need help with custom systemPost Date: 2010-02-16 |
Page 12> |
| Author | |
rogueunicorn
Joined: 16 Feb 2010 Online Status: Offline Posts: 80 |
Topic: need help with custom systemPosted: 16 Feb 2010 at 8:19pm |
i've been looking at these digital storms for other a month now. i can't even believe that i considered alienware computers
im trying to stick as close as possible to $2500. for this computer, i'll mainly be gaming. modern warfare 2, crysis, fallout 3, stuff like that. would this computer be good for running these games maxed out? ticket number: 385090 Storm Sniper Intel i7 920 2.66Ghz EVGA x58 3X SLI 6GB DDR3 1600MHz 1000w Digital Storm Certified Power Supply 1x 500GB Western Digital 1x 500GB Western Digital DVD R/W/CD R/W Optical Drive High Speed Network Port (going to upgrade to killer xeno pro if needed) 1x Radeon 5870 Video Card (going to upgrade to a second card if needed) Integrated Motherboard Audio Asetek 240mm Liquid Cooler Led Performance Fans (Green) Internal Lighting System (Green) Touch 2000 Aerocool Temperature Display and Fan Controller Yes, overclock my processor between 3.3Ghz and 3.9Ghz Yes, overclock my video cards as much as possible with complete stability. Yes, tweak my OS. Microsoft Windows Ultimate Free Digital Storm T-Shirt 3 Year Warranty so...thoughts? |
philiporphillip
Joined: 18 Nov 2009 Online Status: Offline Posts: 335 |
Posted: 16 Feb 2010 at 10:37pm |
1. the haf 932 case has great airflow, so i would choose that. but i haven't tried the storm sniper, but i'm leaning on the haf more.
2. 1000w corsair is better. you could also go with the 750w corsair, but might be tight if you were to go sli/crossfire.
3. don't need to upgrade to the xeno pro.
4. asetek is not a genuine liquid cooler. the v8/noctua are better.
5. no need to upgrade chassis fans/aerocool display unless you want to. will create more noise, but i said 'unless' b/c some like the aesthetic appeal like me.
6. no need to overclock your gpu .. minimal gain.
7. no need to tweak your os.
8. go with windows 7, professional .. has xp support.
the games you listed, i have. i enjoy modern warfare 2 more >,< out of the 3. Edited by philiporphillip - 16 Feb 2010 at 10:39pm |
Digital Storm
haf 922 i7-920 oc'd @ 3.6 ghz (1.28v) evga x58 le edition sli cooler master v8 6 gb ddr3 1600 mhz mushkin evga nvidia geforce gtx 295 co-op edition 1000w corsair hx |
rogueunicorn
Posted: 16 Feb 2010 at 11:28pm |
so would you suggest getting the Noctua NH-D14 Extreme Performance Air Cooler over the Asetek 240mm cooler?
philiporphillip
Posted: 17 Feb 2010 at 12:45am |
yes, replace the asetek either with the v8 or noctua nh-d14 (DS just started adding this in their inventory not too long ago) or the noctua dual 120mm.
if budget allows, select either of the 2 noctua b/c most people here believe v8 < noctua.
are you going to delete the upgrade chassis fans/aerocool display? .. doing so will save you a lot of money.
what resolution are you planning to use? .. the gpu depends on your resolution.
DST4ME should drop-in and help configure a system for you, but what i've mentioned in my previous post still stands in my opinion. Edited by philiporphillip - 17 Feb 2010 at 12:46am |
Digital Storm
rogueunicorn
Posted: 17 Feb 2010 at 12:52am |
i may or may not keep the led fans, but i'm definitely going to delete the aerocool display thing. i'm not sure what resolution i'll be playing on, but probably higher then 1280x1024.
