Need help with a few Config Choices.
Post Date: 2009-07-16
augdawg View Drop Down
  Quote augdawg Quote  Post ReplyReply bullet Topic: Need help with a few Config Choices.
    Posted: 16 Jul 2009 at 1:32pm
Hey Everyone,
I am looking into getting a PC very soon and there was some final choices i wanted some advice on. I will post my goals, my question, and finally the PC setup i am thinking of rolling with.
I want to thank everyone for taking the time to help me with this ahead of time :)
The Goal :)
Play Lord of the rings online at 2560 x 1600 resolution on my 30 inch dell.
Ultra High settings, every single thing maxed out.
16x AA.
DirectX 10.
FPS ALWAYS above 30 preferably 60, but thats near to impossible at max everything on at the above resolution.
the SSD Hard drive is strictly for LOTRO and wow. LOTRO benefits from them greatly due to extremely long load times for their high textures.
Here are some questions i have about individual config options.
Video Card - 4870x2 at 215$ or GTX295 at 465$.. i am leaning towards the 4870 due to the value of it being 1/2 the cost.
Case - Antec 0$ or the Haf 932 +70$
Sound Card. Onboard 0$ or Razer Barracude AC-1 130
Extra Fans  - 0 or 63$
Nvidia ESA - is this really worth the 50$ ?
Windows Boost-  35$  same thing, really worth the $ i normally run MSCONFIG and shut off all apps and services at startup already.
OS - Vista Home 64 for 0$or Vista Ultimate 64  15$ or Ultimate with 7 Upgrade 83$ . for the OS as along as i can lock my workstation as needed, i dont think i would use the extra features.
-------- Here is the proposed setup---------------------------
Chassis Model: Antec Nine Hundred Two
System Memory: 6GB DDR3 1333MHz Digital Storm Certified by mushkin enhanced (Highly Recommended) (Hand Tested)
Power Supply: 910W PC Power & Cooling (Dual/Triple SLI Compatible) (Silencer Edition)
Card Reader: - No Thanks
Hard Drive Set 2: Multimedia\Data: 1x (60GB Solid State (By: OCZ) Vertex Series (Model: OCZSSD2-1VTX60G)
Video Card: 1x NVIDIA GeForce GTX 295 1.792GB (Includes PhysX Technology)
Extreme Cooling: AIR: Stage 2: V8 Cooler Master High Performance Cooler (Compatible With ONLY i7 Processors)
LCD Display: - No Thanks
Edited by augdawg - 16 Jul 2009 at 1:39pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Jul 2009 at 4:15pm
well first of all let me say that if you think one 295 or 4870x2 will run any games maxed out on settings at 2560 x 1600, you are heavily mistaken.
you would need 2 x 295 or 4870x2 to do that, second the 295 beats the 4870x2 that is why it cost more, third I don't believe lotr utilizes sli to begin with so both of those cards will do worst then one 275 GTX.
forget esa its not really supported on the i7 platform.
windows boost is not worth it, and using msconfig to disable all apps is even a worst idea. you should never disable all apps, you need to run your av and firewall and msconfig is not meant to be used to make permanent changes, use CCleaner and disable only the apps you don't need to start.
Edited by DST4ME - 16 Jul 2009 at 4:18pm
  Quote augdawg Quote  Post ReplyReply bullet Posted: 16 Jul 2009 at 5:37pm
Hey DST thanks for the advice.
in alot of the benchmarks i saw the GTX295 and the 4870x2 come relativly close (around 15 20% in the GTX295's favor.)
I am currently running on ultra high in the game with an 8800GTX, but i often go from 60 FPS to 20 or 10 due to various circumstances. Thats why i have the debate between the 2 cards. if the 8800GTX that i currently have can do it poorly, maybe the 295 is way overkill ?
Lotro does support SLI and crossfire now, its the only MMO out there that actually get the benifit. It certainly didnt at release, but they made the changes about a year ago.
