Need help trying to keep it under $1400
Post Date: 2010-07-20
bartmanb View Drop Down
  Quote bartmanb Quote  Post ReplyReply bullet Topic: Need help trying to keep it under $1400
    Posted: 20 Jul 2010 at 10:23am
This will be my first "Gaming PC" and although i have done a bunch of research i really am unsure how i should use my budget wisely on a rig. I am ready to purchase and will be purchasing today, i just need a little advice.  I pretty much want the best i can get for under $1400.  I have a nice 24'' samsung monitor so i won't need that.  I want a nice video card, but more importantly, a good processor and motherboard since i can upgrade the video card later.  here is what i have so far, let me know what you think.  Any advice is welcome.
Chassis Model: Special Deal Hot Seller - Maelstrom
Motherboard: EVGA X58 Micro Edition SLI (Intel X58 Chipset)
Hard Drive Set 1: Operating System: 1x (500GB Western Digital (16MB Cache) (7200 RPM)
Video Card: 1x NVIDIA GeForce GTX 460 768MB (Includes PhysX Technology)
Thanks,
Brandon
  Quote bartmanb Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 10:44am
My main application will be SC2 and Diablo 3 with a little WoW thrown in here and there.
Should i consider going with a cheaper processor and upgrade the cooling components a bit?  Something like this instead:
Processor: Intel Core i5 750 2.66GHz (Quad Core)
Motherboard: EVGA P55M SLI (Intel P55 Chipset)
Extreme Cooling: AIR: Stage 1: High Performance Cooler (Compatible With ONLY i5/AMD Processors)
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Blue) (Up to 6 Fans)
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 11:01am
right idea but you can fit more power into the budget, for 1400 max the bottleneck in gaming right now is all about the graphics card, so i present to you a $1400 gtx 470 build:
you cant fit more power in to the price range, its not going to be an overclocking beast but it will play the games you listed on great settings with no issues
oh and you get a free game
and you dont have to overclock the 470, and it will still beat your 460
i also wouldnt reccomend overclocking the gpu with any budget build
definitely leave out the OS tweak, windows 7 is easy to tweak on your own, but it doesnt need it anyway
Edited by !ender_ - 20 Jul 2010 at 11:06am
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 11:12am
just thought id throw this in as food for thought:
i know its right over 1400 but you really have to consider what youre spending your money for.. sure, you could finagle the price down a few dollars, but i gave you what i feel is the msot effective use of your money. you could drop the HDD to a 250gb but that would only save you $17... so look at objectively, why would you give up paying $17 for double the storage?
several instances of this could shave a few dollars, but in the long run, you would be costing yourself more than helping yourself
  Quote bartmanb Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 11:32am
good and Interesting stuff.  Got a couple of questions.
1. Why not overclock the gpu on a budget build?  not enough cooling?
2. Hmm, i noticed you had the i5-655K on your build, what is the difference between that and the i5-750?
3. I don't see the gtx 460 1gB available as an option, only the 768.  Does DS not have the bigger gtx 460 avaialable?
4. I have heard that the gtx 470 and 480 run a lot hotter than the new 460.  With the cooling you have in the build, would I have to worry about heat issues?
Thanks alot
Brandon
  Quote bartmanb Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 11:43am
Also i noticed that you picked the Cooler Master CM 690 for the chassis. Was this just because it is the cheapest one?  How much does the chassis matter?
chanman View Drop Down
  Quote chanman Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 11:57am
the 655K overclocks better than the 750. other than that, i think they are pretty much the same. I would stick with the 470 personally. I have a larger budget, so i'm going with a 480. You might have to worry about heat, but only if you overclock the video card. Generally, new video cards don't need to be overclocked, and if you need to later you can do so easily yourself with say, rivatuner.
The chassis has a few factors you need to consider. looks, price, size, weight, and airflow mainly. emphasis on the airflow. you can look at the specs of each of them and decided which one you like best.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 12:20pm
655 is dual core, 750 quad.. Im%20with%20Stupid
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 12:52pm
why waste effort on the heat and noise when you can get a 470 which is better and you dont really need to overclock, at least not now. beyond that, it is noise and cooling, its just not nessesary
as was stated its a dual core vs the 750 quad but with hyperthreading, that becomes pretty insignificant. the 655 can run 4 logical cores, providing you the same logical power as an older quad core, and for the budget range you are in. it makes the most sense. if you had some wiggle room, i would go up to the 860 before id take a 750 even though these are both quad cores
i dont see it so i would guess no, but thats, again, not nessesary becuase you can make it to the 470 and its substantially better than either 460
liable marketing, i have yet to find one person who actually OWNS AND USES the fermis to complain about thier noise and heat when they are not overclocked. i am included in this group. mine is cool quiet and powerful as hell
  Quote bartmanb Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 12:58pm
Awesome, thanks for the help guys. I just placed my order.  Hopefully i didn't screw it up too badly.... Confused
You guys did talk me up to the 470 Big%20Smile
I decided to go with the i5-750 after reading a couple of reviews and comparisons online, I hope that wasn't a mistake.
I also added on a few other things that i could use as well... a decent mouse, and new speakers.
here's my build, tell me what you think:
Video Card(s): 1x NVIDIA GeForce GTX 470 1.2GB (Includes PhysX Technology)
Extreme Cooling: AIR: Stage 1:Coolermaster V6 Single 120mm Fan Performance Cooler (Compatible With AMD, i5, i7)
CPU Boost: FREE: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Cooling Upgrade Recommended)
Pre-Install Game: FREE: Hot-selling game with a NVIDIA GeForce GTS 250 or above graphics card
Speakers: Logitech 2.1 System (Black Edition) (Model LS21) (Includes Subwoofer)
Mouse: Razer Deathadder Gaming Mouse (High-Speed Gaming Grade)
Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Xtra Large)
Sub-Total: $1,527.00
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 1:00pm
very good choice on the 750, and the GTX 470..
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 2:10pm
looking pretty good, if you were going to come up to $1500, id get the i7 860
http://www.digitalstormonline.com/comploadsaved.asp?id=423743%20
and id be careful buying speakers from DSO, from what ive read on the forums from DSO staff you will pay extra shipping and these are not covered under warranty
