Need help upgrading PC(newbee)
Post Date: 2018-10-09
jehielfaustino View Drop Down
  Quote jehielfaustino Quote  Post ReplyReply bullet Topic: Need help upgrading PC(newbee)
    Posted: 09 Oct 2018 at 7:12am
[400-600]
[better multi tasking]
[i have vanquish 7 lvl 1 with gtx 1050ti(just bought it and its playable]
[i just need to know whats the next to upgrade to make my pc better at multi tasking(note: Newbee building on computer)]
[proccesor or motherboard i dont know. thanks guys!]
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 09 Oct 2018 at 1:32pm
Depending on your level of multitasking, I would consider upping the 8 gb ram to 16gb.   Also, if you have a mechanical Hard Drive, a solid state SSD will bump up performance across the board with much faster reads and writes.    All depends what you do.
Not sure if that motherboard has a decent 8 core cpu upgrade, but that could help a lot.   A mobo, cpu upgrade is an expensive way to get a little bump.
