Need help with a new computer build
Post Date: 2011-12-15
Charlestp13 View Drop Down
  Quote Charlestp13 Quote  Post ReplyReply bullet Topic: Need help with a new computer build
    Posted: 15 Dec 2011 at 10:55pm
Hi, i am a newbie at building computers. I'm looking for suggestion on what design and config would be best.
1. My Budget: around $3,000 just for the rig.
2. Expectation: Run any games smoothly on high settings (Skyrim, BF3...etc.). Intermediate multitasking.
3. Usage: Mostly gaming, maximum cooling system (my room avg temp is 75F)
4 Special Needs: Quiet :)
Thank you for your time.
HAL View Drop Down
  Quote HAL Quote  Post ReplyReply bullet Posted: 15 Dec 2011 at 11:31pm
We need to know your res before anything else. If you have no monitor chosen we recommend the dell ultra sharp series.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Dec 2011 at 12:52am
As mentioned we need to know you res so we know how much power it takes to max it.
your room temp plays the biggest part in your cooling, if your room temp is hot (80f or higher) then you gonna have load problems, but 75f is a good room temp to have.
95% of noise is gonna be from gpu's fan when under load, the only way to deal with that is to put them under lc, and that is beyond your budget.
Edited by DST4ME - 16 Dec 2011 at 12:53am
  Quote Charlestp13 Quote  Post ReplyReply bullet Posted: 16 Dec 2011 at 1:40am
Oh sorry. The resolution is either 1920x1080 or 1900x1200.I'd prefer 1920x1080
Edited by Charlestp13 - 16 Dec 2011 at 1:44am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Dec 2011 at 2:21am
Here you go Ticket# 632689 --- $2,819 (To see this build click here)
haf 200mm non led fan
Ask for vcore lower then 1.4 for your oc.
  Quote Charlestp13 Quote  Post ReplyReply bullet Posted: 16 Dec 2011 at 2:34am
Awesome, thank you for all the incredible suggestions. However, i do have one more question. Which of the dell ultra sharp series would you recommend? Budget: $300
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Dec 2011 at 2:40am
