MHz.
check it out and you will see, specially look at the charts listed and compare 4GB of 1600MHz ram with 4GB of 1333MHz ram. then fi the extra $200 is worth going with 1600MHz then go for it, I don't see it and your OC won't change much if any between 1600 and 1333.
but like I said look at the info in that thread, this is something you need to decide for yourself
Edited by DST4ME - 12 Oct 2008 at 7:55pm
  Quote Slater Quote  Post ReplyReply bullet Posted: 13 Oct 2008 at 12:28am
On your build you put vista home premium, is that better than ultimate?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Oct 2008 at 12:31am
Yes in a gain vs price aspect.
in short go here and look at see if there is anything ultimate can do that is worth the extra money
BTW I forget to say that its an honor that you were hopping I would respond, that makes me feel great thank you
Edited by DST4ME - 13 Oct 2008 at 12:33am
  Quote Slater Quote  Post ReplyReply bullet Posted: 13 Oct 2008 at 12:37am
I feel honored that you did not tell me to crawl back into my cave with windows 98 Smile
So all ultimate has is a bunch of back up additions?
Edited by Slater - 13 Oct 2008 at 12:39am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Oct 2008 at 12:39am
what are you talking about, I got dell gen 3 and gen 4 sitting here from 2003, what business would I have to tell you that
pgarthw8 View Drop Down
  Quote pgarthw8 Quote  Post ReplyReply bullet Posted: 13 Oct 2008 at 9:02am
Vista Ultimate has a few extra bells and whistles.  I ordered it with mine because I want to be able to connect to my home PC while at work (hehehe), go to the Microsoft site they have it all broken down.  To me and what I need it for, it is worth the extra $$.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Oct 2008 at 9:25am
remote access is the only thing, the rest of the stuff you can do with freewares.
I mean including the remote connect, there is only 4 things different.
1. Protect against hardware failure...
this is just backup, this can be done easily with freeware.
2. Scan, fax, and receive documents and images..
again can be done with freeware, if you have a scanner it came with scanning software.
3. Remotely access your business resources...
this is the only thing, but how many people use it.
4. Better protect your data against loss...
this is basically encrypting data.
so there it is, difference between ultimate and premium.
Edited by DST4ME - 13 Oct 2008 at 9:30am