Edited by rogueunicorn - 17 Feb 2010 at 12:59am |
philiporphillip
Posted: 17 Feb 2010 at 1:04am |
then the ati 5850 would do i think. wait for a 2nd opinion b/c i'm not an expert in this field yet.
led fans with the storm sniper case i suppose? the aerocool takes up 2 drive bays.Edited by philiporphillip - 17 Feb 2010 at 1:06am |
Digital Storm
rogueunicorn
Posted: 17 Feb 2010 at 1:06am |
^ i decided to drop the leds.
Posted: 17 Feb 2010 at 1:51am |
this is what you want, I dropped things that are waste of your money or things that basically make no difference or not enough to be noticed:
Here you go Ticket# 385579 --- Price: $2164 (To see this build click here) Price after current promotion $2164 Copy of Specifications: Chassis Model: Special Deal Hot Seller - Cooler Master CM Storm Sniper Exterior Finish: - Not Available Trim Accents: - Not Available Processor: Intel Core i7 920 2.66GHz (Quad Core) Motherboard: !SALE: EVGA X58 3X SLI (Intel X58 Chipset) (Supports Triple SLI or CrossFire) System Memory: 6GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 750W Corsair TX (Dual SLI Compatible) Expansion Bay: - Not Available Hard Drive Set 1: Operating System: 1x (1TB Seagate/Hitachi/Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme Speed) Set 1 Raid Options: - Not Available Hard Drive Set 2: Multimedia\Data: - No Thanks Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 22x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x ATI Radeon HD 5850 1GB Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 2: Noctua NH-D14 Extreme Performance Cooler (Compatible With ONLY i7 Processors) H20 Tube Color:- Not Available Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Blue) Enhancements: - Not Available Chassis Mods: - Not Available Noise Reduction: - Not Available Boost Processor: FREE: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Requires Air Cooling Upgrade) Boost Video Card: - Not Available Boost Memory: - Not Available Boost OS: - Not Available Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based) Virus Protection: - Not Available Office: - Not Available Benchmarking: - Not Available Install/Test Game: FREE: Please include a free copy of a hot-selling game Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Large) Priority Build: - No Thanks, Ship Within 5-10 Business Days After Order Is Successfully Processed Warranty: 3 Year Platinum Care Extended Parts & Labor Warranty it would be much better if we know what res teh monitor you gonna be using can handle. Edited by DST4ME - 17 Feb 2010 at 1:51am |
philiporphillip
Posted: 17 Feb 2010 at 2:08am |
make sure you choose green as your internal chassis lighting color .. DST4ME's configuration has blue set.
why not the 1000w corsair? .. he may go sli/crossfire in the future. Edited by philiporphillip - 17 Feb 2010 at 2:10am |
Digital Storm
Posted: 17 Feb 2010 at 2:25am |
with 2 x 5850 oced he can do 2560 x 1600, so no need for a third card and minimal gains.
I chose blue cause the case's front fan is blue led, and that won't change unless he pays extra and specifically asks for it to be changed, but ya good catch, if you want green change the light to green but keep in mind that the fan's color is gonna be blue. hope that explains it
rogueunicorn
Posted: 17 Feb 2010 at 3:34pm |
thank you guys soo much. i'm going to go with DST's configuration, but adding the 1000w corsair and using the 5870. also, do sound cards make much of a difference? or will the onboard audio be fine.
philiporphillip
Posted: 17 Feb 2010 at 3:59pm |
any time.
1. it depends .. if you're into music/audio like i am, then yes, a dedicated sound card will be a good investment. don't select the barracuda. go with creative.
2. on-board sound is ok, but i've never tested it. compared to a sound card, the sound card wins.
Digital Storm
Posted: 17 Feb 2010 at 5:13pm |
why go with a 5870 if you will never notice a differnce from 5850? 5870 is for 1900 x 1200 res, but you can oc a 5850 to match its performance if you get to 1900 x 1200, you first need a monitor that can do 1900 x 1200 res, do you have one?
for our use 1000w and 5870 is pure waste of money, since you can do the exact same thing with a 5850 and 750w. Edited by DST4ME - 17 Feb 2010 at 5:14pm |
Monstromo
Joined: 10 Oct 2007 Online Status: Offline Posts: 214 |
Posted: 17 Feb 2010 at 8:37pm |
Take a look at the benchmarks of the performance of an i5-750 and a i7-920. You will find that in gaming the addition cost of the i7-920 is suspect. This is true whether you choose the 5850 or the 5870.
