Need help putting together new DS system
Post Date: 2023-06-04
mnmasotto View Drop Down
  Quote mnmasotto Quote  Post ReplyReply bullet Topic: Need help putting together new DS system
    Posted: 04 Jun 2023 at 9:02pm
$2500 - 4500
Upgradable
Reading radiology exams such as CT Scans, ultrasound, Xrays and MRI. The cases are downloaded from a main server via high speed Google fiber. Many of the CT scsns can have over 2500 images about 1k each image.   Need to be able to scroll through the exams quickly. May also dabble in some gaming.p
Will also use as office PC for home related tasks.
Processor: Intel Core i5-13600KF (5.1 GHz Turbo) (20-Thread) (14-Core) 3.5 GHz (Raptor Lake)
Motherboard: ASUS Prime B760M-A AX D5 (Wi-Fi) (Intel B760) (Up to 3x PCI-E Devices) (No SLI) (DDR5)
System Memory: 32GB DDR5 5200MHz Kingston FURY Beast
Storage Set 1: 1x SSD M.2 (2TB Samsung 980 PRO) (NVM Express)
Storage Set 2: - No Thanks
Optical Drive: - No Thanks
Graphics Card(s): 1x GeForce RTX 4070 Ti 12GB (VR Ready)
Add On Card: - No Thanks
Extreme Cooling: H20: Stage 1: Digital Storm Vortex Liquid CPU Cooler (Single Fan) (Fully Sealed + No Maintenance)
Software Control: - No Thanks
Operating System: Microsoft Windows 10 Professional (64-Bit)
T-Shirt / Hoodie: - No Thanks
Keyboard / Mouse: - No Thanks
Mouse Pad: - No Thanks
Headset: - No Thanks
  Quote Cretae Quote  Post ReplyReply bullet Posted: 06 Jun 2023 at 1:21am
I don't see any red flags. It's a very powerful build. If you don't intend to power a 4K monitor, the video might be overpowered, but not worrisome. It's fine.
MrCheetah View Drop Down
  Quote MrCheetah Quote  Post ReplyReply bullet Posted: 06 Jun 2023 at 9:47am
Overall, I think, you've chosen well.
However, I suggest upping the cooling to H2O Stage 2 and perhaps even stepping up the CPU (and then probably moving to Stage 3 cooling).
Your stated workload will probably lean mostly on single core performance. I wasn't able to find any image viewing only benchmarks -- software such as Photoshop can, at times, leverage parallel processing (i.e., multi-core) -- so the following aren't a perfect depiction of the performance difference you might experience. Nonetheless, technically, there would be an uplift.
Processor Benchmarks | Geekbench
13th Gen Intel Core Processors Content Creation Review | Puget Systems
Is possibly 'flipping' through each image a few seconds faster worth several hundred dollars? ¯\_(ツ)_/¯ That's for you to decide/know.
P.S. One other budget consideration is a monitor. Because the small details, including minor color variations, are important to notice, I'd recommend having a large, in the thirty some inches, 4K/UHD monitor with high(er) color accuracy (e.g., photo editor approved).
Best Color-Critical Monitors for Creative Professionals | B & H Photo
The 5 Best 4k Monitors - Spring 2023 Reviews | RTINGS.com
