Need help
Post Date: 2019-03-04
lindakind89 View Drop Down
  Quote lindakind89 Quote  Post ReplyReply bullet Topic: Need help
    Posted: 04 Mar 2019 at 8:23am
Hey there guys, post pretty much sums it up. Looking for as good as I can get, strictly for gaming..ideally at 1440 144hz, and also with some consideration to futureproofing, i.e. 4k when it becomes really viable. Basically would like a strong 980 Ti SLI system, relatively cool and quiet at slightly under what the ultimate Slade/Apollo pre-builds cost.
Don't really know a whole lot about MOBOs, chipsets, differences in types/brands of RAM. Thanks in advance.
one config I was messing around with
Saved Ticket #: [1321899]
Chassis Model: Special Deal Hot Seller - Digital Storm Coridium <br><strong></strong>
Processor: Intel Core i7 5820K 3.3GHz (Six-Core) (Unlocked CPU)
Motherboard: ASUS X99-A USB 3.1 (Intel X99 Chipset) (Up to 4x PCI-E Devices)
System Memory: 16GB DDR4 2666MHz Digital Storm Certified Performance Series
Power Supply: 850W EVGA SuperNOVA <br><strong></strong>
Storage Set 2: - No Thanks <br><strong></strong>
Internet Access: Wireless PCI-E ASUS PCE-N53 (Dual Band Performance) (Supports 802.11n/g/b) <br><strong></strong>
Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 980 Ti 6GB (ASUS Strix Edition) <br><strong></strong>
H20 Tube Color:- Not Applicable, I do not have a custom HydroLux liquid cooling system selected
Airflow Control: - No Thanks
Boost Processor: Stage 1: Overclock CPU - Up to 4.4GHz (Depends on Cooling and Motherboard)
Portable Gaming: - No Thanks
Branded Gear: - No Thanks
  Quote Cretae Quote  Post ReplyReply bullet Posted: 04 Mar 2019 at 2:31pm
Hmmm, parts from 4 years ago? Are you wanting something that performs as well or outperforms this system? Or are you a time-traveler?
  Quote Snaike Quote  Post ReplyReply bullet Posted: 04 Mar 2019 at 6:09pm
980 Ti SLI? I'm guessing time traveler
  Quote hoserator Quote  Post ReplyReply bullet Posted: 05 Mar 2019 at 2:03am
And an Apollo! That post looks copied from the past altogether. Confused%20Wink
  Quote Snaike Quote  Post ReplyReply bullet Posted: 05 Mar 2019 at 3:28am
It is. From a "Verified Customer" as well.
This page was generated in 7.397461E-02 seconds.