I have three systems:
Intel Quad i5-750 w/ 5850
AMD triple core 720 BE w/ 4890
Intel Quad Q6600 w/ 260 216 OC
I researched the advantages of the i7-920 over the i5-750 and found that if you are using your PC for hard core gaming save the money and put it toward the GPU.
You can easily justify the cost of the 5870 this way. I think you would notice the difference between the 5870 and the 5870 at your res. If you like to turn all the bells and whistles on max in all your games get the 5870, especially AA (anti-aliasing) and other DX11 GPU stressing settings.
Regarding the sound card, I have systems with them and without them. A good sound card costs upwards of $200, I have and recommend the Creative PCI Express Sound Blaster X-Fi Titanium Fatal1ty Champion Series Sound Card http://www.newegg.com/Product/Product.aspx?Item=N82E16829102021&cm_re=fatal1ty_sound_card-_-29-102-021-_-Product if you decide to get one. But what did and recommend to you is that you forego the sound card now and save the money. After you get your PC and set it up and see if you feel that you really want one. Remember a soundcard does nothing for you unless you have the speakers of such quality that does it justice. There are some people who hold the opinion that a sound card will give you more FPS. This really isn't much of a reason to get one. Save the money and buy a 5870 and it won't matter. I doubt a soundcard gives you more than one to three additional FPS if at all.
Regarding the Power supply I think a 750W is plenty for a 5870, but if you plan on going SLI in future and really want to give yourself a lot head room it is okay to go with the 1000W, it is your money, it just isn't absolutely necessary.
Corsair is a good power supply but Enermax is just as good. Find out a head of time what your options are. Sure Corsair is a safe bet but it isn't the only quality PSU in town and you pay a premium for it.
Overclocking the GPU and CPU is not absolutely necessary. For the most part it serves to give you bragging rights. The DS overclocking is going to be a safe overclock it is not going to push the envelope of performance. You will find that if you get your system home and it was overclocked by DS and it is not stable, the first thing the DS techs will tell you is to put the clocks back to stock settings, making the overclocking package irrelevant.
The overclocking that is going on by these PC builders is largely a marketing effort and not really an effort to give you performance that you notice or really need. A i5-750 with a 5870 or 5850 is going to kick ass in games at high settings all on stock settings.
You can always overclock on your own. And that is a fun and interesting thing to learn.
Pro Case 850W Green Cathode
Intel Quad Q6600 790i Mobo 4GB DDR3 1333 RAM 260 216 OC Video Card 150/150GB 10k Raptor RAID X-Fi Fatal1ty Vista 64Bit Ultimate 22" Samsung |
Posted: 17 Feb 2010 at 9:24pm |
Looks like I have to repeat myself:
I think that is a horrible idea, taking into account that you can't upgrade the cpu with the p55 platform, its basically a dead platform. plus the i5 sucks at multi gpu. look below, that is with an 870 which is much better then the 750:
in short the gaming performance is not the same, not if you want multi gpu ability. so lets recap, bad idea for multi gpu, can't upgrade the cpu, don't sound good to me. also does anybody know why it is that every benchmark with i5 vs i7 done between 750 and 920, is done with the 920 having only 3GB of ram or 4GB vs the 6GB it should have, its at its best when using 3Gb increments, where the i5 has 4GB of ram, which is how its setup to be used, also every test is done at 1600 x 1200, why don't they do 1900 x 1200 and 2560 x 1600 so we can see the real difference, and lastly whey don't they oc the i5 and lets see how it hands with the 920 and then lets test them so we can see the real world use of the chip not just why they decided to do, most of us have 6GB ram, game at 1600 x 1200 and 1900 x 1200. all the benchmarks I have seen so far were setup to favor the i5. wow man just because you don't see how big the value is in just being able to upgrade your cpu, does not mean it has no