need help
Post Date: 2013-05-04
codex43 View Drop Down
  Quote codex43 Quote  Post ReplyReply bullet Topic: need help
    Posted: 04 May 2013 at 3:55am
So my first gaming rig is on its way but I was wondering what do I need so I can hook up three monitors to it
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 04 May 2013 at 8:13am
Depends on the monitors you have.  I believe you have gtx 660ti, which have 2x DVi, a HDMI and a DisplayPort connector.  If your monitors have DVI inputs then two DVI cables and a HDMI cable  with a HDMI to DVI adapter.  If the monitors have only HDMI, then 3x HDMI cables with DVI to HDMI adapters, etc.  Lots of ways to go.
Good Luck.
  Quote codex43 Quote  Post ReplyReply bullet Posted: 04 May 2013 at 8:44am
Alright man thx so this 2x SLI Dual (NVIDIA GeForce GTX 660 Ti 2GB (Includes PhysX) if this help
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 04 May 2013 at 8:56am
The other thing is how you're using the monitors.  If its surround gaming across all three then there's a difference how you hook then up to the sli setup.
Here's a link to Nvidia that explains.  Just put in your  gtx 660ti, 2X sli, 2D or 3D and Landscape.  When you look at the two cards they show, the one on the left is your top card.
If only one is gaming and the other two for surfing, etc then you have alot od flexibility .
Good Luck.
Solidus1833 View Drop Down
  Quote Solidus1833 Quote  Post ReplyReply bullet Posted: 04 May 2013 at 11:35am
Good Luck.
THIS
its what i always use. its an awesome tool.
Dreadnought LvL 2
Sabertooth z77
i5-3570k cpu
2x 680 4gb Classified Gpu's
16gb DDR3 @ 1600
Noctua Cpu cooler
Corsair 1050HX PSU
Sound Blaster Creative Z
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 07 May 2013 at 11:32am
Yes, that is a very handy tool, thanks for link bprat Strong
This page was generated in 5.664063E-02 seconds.
