Need help resetting ATI 5970 2GB
Post Date: 2010-03-17
Niloh View Drop Down
  Quote Niloh Quote  Post ReplyReply bullet Topic: Need help resetting ATI 5970 2GB
    Posted: 17 Mar 2010 at 8:58pm
So anyhow I need to know the original settings that were in the Catalyst Control Panel when the computer was shipped to me.  I changed it to fix a bug I was having with a game and then noticed I was losing a lot of FPS when anti-aliasing was turned on (which wasn't the case previous to me changing it).  Also if I try to increase the GPU and Memory clock too much my system freezes up so I don't know what I'm supposed to fix.  Please reply with recommended settings for:
GPU Clock
Memory Clock
SmoothVision HD Anti-Aliasing
SmoothVison HD Anisotropic Filtering
Catalyst A.I.
Mipmap Detail Level
Wait for Vertical Refresh
Anti-Aliasing Mode
Triple Buffering
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 17 Mar 2010 at 9:13pm
when you click on CCC first screen should have a default button on lower right..that ought to do it
  Quote Niloh Quote  Post ReplyReply bullet Posted: 17 Mar 2010 at 9:47pm
I tried that, the problem was it wasn't the same settings at factory, plus the first time I reset to factory it messed with the underscan/overscan option which I'd never even heard of until I ran into the problem and did some checking online
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 17 Mar 2010 at 9:53pm
so it reset you clocks correct?
what other settings do you need help with?
  Quote Niloh Quote  Post ReplyReply bullet Posted: 18 Mar 2010 at 12:22am
Catalyst A.I.
Mipmap Detail Level
Anti-Aliasing Mode
Triple Buffering
or should I just use the slider for Performance -> Quality and not worry about all that other stuff