value to everybody else. if you gonna point all of that stuff out then point out the negatives also, let them know that the p55 platform is a dead platform, does not do well with cf at all, in the long run you will save money with a x58 platform cause you can upgrade the cpu, with the p55 you are left with its crappy performance or buying a new pc or paying more and buying a new mobo, installing it, then buying a new cpu and installing that, all of that equals to more money. if you were building yourself the price difference might have been worth it but here the price difference is only a 100 or 200 and that can't justify all the negatives and lower performance in everything else other then games. you need to take into account that everybody here is not buying a pc just for gaming alone, they do many other things, burning cds, archiving, encoding, media editing and etc, the 750 will suck at that vs a 920 when both oced, and with win7 HT makes even a bigger difference. show me a benchmark with both the 750 and 920 having 3GB of ram both and both at 1600MHz or atleast 1333MHz, and at 1200 x 1000 and 1900 x 1200 and I will show you how different the 920 is. I also like to point out to everybody that all of these benchmarks, even if they were equal in specs, the results won't matter for crap here, simply because all those benchmarks are at 2.66Ghz and not oced, there is no guarantee that a 750 will endup with the same oc as a 920, and that will change everything also. also how does it make sense to spend money on the more expensive gpu that will make no difference and then get stingy on the brain of the cpu and the ability to upgrade it? what bells and whisles are you talking about? farcry2 highest settings and 8x aa and 16x af, notice at 1600 x 1200 the 5850 gets you 55 fps and that is smooth gaming, the 5870 gets you only 6 more fps to 61 fps, you won't notice the difference and the bells and whistels are on:
I can show as many of these as you like Call of Duty 5: World at War again highest settings, 8x aa and 16x af:
this time 59 vs 71, again you won't be able to tell teh difference. if you sli a 5870 on these machines you will be at 80% capacity of your psu, as I said you will be pushing it and not a good idea, and on an i5 platform you will have even less to gain. Edited by DST4ME - 17 Feb 2010 at 10:26pm |
Monstromo
Posted: 17 Feb 2010 at 10:44pm |
I am not at all fazed by this kind of aggressive attack on another forum member's opinions. However, I can see why people avoid posting though because it is annoying to have such slobbering angst hurled at you for just having an opinion about on processor compared to another.
Anyway, the i5-750 paired with a 5850 or a 5870 will give you great performance. So much so that you won't miss the the i7-920. If you want to move up to a 5870 that is fine because it will make it so you can crank the AA and other DX11 features in just about any game. I can't make any promises about Crysis 2 though. The 5850 will struggle with Crysis and a 5870 less so. That is about the best way I can describe the noticeable difference between those cards.
Thei5-750 is such a powerful CPU that it will be years before you think about upgrading it. So, I don't think there is any real concern about the life left in the platform.
The i7-920 is a nice CPU, but it isn't the only CPU to consider when building or choosing what is going to be primarily a gaming machine. Unless you have applications that utilize hyper threading the i5-750 will kick as much ass the an i7-920.
The is no benchmark conspiracy going on through out the internet giving the i5-750 the edge. Look at the benches yourself put out by gamers, researchers and journalists and decide for yourself.
The i5-750 is not a poor man's CPU in any way shape or form. If you want a 5870 go for it. The GPU is far more important in gaming than the CPU.
In any event, it will be great system, with either CPU or GPU, it is not like there is a wrong decision. The difference is really just money and personal preference.
I have a rig with an i5-750 and a 5850, and I think going with a 5870 would have been preferrable if I would have had the benjamins.
