need help
Post Date: 2018-07-24
hoaphuong758 View Drop Down
  Quote hoaphuong758 Quote  Post ReplyReply bullet Topic: need help
    Posted: 24 Jul 2018 at 7:31pm
Can I please get some advice on if this custom build is well balanced. And if not what changes I should consider. I'm on a fairly low budget of around $1000-$1400
current configuration:
CPU (Processor): CPU i5-4690K Haswell 3.5GHz Quad-Core
Motherboard: MB ASrock Z97 Extreme3 SLI/Crossfire Ready
Graphics (Video) Card: GPU NVidia GTX 970 4GB
8 GB (2x4GB) DDR3 1600 Ram
Solid State Drive: SSD 240GB SATA III
Hard Drive: Hard Drive 2TB 7200RPM
Power Supply: PSU 650W Bronze Certified Power Supply
Sound Card: Sound Card None (Included with Motherboard)
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 25 Jul 2018 at 1:29am
It is well balanced and will give very good gaming with most games on a 1080p monitor.    The cpu and graphic card aren’t the latest but are still very strong and all most need.
carefulpunch View Drop Down
  Quote carefulpunch Quote  Post ReplyReply bullet Posted: 26 Jul 2018 at 5:27am
Yes, that's an awesome unit you got there!
carefulpunch
Ben sterling View Drop Down
  Quote Ben sterling Quote  Post ReplyReply bullet Posted: 27 Jul 2018 at 3:57am
Hello, i think that after looking that you have, i feel that your system looks very much balanced, & there's no need to make any changes.
