Need help!
Post Date: 2013-07-30
Ethan221 View Drop Down
  Quote Ethan221 Quote  Post ReplyReply bullet Topic: Need help!
    Posted: 30 Jul 2013 at 6:16pm
So am planning to get a new computer for about $2200 which I plan to use mostly for gaming and I was hoping I could receive some advise for my particular build on which components I should keep and which ones I should change so I could get the best performance based on my budget. All advise and suggestions are welcome.
Configuration number: 855855
Chassis Model: Special Deal Hot Seller - Digital Storm VIRTUE
Processor: Intel Core i5 4670K 3.40 GHz (Unlocked CPU) (Quad Core)
Motherboard: ASUS Gryphon Z87 (Intel Z87 Chipset) (Features Thermal Radar) (MATX)
System Memory: 16GB DDR3 1866MHz Corsair Vengeance Pro (High-Performance)
Power Supply: 750W Corsair CX
Hard Drive Set 1: Operating System: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition)
Video Card: 1x NVIDIA GeForce GTX 780 3GB (Includes PhysX)
DomTheBomb View Drop Down
  Quote DomTheBomb Quote  Post ReplyReply bullet Posted: 30 Jul 2013 at 7:55pm
Welcome to the forums Ethan!
The build you've put together is really nice, but there's a few things you could change:
-You can drop the memory to 1600MHz DS Standard without seeing any change in performance. Corsair Vengeance Pro does look really nice though, so that's one reason to keep it.
-For your budget I can't see not adding a solid state drive of at least 120GB. If you've not had one beofre, your OS and main games would go on there and you'd see a large increase in system speeds and loading times. Everything else goes on the HDD.
-Don't forget the free t-shirt!
The 780 is a great card, especially if you're using a single monitor. With that motherboard and power supply you can also add another card in the future.
DS x17, 1 Year 5 Months
i7 3720QM (2.6GHz/3.6GHz)
16GB 1600MHz DDR3
Nvidia GTX 680M 4GB
240GB Intel 520 SSD
Windows 8.1 Pro
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 30 Jul 2013 at 8:05pm
I will second everything DomTheBomb said.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 31 Jul 2013 at 2:29am
I agree, that is a nice build.    I would spend another $20 and get the Corsair H100i cooler.     Better fans, radiator and tubing and has a 5 year warranty.
Good luck.
  Quote retirednavysnipe Quote  Post ReplyReply bullet Posted: 31 Jul 2013 at 7:20am
I would second what has already been posted.
Hailstorm Black Ops
I7 3930K 4.5GHZ
16GB 1600MHZ ram
2 x GTX 680
120 GB SSD, 1 TB hardrive
  Quote Ethan221 Quote  Post ReplyReply bullet Posted: 31 Jul 2013 at 2:22pm
Thank you so much for all the help guys, I think I might save up a bit more of money and go for that SSD even though I might have to wait a little bit longer, I guess it will be worth it after all.
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 31 Jul 2013 at 4:00pm
SSD will definitely be worth the wait!
Edited by fstcvc - 31 Jul 2013 at 4:00pm
Tio View Drop Down
  Quote Tio Quote  Post ReplyReply bullet Posted: 01 Aug 2013 at 2:58am
I second everything that was said here
Hailstorm II
Intel 3970K
Corsair 1200i
Samsung 512gif 840 Pro SSD
4tb Western Digital Black HD
Blue-Ray and DVD Burn/Player