Posted: 17 Feb 2010 at 10:57pm |
excuse me if I take other people's money seriously.
you tell him that he will see a difference between 5870 and 5850 with bells and whistles and I just showed you that you were wrong. we don't care for opinoins here when it comes to other's moeny, facts are more important, and fact is that 5870 will not make a difference you can see vs the 5850 at 1600 x 1200 with the bells and whistles, you will excuse me if I don't like the members getting opinions that are false and then spending money based on that false advise. you say there is no conspiracy going on, OK show me, show me a benchmark with the 920 with the same exact amount of ram as the 750 and the same exact speed of ram, also show me the difference in both 1200 x 1000 and 1900 x 1200. how can you expect anybody to take any benchmark seriously that is not even, where the i5 has either more amount of ram and/or faster ram speed, and why aer all the benchmarks at 1600 x 1200? lollllllllllllll ok so prove me wrong, show me a even benchmark. rogueunicorn go look at the benchmarks but keep in mind that things are not level, so of course if the i5 has more ram or faster ram, its does not take a genius to figure out that the i5 numbers should be better. rogueunicorn as yourself this, is this machine only for gaming? cause in everhing else the i5 is very inferior. also let me ask you this: in 3 years if I said would you like to upgrade your cpu to a 6core newer cpu, would you say yes or no? if you say yes then you can't do that with the i5. personally if I'm spending this much money, I feel stupid putting myself in a system that can't do cf if I need it, all of that for what? $100 or so dollars? |
Frozen Anvil
Joined: 16 Jan 2010 Online Status: Offline Posts: 76 |
Posted: 17 Feb 2010 at 11:02pm |
**Sits back and eats some popcorn**
![]() DST is the man. Edited by Frozen Anvil - 17 Feb 2010 at 11:04pm |
rogueunicorn
Posted: 17 Feb 2010 at 11:09pm |
stop the arguing lol. i'm going to get the 5850 with the 1000w, just in case i decide to go crossfire. i'm sticking with everything else i chose.
justin.kerr
Joined: 06 May 2008 Online Status: Offline Posts: 5084 |
Posted: 17 Feb 2010 at 11:13pm |
the 750 is a great CPU, and with a single GPU it performs well, with 2 cards it falls behind the 920, and with 3 it is a pile of crap, so if you want one GPU, and a good gaming rig then there is nothing wrong with the 750, want 3 GTX 480's go 920, simple stuff here.
Posted: 17 Feb 2010 at 11:14pm |
I appologise if I its sounds like I'm fighting, I just get all excited, I just want users to know teh facts and not my opinion or anybody else's, its the facts that matters, who cares what I or anybody else thinks, if during the daytime I think its nightime, does it mean its nightime?
I think in 3 years you will see its was a smart choice you made.
I think being able to upgrade your cpu is a very big deal, so I don't think its just a matter multi gpu, also justin you yourself have said many time how much difference those 8 threads make with win7, so we have to take that into account also right? Edited by DST4ME - 17 Feb 2010 at 11:16pm |
justin.kerr
Posted: 17 Feb 2010 at 11:18pm |
yes it does make a difference, but the difference is small with one GPU, and gaming.
Heavy multi tasking, and multi GPU's then yes a pretty big difference.
Posted: 17 Feb 2010 at 11:30pm |
ya but the win7 itself you said its own performance with ht is much snappier and noticeable.
plus lots of people here can't afford to buy a new pc every 2 or 3 years so being able to upgrade to a newer cpu and 6 core is huge deal. Edited by DST4ME - 17 Feb 2010 at 11:32pm |
Frozen Anvil
Posted: 17 Feb 2010 at 11:49pm |
Some Olympics we are having, huh!
Dragoonseal
Joined: 03 Apr 2009 Online Status: Offline Posts: 2247 |
Posted: 18 Feb 2010 at 12:07am |
I don't understand, why would you recommend such an inferior and dead socket system to save less than $200?
