need help with a new pc
Post Date: 2013-01-01
budakia View Drop Down
  Quote budakia Quote  Post ReplyReply bullet Topic: need help with a new pc
    Posted: 01 Jan 2013 at 4:58pm
   Hello everyone... I am new to the scene and I was hoping someone can help me come up with a system for gaming and for my renderings... I use photoshop and a few 3d rendering programs a lot for my hobby. I was hoping for a smooth system that can handle the processing load. I have a toshiba monitor and use a wacom intous 5 drawing pad for everything... and unfortunately I am on a tight budget.
  Please... someone help me with some ideas... I have heard a lot about DS and i must admit that i am impressed...
              thank you
DomTheBomb View Drop Down
  Quote DomTheBomb Quote  Post ReplyReply bullet Posted: 01 Jan 2013 at 8:08pm
Welcome to the forums budakia!
If you could provide us with your budget and monitor(s) resolution that would help us put together a build that fits your needs.
Also, if you have already started configuring a system you can post it in configuration discussion to receive feedback from other forum members.
DS x17, 1 Year 5 Months
i7 3720QM (2.6GHz/3.6GHz)
16GB 1600MHz DDR3
Nvidia GTX 680M 4GB
240GB Intel 520 SSD
Windows 8.1 Pro
  Quote budakia Quote  Post ReplyReply bullet Posted: 02 Jan 2013 at 3:02am
I have a 26" Toshiba set at 1360 x 768   60hz     16:9 ratio
That is all I could really tell you.
I would like to keep my budget at around $1500.00... because I need to get a few other things like an external hard drive,
My hobby is airbrushing and I always do renderings and photo manipulations in adobe photoshop.... this is the main reason i need something with some power....
Thank you for relying and helping me with this,
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 02 Jan 2013 at 6:08am
Hi budakia...   Welcome to the forums.
For your budget I would recommend one of the pre-built sysems because they do offer more for the money.
The Marauder level 4, ODE level 1 and Bolt level 3 fall within your budget and are real nice syatems.
The difference....  The Marauder 4 is the cheapest.   The ODE 1 for another $200 gives you a better case, a better graphics card that's about 20% better in gaming than the 660Ti , and cpu overclocking.  Oc'ing is a cheap way to get a boost in performance and your apps would appreciate the added clock speed.
The Bolt level 3 has the avantage of the i7-3770k cpu over the others.  For your renderings, etc. the 3770k with its Hyperthreading gives you a 4 core chip with 8 threads for faster processing over the 3570k's 4 core, 4 thread in the other builds.
To stay in budget with the Bolt 3 , you could drop the SSD, and Blu-ray player for DVD player.
Here's another config just to show you some options.  It's over budget but the X79 Sabertooth motherboard is a quad channel memory board as opposed to the others Z77 dual channel ram.  The quad channel has a 256 bit memory buss, the Z77 boards a 128 bit memory buss.  Theoretically twice the speed but in reality about 20-30% or better by some estimates.  Its also has 16GB ram.  The wider memory bandwidth will make your renderings smoother.
Config # 770555      Cost $ 1815
Chassis Model: Special Deal Hot Seller - Corsair Carbide 500R (Black Finish)
Hard Drive Set 1: Operating System: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition)
Video Card: 1x NVIDIA GeForce GTX 660 Ti 2GB (Includes PhysX)
Extreme Cooling: AIR: Stage 1: Cooler Master Hyper 212 EVO (High Performance Cooler)
This config is more $$ than you asked for and the other builds with Z77 dual core ram will work great and stay in budget.  It all depends on what level you render, Photoshop, special effects, etc.  And budget of course.
You really can't go wrong with any of them.  They will all give you what you want, just that some options have a bit better components.  It's all good. Strong
Hope this helps and good luck. Big%20Smile
Edited by bprat22 - 02 Jan 2013 at 6:14am
  Quote budakia Quote  Post ReplyReply bullet Posted: 03 Jan 2013 at 3:22am
wow!! i definitely love the last config!!!  Thank you very much   bprat22!!!
I realize I have some options now and I think within a couple of months I will have a perfect pc!! Thank you all!!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 03 Jan 2013 at 8:41am
Glad to help. Big%20Smile
This page was generated in 0.140625 seconds.
