Need help!
Post Date: 2021-01-25
Vili_wonka View Drop Down
  Quote Vili_wonka Quote  Post ReplyReply bullet Topic: Need help!
    Posted: 25 Jan 2021 at 5:58pm
Looking into buying a PC. I have a Alienware monitor that can have 240 hz. I have a build but I have no clue what I’m buying... can someone help me out please?
This is my build currently...
Chassis Model: Digital Storm Lynx
Processor: Intel Core i9-10850K (5.2 GHz Turbo) (20-Thread) (10-Core) 3.6 GHz
Motherboard: ASUS Prime Z490-P / MSI Z490-A Pro (Intel Z490 Chipset) (Up to 2x PCI-E Devices) (No SLI Support)
Optical Drive: - No Thanks
Graphics Card(s): 1x GeForce GTX 1650 4GB
Airflow Control: - No Thanks
Boost Processor: Stage 1: Overclock CPU - Up to 4.7GHz on All CPU Cores
Boost OS: Yes, Disable and tweak all of the non-crucial services on the operating system <br><strong></strong>
VF
  Quote Cretae Quote  Post ReplyReply bullet Posted: 26 Jan 2021 at 4:06am
Well, you could start with a budget. Do you already have a good GPU? That one is not good, and overclocking it won't help. What is the resolution of the monitor?
The "Performance Series" Storage Set 1 is anything but. It is SATA while the other M.2 SSDs are up to 10 times faster. NVMe works off the PCIe interface.
The "OS Boost" is a waste.
  Quote Vili_wonka Quote  Post ReplyReply bullet Posted: 26 Jan 2021 at 5:44am
Thanks for replying! I don’t have a GpU. The resolution is 1920 x 1080. I honestly have no knowledge about PC. I’m trying to keep budget $1500-$2000.
VF
  Quote Cretae Quote  Post ReplyReply bullet Posted: 27 Jan 2021 at 4:15am
I would prefer to see you wait until the Lynx "prebuilts" are back in stock as that will save you some $$.
However, I know how hard that can be to wait, so here's something at $2033 that will work for you for a few years.
        3746681
To see it in the configurator, select "Load Config" at the upper right of the main page and copy/paste that number.
All the CPU you need. A better PSU for future upgrades, and game-changing Primary SSD for your operating system.
At 1080p, and high frame rates, the GPU will keep you happy for quite awhile.
  Quote Vili_wonka Quote  Post ReplyReply bullet Posted: 27 Jan 2021 at 4:27am
Thank you so much for your help!! Greatly appreciated!!
VF
  Quote Cretae Quote  Post ReplyReply bullet Posted: 28 Jan 2021 at 3:42am
This page was generated in 2.246094E-02 seconds.
