need help to build a computerPost Date: 2012-11-04 |
| Author | |
slice3819
Joined: 04 Nov 2012 Online Status: Offline Posts: 3 |
Topic: need help to build a computerPosted: 04 Nov 2012 at 10:14am |
hello guys, i'm planning to get a new computer for games in black friday, but i am new and duno how to build a compatible computer,i'll be glad if any of you can lend me hand, thank you.
I want to build a computer which can handle the full graphic setting without lag for skyrim(if don't lag with mod would be the best), witcher 2 and most FPS.
my budget is around $700-800, i don't need a monitor nor keyboard and mouse neither speakers. I only need the main machine but at least able to install 4 3.5 inch internal hardrives. I prefer intel cpu and Nvidia products. I also prefer quite but a little bit noise is okay. |
FrankW
Joined: 22 Feb 2010 Online Status: Offline Posts: 2254 |
Posted: 04 Nov 2012 at 1:12pm |
Hi slice3819, welcome to the forum.
I am sorry but with your budget you don't have a lot of options. The only DS system that fits somewhat is the Marauder level-1. That is DS's entry level gaming machine. This system won't get you Nvidia or Intel. This is it or you need to save some more money. Frank Marauder Level-1 Cost: $799 Chassis Model: Special Deal Hot Seller - Pre-built Digital Storm Marauder - Level 1 Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: AMD Bulldozer FX-4100 Zambezi (3.6GHz) (4 Core) (8 MB Cache) AM3+ Socket Motherboard: ASUS M5A97 (AMD 970 Chipset) (SATA 6 and USB 3.0) (Socket AM3+) System Memory: 8GB DDR3 1600MHz Corsair Vengeance Series (High-Performance) Power Supply: 600W Corsair GS Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (500GB Western Digital/Seagate/Hitachi/Samsung (7200 RPM) (16MB Cache) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: - No Thanks Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x AMD Radeon HD 7750 1GB Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: Standard Factory Heat-sink and Fan H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: - No Thanks Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: - No Thanks, Please do not overclock my processor Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty Edited by FrankW - 06 Nov 2012 at 9:50am |
slice3819
Posted: 06 Nov 2012 at 8:58am |
thank you for the reply, how much would be the minimum cost for a gaming computer?
FrankW
Posted: 06 Nov 2012 at 10:03am |
Hi slice3819,
I am sorry that I left off the price. The computer I posted is the cheapest computer DS sells and it is $799. You can move up to the Marauder Level 3 and it will give you an Intel i5 3570K CPU and a AMD 7870 GPU. The cost is $1259. The next step up is the Marauder Level 4 that will give you the same Intel CPU with a Nvida GTX 660 Ti GPU. the cost is $1299. Then there is the ODE series that offers a little better stuff. The ODE Level 1 will give you the same CPU with a Nvidia 670 GPU. The cost is $1499. You need to go to these individual builds and see what you like. A high performance gaming computer cost some money but will give you terrific game play. The computers I have listed are all based on the best performance for the money. It mostly depends on what your gaming expectations are and how much you can speed. This is what the ODE Level-1 looks like. Chassis Model: Special Deal Hot Seller - Pre-built Digital Storm ODE V2 - Level 1 Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i5 3570K 3.40 GHz (Unlocked CPU) (Quad Core) (Requires Z77 Motherboard) Motherboard: ASUS P8Z77-V LX (Intel Z77 Chipset) System Memory: 8GB DDR3 1600MHz Corsair Vengeance Series (High-Performance) Power Supply: 600W Corsair GS Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (1TB Western Digital/Seagate/Hitachi/Samsung (7200 RPM) (32MB Cache) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: - No Thanks Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x NVIDIA GeForce GTX 670 2GB (Includes PhysX) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 1: Corsair A50 120mm Fan High Performance Cooler H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Red) Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty Edited by FrankW - 06 Nov 2012 at 12:17pm |
slice3819
Posted: 06 Nov 2012 at 11:49am |
oh ok thank you