Go head, try configuring some yourself. Here are two, same parts used in both of these except one is Core i7 920, 6GB RAM, EVGA X58 3X motherboard, the other is Core i5 750, 4GB RAM, EVGA P55 SLI motherboard. Ticket Number: 385884 Total Price with Instant Savings: $1,736.00 Direct Load URL: http://www.digitalstormonline. Ticket Number: 385779 Total Price with Instant Savings: $1,930.00 Direct Load URL: http://www.digitalstormonline. Price difference? $194. That is pathetic, you have to give up so much for it. You give up hyper threading (which does make quite the difference in Windows 7), the ability to SLI or Crossfire without the CPU totally crapping out (!!!), 2GB of RAM (4GB is no longer the sweet spot for today's needs), lots of motherboard functionality, and the ability to upgrade your PC in the future. What's the thinking? The only situation I could see it ever being worth going for is if you are skimping on every part possible in an attempt to skim the price down on a computer and you just have absolutely nothing left sacrifice other than the CPU and motherboard and you don't mind having a dead system with no upgradability. But if you don't mind a dead system and have to cut the price down that badly why not just go with a cheaper AMD Phenom system? And think carefully about the answer to that last question, because the answer will also be why you would want to go with a X58 socket 1366 Core i7 system instead of the dead P55 socket 1156. |
Posted: 18 Feb 2010 at 12:12am |
lol what are you talking about, justin would never agree with you that a 5870 is better for 1600 x 1200, in anything jsuting will tell you that a 5850 with a good oc will be great for 1900 x 1200.
all justin is agreeing with is that for gaming the 750 will perform the same as 920 in games, in everyhing else he does not agree with you. thank you Dragoonseal this is what I'm saying, for 200 get the ability to upgrade cpu, you get more ram, you get 8 threads, ability to cf, and much better performance in everything else other then gaming. not to mention you are also getting a better mobo: x58 is the left one and the p55 is the right one:
and don't forget he is telling users with 1600 x 1200 to spend the difference on a 5870 which will not make a noticeable difference in games at that res at all, so its not even a matter of saving that $194. the i5 your listed is $1736 with no gpu, now lest add a 5850 which is a great card for 1600 x 1200 and can be oced to offer the same performance of 5870, so the price with 5850 comes to $2084, but he wants you to get a 5870 so the price with a 5870 comes to $2201. so how is it better to spend the same money, but get a less ram, inferior mobo, you can't upgrade teh cpu, 4 less threads, less performance in everything else other then gaming. how does that even make sense? Edited by DST4ME - 18 Feb 2010 at 12:26am |
rogueunicorn
Posted: 19 Feb 2010 at 11:21pm |
@DST4ME. thank you SOOO much for all of your help, im sticking with the i7.
Posted: 20 Feb 2010 at 2:59am |
My pleasure and good luck
rogueunicorn
Posted: 25 Feb 2010 at 11:00pm |
curses! i have received word that the noctua dh-14 wont fit my mobo. should i get the asus p6x58 or change my cooler? also, is the corsair dominator any better then the digital storm ram?
Edited by rogueunicorn - 26 Feb 2010 at 2:09am |
Posted: 26 Feb 2010 at 4:16am |
no dominator is not better, and no don't go with asus.
if you don't have use for a lot of pci cards then go with the micro. if you do have use then go with the LE. or change your cooler to the u12 which is just fine also. Edited by DST4ME - 26 Feb 2010 at 4:16am |
rogueunicorn
Posted: 26 Feb 2010 at 5:18pm |
is the u12 just the dual 120mm fans? or is it blackops exclusive? because i really want to keep the evga 3x sli mobo.
Posted: 26 Feb 2010 at 6:25pm |
Its a dual I believe, you can double check if you like, its a great cooler.
rogueunicorn
Posted: 26 Feb 2010 at 6:43pm |
so would recommend the evga 3x sli with the noctua 120mms? also, do you think digital storm could replace the blue led a green led? and paint the inside black?
Posted: 26 Feb 2010 at 7:06pm |
yes I would definitely recommend the 3x sli and the noctua 12.
the front 200mm led will be replaces with a 140mm green led if you want green, cm makes the 200mm in blue and red but not green. and yes they can paint the inside. |
rogueunicorn
Posted: 27 Feb 2010 at 1:02pm |
is the silverstone raven case any good? i've been looking at that one
Page 12> |