Thank you for your advice on the ESA and the windows boost. As for MSCONFIG i only used it to turn off stupid services, not all applications especially Antivirus. I've been working in Helpdesk/Networking for about 9 years so i have a good handle on PC's.
Thanks for your advice.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Jul 2009 at 5:41pm
again with all due respect, msconfig is not meant for permanent changes, go to your service window and change services there then.
ok if it does support sli then your best bet is 3 x 275.
you running 2560 x 1600 with a 8800gtx on high settings, that is why you fps drop so low. tri sli 275 will give you highest settings with high fps, but you are more then welcome to try 2 x 275 if you like, you can always add a third one later.
  Quote augdawg Quote  Post ReplyReply bullet Posted: 16 Jul 2009 at 5:41pm
You are totally correct with that, disable services. I have just used it to disable apps on windows startup. IM, Quicktime etc etc.
So i wonder what is actually involved in their windows tuning ? Does that just include turning off Aero :P
I'll consider going with the 2 or 3 275's. i have seen a few other people going with the same thing.
This is my current setup, so i am comparing from that.
30' dell monitor
amd dual core chip 2.6
Nvidia evga 8800 GTX
4 gb of ram
7.200 rpm HD
on board nic - i know, i never thought it would suck so bad.
Windows XP, sp 3. - NO dx10 .
Edited by augdawg - 16 Jul 2009 at 5:43pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Jul 2009 at 5:49pm
then use ccleaner to disable apps
windows tunning is pointless, what is the use of it? do you think disabling services in this beast will make any difference to it.
Edited by DST4ME - 16 Jul 2009 at 5:49pm
satsunada View Drop Down
  Quote satsunada Quote  Post ReplyReply bullet Posted: 16 Jul 2009 at 6:33pm
ya know, 2 x 4870x2 is wildly cheaper than 3 x 275 given the clearance thing. And if you consider the 2 x 275 1796mb is like 60 bucks cheaper than 2 x 4870x2 then it's almost worth the jump to the 4870x2's.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Jul 2009 at 6:36pm
do you have any idea how much better 3 x 275 is then 2 x 4870x2?
2 x 275 matches the performance of 2 x 4870x2 practically
Edited by DST4ME - 16 Jul 2009 at 6:38pm
  Quote augdawg Quote  Post ReplyReply bullet Posted: 17 Jul 2009 at 10:27am
well 1 4870x2 is 215, while 2 275's is 415 ish. only a 200$ difference.
DST do you know any sites that have done benchmark testing with 275's in SLI. everything i can find just has it as a stand alone. I usually go off what Toms hardware says and a few other random sites i google.
http://www.tomshardware.com/charts/gaming-graphics-cards-charts-2009-high-quality/F.E.A.R.-2,1325.html
I turned everything up to ultra high, and 4x aa last night on my current rig. it can maintain 40 DPS in all but the most crowded places. So i think regardless of what video card solution i go with, i should be able to accompish my goal.
oh and i downloaded CC cleaner, pretty nice tool there. definetly a keeper.
Edited by augdawg - 17 Jul 2009 at 10:28am
Sarah View Drop Down
Hardcore Gamer
  Quote Sarah Quote  Post ReplyReply bullet Posted: 17 Jul 2009 at 2:46pm
augdawg, when you are ready, give me a call, I will get you rocking.
Sarah
  Quote augdawg Quote  Post ReplyReply bullet Posted: 17 Jul 2009 at 3:27pm
Thanks Sarah i will :)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Jul 2009 at 6:02pm
augdawg read my last post again I said 2 x 275 will match performance of 2 x 4870x2, so:
2 x 275 = $415
2 x 4870x2 = $430
I have seen some 275 sli benches, I don't remember where tho, but if you find them you will see that 1 x 275 matches the performance of 1 x 4870x2 or beats it.
Edited by DST4ME - 17 Jul 2009 at 6:02pm
This page was generated in 0.140625 seconds.
