Need Help
Post Date: 2014-11-25
Skargg View Drop Down
  Quote Skargg Quote  Post ReplyReply bullet Topic: Need Help
    Posted: 25 Nov 2014 at 5:18pm
$3500
Expectation
Looking for a very cool machine . Will be using Dual monitor @ 1080P.
Gaming from WOW to Farcry4 and some light TV streaming
Temps of card and CPU area very Important.
Saved Ticket #:1101544
Hi all !
Looking to get a new Computer to replace my old DS System. Wanting a slightly smaller case. I have been out of the Hardware loop for awhile and want everyone's thoughts on this rig. I will be using a dual monitor setup 1080P.
My only concern is the H20 Cooling.I live in a high humidity area 80% all the time. I tried it once (along time ago) and the condensation fried my rig.
Has the tech changed? is it still a issue? Temps are very important to me because of the high heat area i live in.
Thoughts?
Thanks Skargg
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 26 Nov 2014 at 7:06am
I wouldn't think condensation would be an issue with the Vortex 240 closed cooler you selected.   Ambient air is used by the fans to cool the fluid, so at no point would it be cooler than the surrounding air temps. Without the fluid being cooler, even in high humidity, no condensation. Never say never, but, highly unlikely in my opinion.
You could select the Noctua air cooler if its still a concern.   An excellent air cooler that is reliable, no pump, fluid, etc, quiet and cools just as well on your system. It is large but works.
  Quote Skargg Quote  Post ReplyReply bullet Posted: 27 Nov 2014 at 7:44pm
OK guys check out this revised order. Plan on pulling the trigger tomorrow or Monday.
1103176
Again i am going to be using on 2 27inch 1080P monitors play most games at high to ultra. I will be streaming Tv or movies on second monitor as i play.
Want to keep system nice and cool. Any suggestions and or tips are appreciated.
Thnks !
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 28 Nov 2014 at 8:11am
Excellent build.  Go for it.  Awesome
  Quote Skargg Quote  Post ReplyReply bullet Posted: 01 Dec 2014 at 5:47pm
Want to thank all for the help.
Just pulled the trigger !
Digital Storm Desktop 685801
Chassis Model: Special Deal Hot Seller ­ Digital Storm Velox
Exterior Finish: ­ Standard Factory Finish
Trim Accents: ­ Standard Factory Finish
Processor: Intel Core i7 5820K 3.3GHz (Six­Core) (Unlocked CPU)
Motherboard: ASUS X99­DELUXE (Intel X99 Chipset)
System Memory: 16GB DDR4 2666MHz Corsair Vengeance LPX (High­Performance)
Expansion Bay: ­ No Thanks
Optical Drive: DVD­R/RW/CD­R/RW (DVD Writer 24x / CD­Writer 48x)
Storage Set 1: 1x SSD (250GB Samsung 840 EVO)
Storage Set 3: ­ No Thanks
RAID Config: ­ No Thanks
RAID Card: ­ No Thanks
Internet Access: High Speed Network Port (Supports High­Speed Cable / DSL / Network Connections)
HPC Processor: ­ No Thanks
Extreme Cooling: H20: Stage 2: Digital Storm Vortex 240mm Radiator Liquid CPU Cooler (Extreme­Performance Edition)
H20 Tube Color: ­ Not Applicable, I do not have a FrostChill or Sub­Zero LCS Cooling System Selected
Chassis Fans: Upgrade All Fans to Corsair Airflow Performance Edition (Up to 6 Fans)
Internal Lighting: Digital Storm RGB LED Lighting System (Requires Thermal Management Control Board & Software)
Chassis Mods: ­ No Thanks
Noise Reduction: ­ No Thanks
LaserMark: ­ No Thanks
Graphics Boost: ­ No Thanks, Please do not overclock my video card(s)
Memory Boost: ­ No Thanks, Please do not overclock my memory
OS Boost: ­ No Thanks, Please do not tweak the services on the operating system
Windows OS: Microsoft Windows 8.1 (64­Bit Edition)
Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre­installed) ($35 Value)
Office: ­ No Thanks
Game: ­ No Thanks
Display: ­ No Thanks
Surge Shield: ­ No Thanks
Speakers: ­ No Thanks
Keyboard: ­ No Thanks
Mouse: ­ No Thanks
NVIDIA SHIELD: ­ No Thanks
Branded Gear: ­ No Thanks
Priority Build: ­ No Thanks, Ship Within 10­15 Business Days After Order Is Successfully Processed
