Need help
Post Date: 2009-02-18
gamejock54 View Drop Down
  Quote gamejock54 Quote  Post ReplyReply bullet Topic: Need help
    Posted: 18 Feb 2009 at 4:01pm
OK so i am looking for a rig that cost under 1200 after the sweet saving deals DS offers. Dont include an OS in system config.
I play EVE online. Looking to be able to run two premium clients at same time. With fps around 50.
This is there recommended requirement.
CPU: Intel Pentium® IV 2 GHz or AMD XP 2000+ MHz
RAM: 2048 MB
HD space: 8.0 GB
Video: 256MB GeForce 7950 or higher, ATi Radeon X1900 or higher and Similar chips from other manufacturers
Also do these rigs come with free slots so i can say add on another video card or buy more RAM in month and add it on?
Pls help i want to purchase this by tomorow.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Feb 2009 at 4:09pm
yes you can add more video cards but that will depend on your PSU.
your budget is too tight for me to config a system that not only you will have a 1 good GPU now and but be able to add another later.
you need to be around $2000 so we can build a system for you that will last you many years and you can upgrade to keep up with games as their requirements get higher.
  Quote gamejock54 Quote  Post ReplyReply bullet Posted: 18 Feb 2009 at 4:17pm
249155
that is what i came up with. Does that rig lend it self to be able to upgrade or add a video card and memory on?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Feb 2009 at 4:43pm
you have chosen no case. chose your case then let me look at it
Edited by DST4ME - 18 Feb 2009 at 4:44pm
  Quote gamejock54 Quote  Post ReplyReply bullet Posted: 18 Feb 2009 at 4:58pm
249169
There you go thanks.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Feb 2009 at 5:05pm
well your dvd is a reader not a writer, you maybe want to change that, you psu needs to go to a 1000w. and remember you will be running at stock speed of 2.6GHz.
Edited by DST4ME - 18 Feb 2009 at 5:06pm
